remote application pool recycle using WMI \ PowerShell
B
I'm having some trouble finding the best method for recycling remote IIS6
application pools using PowerShell.
In the past this has always been very easy using VB script:
Function PoolRecycle(strServer)
On Error Resume Next
Err.Clear
Dim objWMIService
Dim colItems
Dim objItem
'recycle application pool
WScript.Echo ""
Err.Clear
Set objWMIService = GetObject _
("winmgmts:{authenticationLevel=pktPrivacy}\\" _
& strServer & "\root\microsoftiisv2")
'connect to WMI
Set colItems = objWMIService.ExecQuery("Select * From IIsApplicationPool")
'Step through the objects to be recycled
For each objItem in colItems
objItem.Recycle
If err = 0 Then
WScript.Echo(strServer & " - " & ObjItem.Name & " Recycled")
PoolRecycle = "success"
Else
WScript.Echo("Unable to recycle the application pool on " & strServer)
PoolRecycle = "failed"
End If
Next
End Function
I have attempted to duplicate the same thing in PowerShell, but I believe I
am still running into an issue with the pktPrivacy authentication setting.
The following code works when executing localy, but not on a remote host:
Function PoolRecycle($strServerName)
$objWMI = [WmiSearcher] "Select * From IIsApplicationPool"
$objWMI.Scope.Path = "\\" + $strServerName + "\root\microsoftiisv2"
$objWMI.Scope.Options.Authentication = 6
$pools = $objWMI.Get()
foreach ($pool in $pools)
$pool.recycle()
if (!$?)
Write-Host $pool.name " - ERROR"
else
Write-Host $pool.name " - Recycled"
Any help or better ways of accomplishing this in PowerShell would be very
much appreciated!
Thanks
Bill
S
Shay Levi
If you know the application pool name (the function returns true/false respectively:
function Recycle-AppPool{
param([string]$server,[string]$appPool)
([WMI]"\\$server\root\MicrosoftIISv2:IIsApplicationPool.Name='W3SVC/AppPools/$appPool'").recycle();
if($? -ne 0}{$false} else {$true}
To get a list of application pool names:
$computer = "your Server name/ip"
gwmi -class IIsApplicationPool -namespace "root\MicrosoftIISv2" -computer
$computer | % {$_.name}
Shay Levi
$cript Fanatic
http://scriptolog.blogspot.com
> IIS6 application pools using PowerShell.
> Err.Clear
> Dim objWMIService
> Dim colItems
> Dim objItem
> WScript.Echo ""
> Err.Clear
> 'connect to WMI
> objItem.Recycle
> If err = 0 Then
> Else
> strServer)
> End If
> Next
> End Function
> believe I am still running into an issue with the pktPrivacy
> authentication setting. The following code works when executing
> $pool.recycle()
> if (!$?)
> else
> very much appreciated!
> Thanks
> Bill
S
Shay Levi
Pinging the remote machine before trying to recycle pools is a recommended
practice.
for those who are not familiar with gwmi and %, I should say that they are
aliases for:
gwmi = get-wmiobject
% = foreach-object
I should have written it like:
get-wmiobject -class IIsApplicationPool -namespace "root\MicrosoftIISv2"
-computer $computer | foreach-object {$_.name}
Shay Levi
$cript Fanatic
> respectively:
> -computer
> Shay Levi
> $cript Fanatic
>> Err.Clear
>> Dim objWMIService
>> Dim colItems
>> Dim objItem
>> WScript.Echo ""
>> Err.Clear
>> 'connect to WMI
>> objItem.Recycle
>> If err = 0 Then
>> Else
>> strServer)
>> End If
>> Next
>> End Function
>> $pool.recycle()
>> if (!$?)
>> else
>> Thanks
>> Bill
B
Shay,
Thanks for the help, but I see the namespace "root\MicrosoftIISv2" operate
differently when attempting to access it on a remote IIS6 computer (default
W2K3 installs).
The code examples you pointed out all work fine when targeting the namespace
locally, but I recieve access denied messages when useing the same commands
remotely.
I have tried from multiple machines to multiple servers. The VB Script I
supplied still works in all cases, which leads me to believe I am not setting
the PowerShell WMI object authentication to use pktPrivacy correctly.
Any advice would be appreciated.
Thanks
Bill
> practice.
> aliases for:
> % = foreach-object
> Shay Levi
> $cript Fanatic
> > respectively:
> > -computer
> > Shay Levi
> > $cript Fanatic
> >> Err.Clear
> >> Dim objWMIService
> >> Dim colItems
> >> Dim objItem
> >> WScript.Echo ""
> >> Err.Clear
> >> 'connect to WMI
> >> objItem.Recycle
> >> If err = 0 Then
> >> Else
> >> strServer)
> >> End If
> >> Next
> >> End Function
> >> $pool.recycle()
> >> if (!$?)
> >> else
> >> Thanks
> >> Bill
S
Shay Levi
Bill
I can't test it right now. Try this on the remote server(s:)
1. Start > Run > dcomcnfg > ENTER
2. In the left pane (Compnent Services.msc) expand "Component Services" >
Computers
3. Right click "My Computer"
4. In the "Default Properties" tab tick the "Enable COM Internet Services
on this computer" checkbox
5. Reboot remote server
6. Test again
I can't recall if you need to add Access Permissions in the "COM Security"
tab.
Shay Levi
$cript Fanatic
> Shay,
> operate differently when attempting to access it on a remote IIS6
> computer (default W2K3 installs).
> namespace locally, but I recieve access denied messages when useing
> the same commands remotely.
> Script I supplied still works in all cases, which leads me to believe
> I am not setting the PowerShell WMI object authentication to use
> Thanks
> Bill
>> recommended practice.
>> -computer $computer | % {$_.name}
>> they are
>> aliases for:
>> % = foreach-object
>> "root\MicrosoftIISv2" -computer $computer | foreach-object {$_.name}
>> Shay Levi
>> $cript Fanatic
>>> A
>>> -computer
>>> Shay Levi
>>> $cript Fanatic
>>>> remote IIS6 application pools using PowerShell.
>>>> Err.Clear
>>>> Dim objWMIService
>>>> Dim colItems
>>>> Dim objItem
>>>> WScript.Echo ""
>>>> Err.Clear
>>>> 'connect to WMI
>>>> objItem.Recycle
>>>> If err = 0 Then
>>>> Else
>>>> strServer)
>>>> End If
>>>> Next
>>>> End Function
>>>> $pool.recycle()
>>>> if (!$?)
>>>> else
>>>> be
>>>> Thanks
>>>> Bill
B
Hi Shay,
I have tested this and it still does not resolve the issue.
I guess I must be missing something. The fact that the VB Script works and
the PowerShell does not, leads me to believe that I have an issue with my
script and not the security on the target server.
I may have to use PowerShell to call the actual .Net class instead of using
the built in commands.
Funny, I would have never believed that something as simple as recycling a
remote application pool would be so hard :)
Thanks again for the help.
Bill
"Shay Levi" wrote:
> Bill
> Computers
> 6. Test again
> tab.
> Shay Levi
> $cript Fanatic
> > Shay,
> > Thanks
> > Bill
> >> they are
> >> aliases for:
> >> % = foreach-object
> >> Shay Levi
> >> $cript Fanatic
> >>> A
> >>> -computer
> >>> Shay Levi
> >>> $cript Fanatic
> >>>> Err.Clear
> >>>> Dim objWMIService
> >>>> Dim colItems
> >>>> Dim objItem
> >>>> WScript.Echo ""
> >>>> Err.Clear
> >>>> 'connect to WMI
> >>>> objItem.Recycle
> >>>> If err = 0 Then
> >>>> Else
> >>>> strServer)
> >>>> End If
> >>>> Next
> >>>> End Function
> >>>> $pool.recycle()
> >>>> if (!$?)
> >>>> else
> >>>> be
> >>>> Thanks
> >>>> Bill
S
Shay Levi
Are you able to list the Application poll names?
$server="server"
$objWMI.Scope.Path = "\\$server\root\microsoftiisv2"
$objWMI.Scope.Options.Authentication = [System.Management.AuthenticationLevel]::PacketPrivacy
$pools | foreach { $_.name }
Shay Levi
$cript Fanatic
> Hi Shay,
> works and the PowerShell does not, leads me to believe that I have an
> issue with my script and not the security on the target server.
> using the built in commands.
> recycling a remote application pool would be so hard :)
> Bill
> "Shay Levi" wrote:
>> Bill
>> Services" >
>> Computers
>> Services
>> 6. Test again
>> Security" tab.
>> Shay Levi
>> $cript Fanatic
>>> Shay,
>>> believe I am not setting the PowerShell WMI object authentication to
>>> Thanks
>>> Bill
>>>> they are
>>>> aliases for:
>>>> % = foreach-object
>>>> {$_.name}
>>>> Shay Levi
>>>> $cript Fanatic
>>>>> C/
>>>>> A
>>>>> -computer
>>>>> Shay Levi
>>>>> $cript Fanatic
>>>>>> Err.Clear
>>>>>> Dim objWMIService
>>>>>> Dim colItems
>>>>>> Dim objItem
>>>>>> WScript.Echo ""
>>>>>> Err.Clear
>>>>>> 'connect to WMI
>>>>>> objItem.Recycle
>>>>>> If err = 0 Then
>>>>>> Else
>>>>>> strServer)
>>>>>> End If
>>>>>> Next
>>>>>> End Function
>>>>>> $pool.recycle()
>>>>>> if (!$?)
>>>>>> else
>>>>>> be
>>>>>> Thanks
>>>>>> Bill
S
Shay Levi
#8
Bill
Just to clarify, I'm not able to recycle remote app pools, just list their
names (Access denied).
Even adding full security on IIsApplicationPool (WMI Properties) didn't resolve
it.
I'm still on it...
Shay Levi
$cript Fanatic
> $server="server"
> Shay Levi
> $cript Fanatic
>> Hi Shay,
>> Bill
>> "Shay Levi" wrote:
>>> Bill
>>> Services" >
>>> Computers
>>> Services
>>> 6. Test again
>>> Security" tab.
>>> Shay Levi
>>> $cript Fanatic
>>>> Shay,
>>>> Thanks
>>>> Bill
>>>>> they are
>>>>> aliases for:
>>>>> % = foreach-object
>>>>> {$_.name}
>>>>> Shay Levi
>>>>> $cript Fanatic
>>>>>> V
>>>>>> C/
>>>>>> A
>>>>>> -computer
>>>>>> Shay Levi
>>>>>> $cript Fanatic
>>>>>>> Err.Clear
>>>>>>> Dim objWMIService
>>>>>>> Dim colItems
>>>>>>> Dim objItem
>>>>>>> WScript.Echo ""
>>>>>>> Err.Clear
>>>>>>> 'connect to WMI
>>>>>>> objItem.Recycle
>>>>>>> If err = 0 Then
>>>>>>> Else
>>>>>>> strServer)
>>>>>>> End If
>>>>>>> Next
>>>>>>> End Function
>>>>>>> I
>>>>>>> $pool.recycle()
>>>>>>> if (!$?)
>>>>>>> else
>>>>>>> would
>>>>>>> be
>>>>>>> Thanks
>>>>>>> Bill
B
#9
Hi Shay,
Yeah, I can list the pools, but only after specifing the authentication
setting.
It's almost like it does not carry to the other objects.
I appreciate the help.
Thanks
Bill
"Shay Levi" wrote:
> Bill
> it.
> I'm still on it...
> Shay Levi
> $cript Fanatic
> > $server="server"
> > Shay Levi
> > $cript Fanatic
> >> Hi Shay,
> >> Bill
> >> "Shay Levi" wrote:
> >>> Bill
> >>> Services" >
> >>> Computers
> >>> Services
> >>> 6. Test again
> >>> Security" tab.
> >>> Shay Levi
> >>> $cript Fanatic
> >>>> Shay,
> >>>> Thanks
> >>>> Bill
> >>>>> they are
> >>>>> aliases for:
> >>>>> % = foreach-object
> >>>>> {$_.name}
> >>>>> Shay Levi
> >>>>> $cript Fanatic
> >>>>>> V
> >>>>>> C/
> >>>>>> A
> >>>>>> -computer
> >>>>>> Shay Levi
> >>>>>> $cript Fanatic
> >>>>>>> Err.Clear
> >>>>>>> Dim objWMIService
> >>>>>>> Dim colItems
> >>>>>>> Dim objItem
> >>>>>>> WScript.Echo ""
> >>>>>>> Err.Clear
> >>>>>>> 'connect to WMI
> >>>>>>> objItem.Recycle
> >>>>>>> If err = 0 Then
> >>>>>>> Else
> >>>>>>> strServer)
> >>>>>>> End If
> >>>>>>> Next
> >>>>>>> End Function
> >>>>>>> I
> >>>>>>> $pool.recycle()
> >>>>>>> if (!$?)
> >>>>>>> else
> >>>>>>> would
> >>>>>>> be
> >>>>>>> Thanks
> >>>>>>> Bill
S
Shay Levi
#10
I'll keep looking for it :-)
Shay Levi
$cript Fanatic
> Hi Shay,
> Thanks
> Bill
> "Shay Levi" wrote:
>> Bill
>> their
>> didn't resolve
>> it.
>> I'm still on it...
>> Shay Levi
>> $cript Fanatic
>>> $server="server"
>>> Shay Levi
>>> $cript Fanatic
>>>> Hi Shay,
>>>> an issue with my script and not the security on the target server.
>>>> of using the built in commands.
>>>> Bill
>>>> "Shay Levi" wrote:
>>>>> Bill
>>>>> Services" >
>>>>> Computers
>>>>> Services
>>>>> 6. Test again
>>>>> Security" tab.
>>>>> Shay Levi
>>>>> $cript Fanatic
>>>>>> Shay,
>>>>>> "root\MicrosoftIISv2" operate differently when attempting to
>>>>>> access it on a remote IIS6 computer (default W2K3 installs).
>>>>>> the namespace locally, but I recieve access denied messages when
>>>>>> useing the same commands remotely.
>>>>>> Thanks
>>>>>> Bill
>>>>>>> that
>>>>>>> they are
>>>>>>> aliases for:
>>>>>>> % = foreach-object
>>>>>>> {$_.name}
>>>>>>> Shay Levi
>>>>>>> $cript Fanatic
>>>>>>>> 3S
>>>>>>>> V
>>>>>>>> C/
>>>>>>>> A
>>>>>>>> -computer
>>>>>>>> Shay Levi
>>>>>>>> $cript Fanatic
>>>>>>>>> Err.Clear
>>>>>>>>> Dim objWMIService
>>>>>>>>> Dim colItems
>>>>>>>>> Dim objItem
>>>>>>>>> WScript.Echo ""
>>>>>>>>> Err.Clear
>>>>>>>>> 'connect to WMI
>>>>>>>>> objItem.Recycle
>>>>>>>>> If err = 0 Then
>>>>>>>>> Else
>>>>>>>>> strServer)
>>>>>>>>> End If
>>>>>>>>> Next
>>>>>>>>> End Function
>>>>>>>>> but
>>>>>>>>> I
>>>>>>>>> executing
>>>>>>>>> $pool.recycle()
>>>>>>>>> if (!$?)
>>>>>>>>> else
>>>>>>>>> would
>>>>>>>>> be
>>>>>>>>> Thanks
>>>>>>>>> Bill
S
Shay Levi
#11
Bill
Try this, I get no errors on my machines.
$server="server"
$objWMI.Scope.Options.Authentication = [System.Management.AuthenticationLevel]::PacketPrivacy;
$objWMI.Scope.Options.EnablePrivileges=$true;
$pools | foreach {$_.recycle}
Shay Levi
$cript Fanatic
> Shay Levi
> $cript Fanatic
>> Hi Shay,
>> Thanks
>> Bill
>> "Shay Levi" wrote:
>>> Bill
>>> their
>>> didn't resolve
>>> it.
>>> I'm still on it...
>>> Shay Levi
>>> $cript Fanatic
>>>> $server="server"
>>>> Shay Levi
>>>> $cript Fanatic
>>>>> Hi Shay,
>>>>> Bill
>>>>> "Shay Levi" wrote:
>>>>>> Bill
>>>>>> Services" >
>>>>>> Computers
>>>>>> Services
>>>>>> 6. Test again
>>>>>> Security" tab.
>>>>>> Shay Levi
>>>>>> $cript Fanatic
>>>>>>> Shay,
>>>>>>> Thanks
>>>>>>> Bill
>>>>>>>> that
>>>>>>>> they are
>>>>>>>> aliases for:
>>>>>>>> % = foreach-object
>>>>>>>> {$_.name}
>>>>>>>> Shay Levi
>>>>>>>> $cript Fanatic
>>>>>>>>> W
>>>>>>>>> 3S
>>>>>>>>> V
>>>>>>>>> C/
>>>>>>>>> A
>>>>>>>>> -computer
>>>>>>>>> Shay Levi
>>>>>>>>> $cript Fanatic
>>>>>>>>>> Err.Clear
>>>>>>>>>> Dim objWMIService
>>>>>>>>>> Dim colItems
>>>>>>>>>> Dim objItem
>>>>>>>>>> WScript.Echo ""
>>>>>>>>>> Err.Clear
>>>>>>>>>> 'connect to WMI
>>>>>>>>>> objItem.Recycle
>>>>>>>>>> If err = 0 Then
>>>>>>>>>> Else
>>>>>>>>>> strServer)
>>>>>>>>>> End If
>>>>>>>>>> Next
>>>>>>>>>> End Function
>>>>>>>>>> but
>>>>>>>>>> I
>>>>>>>>>> executing
>>>>>>>>>> $pool.recycle()
>>>>>>>>>> if (!$?)
>>>>>>>>>> else
>>>>>>>>>> would
>>>>>>>>>> be
>>>>>>>>>> Thanks
>>>>>>>>>> Bill
S
Shay Levi
#12
You can even connect with alternate credentials:
$wmi.Scope.Options.Username="domain\user"
$wmi.Scope.Options.Password="yourPassword"
Shay Levi
$cript Fanatic
> Bill
> $server="server"
> Shay Levi
> $cript Fanatic
>> Shay Levi
>> $cript Fanatic
>>> Hi Shay,
>>> Thanks
>>> Bill
>>> "Shay Levi" wrote:
>>>> Bill
>>>> list
>>>> their
>>>> didn't resolve
>>>> it.
>>>> I'm still on it...
>>>> Shay Levi
>>>> $cript Fanatic
>>>>> $server="server"
>>>>> Shay Levi
>>>>> $cript Fanatic
>>>>>> Hi Shay,
>>>>>> have an issue with my script and not the security on the target
>>>>>> server.
>>>>>> instead of using the built in commands.
>>>>>> Bill
>>>>>> "Shay Levi" wrote:
>>>>>>> Bill
>>>>>>> Services" >
>>>>>>> Computers
>>>>>>> Services
>>>>>>> 6. Test again
>>>>>>> Security" tab.
>>>>>>> Shay Levi
>>>>>>> $cript Fanatic
>>>>>>>> Shay,
>>>>>>>> when useing the same commands remotely.
>>>>>>>> VB Script I supplied still works in all cases, which leads me
>>>>>>>> to believe I am not setting the PowerShell WMI object
>>>>>>>> Thanks
>>>>>>>> Bill
>>>>>>>>> "root\MicrosoftIISv2" -computer $computer | % {$_.name}
>>>>>>>>> that
>>>>>>>>> they are
>>>>>>>>> aliases for:
>>>>>>>>> % = foreach-object
>>>>>>>>> {$_.name}
>>>>>>>>> Shay Levi
>>>>>>>>> $cript Fanatic
>>>>>>>>>> W
>>>>>>>>>> 3S
>>>>>>>>>> V
>>>>>>>>>> C/
>>>>>>>>>> A
>>>>>>>>>> -computer
>>>>>>>>>> Shay Levi
>>>>>>>>>> $cript Fanatic
>>>>>>>>>>> recycling remote IIS6 application pools using PowerShell.
>>>>>>>>>>> Err.Clear
>>>>>>>>>>> Dim objWMIService
>>>>>>>>>>> Dim colItems
>>>>>>>>>>> Dim objItem
>>>>>>>>>>> WScript.Echo ""
>>>>>>>>>>> Err.Clear
>>>>>>>>>>> 'connect to WMI
>>>>>>>>>>> objItem.Recycle
>>>>>>>>>>> If err = 0 Then
>>>>>>>>>>> Else
>>>>>>>>>>> strServer)
>>>>>>>>>>> End If
>>>>>>>>>>> Next
>>>>>>>>>>> End Function
>>>>>>>>>>> but
>>>>>>>>>>> I
>>>>>>>>>>> executing
>>>>>>>>>>> $pool.recycle()
>>>>>>>>>>> if (!$?)
>>>>>>>>>>> else
>>>>>>>>>>> would
>>>>>>>>>>> be
>>>>>>>>>>> Thanks
>>>>>>>>>>> Bill
S
Shay Levi
#13
I came up with another working version:
$server="server"
$co = new-object System.Management.ConnectionOptions;
$co.Username="domain\username";
$co.Password="password";
$co.Authentication=[System.Management.AuthenticationLevel]::PacketPrivacy;
$co.EnablePrivileges=$true;
$wmi = New-Object System.Management.ManagementObjectSearcher;
$wmi.Query="Select * From IIsApplicationPool";
$wmi.Scope.Path="\\$server\root\microsoftiisv2";
$wmi.Scope.Options=$co;
$wmi.Get() | foreach {
$_.recycle;
if($?){
$_.name + " recycled";
} else {
$_.name + " error";
I hope it solves your problem.
Shay Levi
$cript Fanatic
> Shay Levi
> $cript Fanatic
>> Bill
>> $server="server"
>> Shay Levi
>> $cript Fanatic
>>> Shay Levi
>>> $cript Fanatic
>>>> Hi Shay,
>>>> Thanks
>>>> Bill
>>>> "Shay Levi" wrote:
>>>>> Bill
>>>>> list
>>>>> their
>>>>> didn't resolve
>>>>> it.
>>>>> I'm still on it...
>>>>> Shay Levi
>>>>> $cript Fanatic
>>>>>> $server="server"
>>>>>> Shay Levi
>>>>>> $cript Fanatic
>>>>>>> Hi Shay,
>>>>>>> Script works and the PowerShell does not, leads me to believe
>>>>>>> that I have an issue with my script and not the security on the
>>>>>>> target server.
>>>>>>> Bill
>>>>>>> "Shay Levi" wrote:
>>>>>>>> Bill
>>>>>>>> Services" >
>>>>>>>> Computers
>>>>>>>> Internet
>>>>>>>> Services
>>>>>>>> 6. Test again
>>>>>>>> "COM
>>>>>>>> Security" tab.
>>>>>>>> Shay Levi
>>>>>>>> $cript Fanatic
>>>>>>>>> Shay,
>>>>>>>>> Thanks
>>>>>>>>> Bill
>>>>>>>>>> a recommended practice.
>>>>>>>>>> that
>>>>>>>>>> they are
>>>>>>>>>> aliases for:
>>>>>>>>>> % = foreach-object
>>>>>>>>>> {$_.name}
>>>>>>>>>> Shay Levi
>>>>>>>>>> $cript Fanatic
>>>>>>>>>>> W
>>>>>>>>>>> 3S
>>>>>>>>>>> V
>>>>>>>>>>> C/
>>>>>>>>>>> A
>>>>>>>>>>> -computer
>>>>>>>>>>> Shay Levi
>>>>>>>>>>> $cript Fanatic
>>>>>>>>>>>> Err.Clear
>>>>>>>>>>>> Dim objWMIService
>>>>>>>>>>>> Dim colItems
>>>>>>>>>>>> Dim objItem
>>>>>>>>>>>> WScript.Echo ""
>>>>>>>>>>>> Err.Clear
>>>>>>>>>>>> 'connect to WMI
>>>>>>>>>>>> objItem.Recycle
>>>>>>>>>>>> If err = 0 Then
>>>>>>>>>>>> Recycled")
>>>>>>>>>>>> Else
>>>>>>>>>>>> strServer)
>>>>>>>>>>>> End If
>>>>>>>>>>>> Next
>>>>>>>>>>>> End Function
>>>>>>>>>>>> but
>>>>>>>>>>>> I
>>>>>>>>>>>> pktPrivacy
>>>>>>>>>>>> executing
>>>>>>>>>>>> $pool.recycle()
>>>>>>>>>>>> if (!$?)
>>>>>>>>>>>> else
>>>>>>>>>>>> would
>>>>>>>>>>>> be
>>>>>>>>>>>> Thanks
>>>>>>>>>>>> Bill
B
#14
Hi Shay,
This last set of code seems to have come the closest. I no longer get an
access denied error, but the application pools on the remote server don't
actually recycle.
I have gotten some new ideas from these scripts though and I will try some
things.
Thank You for the continued effort.
Bill
> $server="server"
> $_.recycle;
> if($?){
> } else {
> $_.name + " error";
> Shay Levi
> $cript Fanatic
> > Shay Levi
> > $cript Fanatic
> >> Bill
> >> $server="server"
> >> Shay Levi
> >> $cript Fanatic
> >>> Shay Levi
> >>> $cript Fanatic
> >>>> Hi Shay,
> >>>> Thanks
> >>>> Bill
> >>>> "Shay Levi" wrote:
> >>>>> Bill
> >>>>> list
> >>>>> their
> >>>>> didn't resolve
> >>>>> it.
> >>>>> I'm still on it...
> >>>>> Shay Levi
> >>>>> $cript Fanatic
> >>>>>> $server="server"
> >>>>>> Shay Levi
> >>>>>> $cript Fanatic
> >>>>>>> Hi Shay,
> >>>>>>> target server.
> >>>>>>> Bill
> >>>>>>> "Shay Levi" wrote:
> >>>>>>>> Bill
> >>>>>>>> Services" >
> >>>>>>>> Computers
> >>>>>>>> Internet
> >>>>>>>> Services
> >>>>>>>> 6. Test again
> >>>>>>>> "COM
> >>>>>>>> Security" tab.
> >>>>>>>> Shay Levi
> >>>>>>>> $cript Fanatic
> >>>>>>>>> Shay,
> >>>>>>>>> Thanks
> >>>>>>>>> Bill
> >>>>>>>>>> that
> >>>>>>>>>> they are
> >>>>>>>>>> aliases for:
> >>>>>>>>>> % = foreach-object
> >>>>>>>>>> {$_.name}
> >>>>>>>>>> Shay Levi
> >>>>>>>>>> $cript Fanatic
> >>>>>>>>>>> W
> >>>>>>>>>>> 3S
> >>>>>>>>>>> V
> >>>>>>>>>>> C/
> >>>>>>>>>>> A
> >>>>>>>>>>> -computer
> >>>>>>>>>>> Shay Levi
> >>>>>>>>>>> $cript Fanatic
> >>>>>>>>>>>> Err.Clear
> >>>>>>>>>>>> Dim objWMIService
> >>>>>>>>>>>> Dim colItems
> >>>>>>>>>>>> Dim objItem
> >>>>>>>>>>>> WScript.Echo ""
> >>>>>>>>>>>> Err.Clear
> >>>>>>>>>>>> 'connect to WMI
> >>>>>>>>>>>> objItem.Recycle
> >>>>>>>>>>>> If err = 0 Then
> >>>>>>>>>>>> Recycled")
> >>>>>>>>>>>> Else
> >>>>>>>>>>>> strServer)
> >>>>>>>>>>>> End If
> >>>>>>>>>>>> Next
> >>>>>>>>>>>> End Function
> >>>>>>>>>>>> but
> >>>>>>>>>>>> I
> >>>>>>>>>>>> pktPrivacy
> >>>>>>>>>>>> executing
> >>>>>>>>>>>> $pool.recycle()
> >>>>>>>>>>>> if (!$?)
> >>>>>>>>>>>> else
> >>>>>>>>>>>> would
> >>>>>>>>>>>> be
> >>>>>>>>>>>> Thanks
> >>>>>>>>>>>> Bill
S
Shay Levi
#15
Bill
You're right. The pools aren't recycling. PowerShell doesn't return any error
on $_.recycle
and I assumed no errors returned = recycled.
This turned out to be my typo error. I should have write $_.recycle().
Now its givin me the ACCESS_DENIED again.
I'll check on it some more and see what I can find.
Shay Levi
$cript Fanatic
> Hi Shay,
> an access denied error, but the application pools on the remote server
> don't actually recycle.
> some things.
> Bill
>> $server="server"
>> vacy;
>> $_.recycle;
>> if($?){
>> } else {
>> $_.name + " error";
>> Shay Levi
>> $cript Fanatic
>>> Shay Levi
>>> $cript Fanatic
>>>> Bill
>>>> $server="server"
>>>> Shay Levi
>>>> $cript Fanatic
>>>>> Shay Levi
>>>>> $cript Fanatic
>>>>>> Hi Shay,
>>>>>> Thanks
>>>>>> Bill
>>>>>> "Shay Levi" wrote:
>>>>>>> Bill
>>>>>>> list
>>>>>>> their
>>>>>>> didn't resolve
>>>>>>> it.
>>>>>>> I'm still on it...
>>>>>>> Shay Levi
>>>>>>> $cript Fanatic
>>>>>>>> $server="server"
>>>>>>>> Shay Levi
>>>>>>>> $cript Fanatic
>>>>>>>>> Hi Shay,
>>>>>>>>> the target server.
>>>>>>>>> Bill
>>>>>>>>> "Shay Levi" wrote:
>>>>>>>>>> Bill
>>>>>>>>>> Services" >
>>>>>>>>>> Computers
>>>>>>>>>> Internet
>>>>>>>>>> Services
>>>>>>>>>> 6. Test again
>>>>>>>>>> "COM
>>>>>>>>>> Security" tab.
>>>>>>>>>> Shay Levi
>>>>>>>>>> $cript Fanatic
>>>>>>>>>>> Shay,
>>>>>>>>>>> targeting the namespace locally, but I recieve access denied
>>>>>>>>>>> messages when useing the same commands remotely.
>>>>>>>>>>> The VB Script I supplied still works in all cases, which
>>>>>>>>>>> leads me to believe I am not setting the PowerShell WMI
>>>>>>>>>>> Thanks
>>>>>>>>>>> Bill
>>>>>>>>>>>> is a recommended practice.
>>>>>>>>>>>> say
>>>>>>>>>>>> that
>>>>>>>>>>>> they are
>>>>>>>>>>>> aliases for:
>>>>>>>>>>>> % = foreach-object
>>>>>>>>>>>> {$_.name}
>>>>>>>>>>>> Shay Levi
>>>>>>>>>>>> $cript Fanatic
>>>>>>>>>>>>> me
>>>>>>>>>>>>> W
>>>>>>>>>>>>> 3S
>>>>>>>>>>>>> V
>>>>>>>>>>>>> C/
>>>>>>>>>>>>> A
>>>>>>>>>>>>> -computer
>>>>>>>>>>>>> Shay Levi
>>>>>>>>>>>>> $cript Fanatic
>>>>>>>>>>>>>> script:
>>>>>>>>>>>>>> Err.Clear
>>>>>>>>>>>>>> Dim objWMIService
>>>>>>>>>>>>>> Dim colItems
>>>>>>>>>>>>>> Dim objItem
>>>>>>>>>>>>>> WScript.Echo ""
>>>>>>>>>>>>>> Err.Clear
>>>>>>>>>>>>>> 'connect to WMI
>>>>>>>>>>>>>> objItem.Recycle
>>>>>>>>>>>>>> If err = 0 Then
>>>>>>>>>>>>>> Recycled")
>>>>>>>>>>>>>> Else
>>>>>>>>>>>>>> strServer)
>>>>>>>>>>>>>> End If
>>>>>>>>>>>>>> Next
>>>>>>>>>>>>>> End Function
>>>>>>>>>>>>>> PowerShell,
>>>>>>>>>>>>>> but
>>>>>>>>>>>>>> I
>>>>>>>>>>>>>> pktPrivacy
>>>>>>>>>>>>>> executing
>>>>>>>>>>>>>> IIsApplicationPool"
>>>>>>>>>>>>>> $pool.recycle()
>>>>>>>>>>>>>> if (!$?)
>>>>>>>>>>>>>> else
>>>>>>>>>>>>>> PowerShell
>>>>>>>>>>>>>> would
>>>>>>>>>>>>>> be
>>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>>> Bill
S
Shay Levi
#16
I monitored the remote server's WMI log file and found this (truncated) while
executing the code:
CALL ConnectionLogin::NTLMLogin
wszNetworkResource = \\server\root\MicrosoftIISv2
pPreferredLocale =
lFlags = 0x0
DCOM connection from DOMAIN\ShayL at authentiction level Packet, AuthnSvc
= 9, AuthzSvc = 1, Capabilities = 0
CALL CWbemNamespace::ExecQuery
BSTR QueryFormat = WQL
BSTR Query = select * from IIsApplicationPool
IEnumWbemClassObject **pEnum = 0xB9130
Access to the root\MicrosoftIISv2 namespace was denied. The namespace is
marked with RequiresEncryption but the client connection was attempted with
an authentication level below Pkt_Privacy.Re try the connection using Pkt_Privacy
authentication level.
Odd... the connection AuthenticationLevel was specified to PacketPrivacy
Why do I still get access denied?
Shay Levi
$cript Fanatic
> Bill
> any error
> on $_.recycle
> Shay Levi
> $cript Fanatic
>> Hi Shay,
>> get an access denied error, but the application pools on the remote
>> server don't actually recycle.
>> some things.
>> Bill
>>> $server="server"
>>> i
>>> vacy;
>>> $_.recycle;
>>> if($?){
>>> } else {
>>> $_.name + " error";
>>> Shay Levi
>>> $cript Fanatic
>>>> Shay Levi
>>>> $cript Fanatic
>>>>> Bill
>>>>> $server="server"
>>>>> Shay Levi
>>>>> $cript Fanatic
>>>>>> Shay Levi
>>>>>> $cript Fanatic
>>>>>>> Hi Shay,
>>>>>>> Thanks
>>>>>>> Bill
>>>>>>> "Shay Levi" wrote:
>>>>>>>> Bill
>>>>>>>> list
>>>>>>>> their
>>>>>>>> Properties)
>>>>>>>> didn't resolve
>>>>>>>> it.
>>>>>>>> I'm still on it...
>>>>>>>> Shay Levi
>>>>>>>> $cript Fanatic
>>>>>>>>> $server="server"
>>>>>>>>> Shay Levi
>>>>>>>>> $cript Fanatic
>>>>>>>>>> Hi Shay,
>>>>>>>>>> the target server.
>>>>>>>>>> as recycling a remote application pool would be so hard :)
>>>>>>>>>> Bill
>>>>>>>>>> "Shay Levi" wrote:
>>>>>>>>>>> Bill
>>>>>>>>>>> "Component
>>>>>>>>>>> Services" >
>>>>>>>>>>> Computers
>>>>>>>>>>> Internet
>>>>>>>>>>> Services
>>>>>>>>>>> 6. Test again
>>>>>>>>>>> "COM
>>>>>>>>>>> Security" tab.
>>>>>>>>>>> Shay Levi
>>>>>>>>>>> $cript Fanatic
>>>>>>>>>>>> Shay,
>>>>>>>>>>>> to access it on a remote IIS6 computer (default W2K3
>>>>>>>>>>>> installs).
>>>>>>>>>>>> denied messages when useing the same commands remotely.
>>>>>>>>>>>> Thanks
>>>>>>>>>>>> Bill
>>>>>>>>>>>>> say
>>>>>>>>>>>>> that
>>>>>>>>>>>>> they are
>>>>>>>>>>>>> aliases for:
>>>>>>>>>>>>> % = foreach-object
>>>>>>>>>>>>> {$_.name}
>>>>>>>>>>>>> Shay Levi
>>>>>>>>>>>>> $cript Fanatic
>>>>>>>>>>>>>> a
>>>>>>>>>>>>>> me
>>>>>>>>>>>>>> W
>>>>>>>>>>>>>> 3S
>>>>>>>>>>>>>> V
>>>>>>>>>>>>>> C/
>>>>>>>>>>>>>> A
>>>>>>>>>>>>>> -computer
>>>>>>>>>>>>>> Shay Levi
>>>>>>>>>>>>>> $cript Fanatic
>>>>>>>>>>>>>>> PowerShell.
>>>>>>>>>>>>>>> script:
>>>>>>>>>>>>>>> Err.Clear
>>>>>>>>>>>>>>> Dim objWMIService
>>>>>>>>>>>>>>> Dim colItems
>>>>>>>>>>>>>>> Dim objItem
>>>>>>>>>>>>>>> WScript.Echo ""
>>>>>>>>>>>>>>> Err.Clear
>>>>>>>>>>>>>>> 'connect to WMI
>>>>>>>>>>>>>>> objItem.Recycle
>>>>>>>>>>>>>>> If err = 0 Then
>>>>>>>>>>>>>>> Recycled")
>>>>>>>>>>>>>>> Else
>>>>>>>>>>>>>>> strServer)
>>>>>>>>>>>>>>> End If
>>>>>>>>>>>>>>> Next
>>>>>>>>>>>>>>> End Function
>>>>>>>>>>>>>>> PowerShell,
>>>>>>>>>>>>>>> but
>>>>>>>>>>>>>>> I
>>>>>>>>>>>>>>> pktPrivacy
>>>>>>>>>>>>>>> executing
>>>>>>>>>>>>>>> IIsApplicationPool"
>>>>>>>>>>>>>>> $pool.recycle()
>>>>>>>>>>>>>>> if (!$?)
>>>>>>>>>>>>>>> else
>>>>>>>>>>>>>>> PowerShell
>>>>>>>>>>>>>>> would
>>>>>>>>>>>>>>> be
>>>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>>>> Bill
S
Shay Levi
#17
I also found this:
Encrypting Data When Running WMI–Based Remote Administration Scripts (IIS
6.0)
http://www.microsoft.com/technet/pr...ea9-0639-475f-b6c7-883cbde6f3a0.mspx?mfr=true
Authentication level seems to be in place. Anyone???
Shay Levi
$cript Fanatic
> (truncated) while executing the code:
> pPreferredLocale =
> lFlags = 0x0
> AuthnSvc
> namespace is
> with an authentication level below Pkt_Privacy.Re try the connection
> using Pkt_Privacy authentication level.
> PacketPrivacy
> acy;
> Shay Levi
> $cript Fanatic
>> Bill
>> any error
>> on $_.recycle
>> $_.recycle().
>> Shay Levi
>> $cript Fanatic
>>> Hi Shay,
>>> try some things.
>>> Bill
>>>> $server="server"
>>>> r
>>>> i
>>>> vacy;
>>>> $_.recycle;
>>>> if($?){
>>>> } else {
>>>> $_.name + " error";
>>>> Shay Levi
>>>> $cript Fanatic
>>>>> Shay Levi
>>>>> $cript Fanatic
>>>>>> Bill
>>>>>> $server="server"
>>>>>> Shay Levi
>>>>>> $cript Fanatic
>>>>>>> Shay Levi
>>>>>>> $cript Fanatic
>>>>>>>> Hi Shay,
>>>>>>>> Thanks
>>>>>>>> Bill
>>>>>>>> "Shay Levi" wrote:
>>>>>>>>> Bill
>>>>>>>>> just
>>>>>>>>> list
>>>>>>>>> their
>>>>>>>>> Properties)
>>>>>>>>> didn't resolve
>>>>>>>>> it.
>>>>>>>>> I'm still on it...
>>>>>>>>> Shay Levi
>>>>>>>>> $cript Fanatic
>>>>>>>>>> $server="server"
>>>>>>>>>> Shay Levi
>>>>>>>>>> $cript Fanatic
>>>>>>>>>>> Hi Shay,
>>>>>>>>>>> believe that I have an issue with my script and not the
>>>>>>>>>>> Bill
>>>>>>>>>>> "Shay Levi" wrote:
>>>>>>>>>>>> Bill
>>>>>>>>>>>> server(s:)
>>>>>>>>>>>> "Component
>>>>>>>>>>>> Services" >
>>>>>>>>>>>> Computers
>>>>>>>>>>>> Internet
>>>>>>>>>>>> Services
>>>>>>>>>>>> 6. Test again
>>>>>>>>>>>> "COM
>>>>>>>>>>>> Security" tab.
>>>>>>>>>>>> Shay Levi
>>>>>>>>>>>> $cript Fanatic
>>>>>>>>>>>>> Shay,
>>>>>>>>>>>>> installs).
>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>> Bill
>>>>>>>>>>>>>> say
>>>>>>>>>>>>>> that
>>>>>>>>>>>>>> they are
>>>>>>>>>>>>>> aliases for:
>>>>>>>>>>>>>> % = foreach-object
>>>>>>>>>>>>>> foreach-object
>>>>>>>>>>>>>> {$_.name}
>>>>>>>>>>>>>> Shay Levi
>>>>>>>>>>>>>> $cript Fanatic
>>>>>>>>>>>>>>> N
>>>>>>>>>>>>>>> a
>>>>>>>>>>>>>>> me
>>>>>>>>>>>>>>> W
>>>>>>>>>>>>>>> 3S
>>>>>>>>>>>>>>> V
>>>>>>>>>>>>>>> C/
>>>>>>>>>>>>>>> A
>>>>>>>>>>>>>>> -computer
>>>>>>>>>>>>>>> Shay Levi
>>>>>>>>>>>>>>> $cript Fanatic
>>>>>>>>>>>>>>>> PowerShell.
>>>>>>>>>>>>>>>> script:
>>>>>>>>>>>>>>>> Err.Clear
>>>>>>>>>>>>>>>> Dim objWMIService
>>>>>>>>>>>>>>>> Dim colItems
>>>>>>>>>>>>>>>> Dim objItem
>>>>>>>>>>>>>>>> WScript.Echo ""
>>>>>>>>>>>>>>>> Err.Clear
>>>>>>>>>>>>>>>> 'connect to WMI
>>>>>>>>>>>>>>>> objItem.Recycle
>>>>>>>>>>>>>>>> If err = 0 Then
>>>>>>>>>>>>>>>> Recycled")
>>>>>>>>>>>>>>>> Else
>>>>>>>>>>>>>>>> strServer)
>>>>>>>>>>>>>>>> End If
>>>>>>>>>>>>>>>> Next
>>>>>>>>>>>>>>>> End Function
>>>>>>>>>>>>>>>> PowerShell,
>>>>>>>>>>>>>>>> but
>>>>>>>>>>>>>>>> I
>>>>>>>>>>>>>>>> pktPrivacy
>>>>>>>>>>>>>>>> executing
>>>>>>>>>>>>>>>> IIsApplicationPool"
>>>>>>>>>>>>>>>> $pool.recycle()
>>>>>>>>>>>>>>>> if (!$?)
>>>>>>>>>>>>>>>> else
>>>>>>>>>>>>>>>> PowerShell
>>>>>>>>>>>>>>>> would
>>>>>>>>>>>>>>>> be
>>>>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>>>>> Bill
B
#18
Hi Shay,
I'm still pluggin around, but I wanted to run a couple of things by you.
Do you think it could be related to the Timeout option? I'm not sure how to
translate the value, but if it was short our connection could have timed out.
Another possibility could be that the connection options are not carrying
over to the other objects. Maybe reset the $_.psbase.options on each object??
Thanks
Bill
"Shay Levi" wrote:
> I also found this:
> 6.0)
> Shay Levi
> $cript Fanatic
> > pPreferredLocale =
> > lFlags = 0x0
> > AuthnSvc
> > namespace is
> > PacketPrivacy
> > acy;
> > Shay Levi
> > $cript Fanatic
> >> Bill
> >> any error
> >> on $_.recycle
> >> $_.recycle().
> >> Shay Levi
> >> $cript Fanatic
> >>> Hi Shay,
> >>> try some things.
> >>> Bill
> >>>> $server="server"
> >>>> r
> >>>> i
> >>>> vacy;
> >>>> $_.recycle;
> >>>> if($?){
> >>>> } else {
> >>>> $_.name + " error";
> >>>> Shay Levi
> >>>> $cript Fanatic
> >>>>> Shay Levi
> >>>>> $cript Fanatic
> >>>>>> Bill
> >>>>>> $server="server"
> >>>>>> Shay Levi
> >>>>>> $cript Fanatic
> >>>>>>> Shay Levi
> >>>>>>> $cript Fanatic
> >>>>>>>> Hi Shay,
> >>>>>>>> Thanks
> >>>>>>>> Bill
> >>>>>>>> "Shay Levi" wrote:
> >>>>>>>>> Bill
> >>>>>>>>> just
> >>>>>>>>> list
> >>>>>>>>> their
> >>>>>>>>> Properties)
> >>>>>>>>> didn't resolve
> >>>>>>>>> it.
> >>>>>>>>> I'm still on it...
> >>>>>>>>> Shay Levi
> >>>>>>>>> $cript Fanatic
> >>>>>>>>>> $server="server"
> >>>>>>>>>> Shay Levi
> >>>>>>>>>> $cript Fanatic
> >>>>>>>>>>> Hi Shay,
> >>>>>>>>>>> Bill
> >>>>>>>>>>> "Shay Levi" wrote:
> >>>>>>>>>>>> Bill
> >>>>>>>>>>>> server(s:)
> >>>>>>>>>>>> "Component
> >>>>>>>>>>>> Services" >
> >>>>>>>>>>>> Computers
> >>>>>>>>>>>> Internet
> >>>>>>>>>>>> Services
> >>>>>>>>>>>> 6. Test again
> >>>>>>>>>>>> "COM
> >>>>>>>>>>>> Security" tab.
> >>>>>>>>>>>> Shay Levi
> >>>>>>>>>>>> $cript Fanatic
> >>>>>>>>>>>>> Shay,
> >>>>>>>>>>>>> installs).
> >>>>>>>>>>>>> Thanks
> >>>>>>>>>>>>> Bill
> >>>>>>>>>>>>>> say
> >>>>>>>>>>>>>> that
> >>>>>>>>>>>>>> they are
> >>>>>>>>>>>>>> aliases for:
> >>>>>>>>>>>>>> % = foreach-object
> >>>>>>>>>>>>>> foreach-object
> >>>>>>>>>>>>>> {$_.name}
> >>>>>>>>>>>>>> Shay Levi
> >>>>>>>>>>>>>> $cript Fanatic
> >>>>>>>>>>>>>>> N
> >>>>>>>>>>>>>>> a
> >>>>>>>>>>>>>>> me
> >>>>>>>>>>>>>>> W
> >>>>>>>>>>>>>>> 3S
> >>>>>>>>>>>>>>> V
> >>>>>>>>>>>>>>> C/
> >>>>>>>>>>>>>>> A
> >>>>>>>>>>>>>>> -computer
> >>>>>>>>>>>>>>> Shay Levi
> >>>>>>>>>>>>>>> $cript Fanatic
> >>>>>>>>>>>>>>>> PowerShell.
> >>>>>>>>>>>>>>>> script:
> >>>>>>>>>>>>>>>> Err.Clear
> >>>>>>>>>>>>>>>> Dim objWMIService
> >>>>>>>>>>>>>>>> Dim colItems
S
Shay Levi
#19
IMO, its a permissions issue.
Shay Levi
$cript Fanatic
> Hi Shay,
> you.
> how to translate the value, but if it was short our connection could
> have timed out.
> carrying over to the other objects. Maybe reset the $_.psbase.options
> on each object??
> Thanks
> Bill
> "Shay Levi" wrote:
>> I also found this:
>> (IIS
>> 6.0)
>> http://www.microsoft.com/technet/prodtechnol/WindowsServer2003/Librar
>> y/IIS/aa7f3ea9-0639-475f-b6c7-883cbde6f3a0.mspx?mfr=true
>> Shay Levi
>> $cript Fanatic
>>> pPreferredLocale =
>>> lFlags = 0x0
>>> AuthnSvc
>>> namespace is
>>> attempted
>>> PacketPrivacy
>>> iv acy;
>>> Shay Levi
>>> $cript Fanatic
>>>> Bill
>>>> any error
>>>> on $_.recycle
>>>> $_.recycle().
>>>> Shay Levi
>>>> $cript Fanatic
>>>>> Hi Shay,
>>>>> remote server don't actually recycle.
>>>>> try some things.
>>>>> Bill
>>>>>> $server="server"
>>>>>> tP
>>>>>> r
>>>>>> i
>>>>>> vacy;
>>>>>> $_.recycle;
>>>>>> if($?){
>>>>>> } else {
>>>>>> $_.name + " error";
>>>>>> Shay Levi
>>>>>> $cript Fanatic
>>>>>>> Shay Levi
>>>>>>> $cript Fanatic
>>>>>>>> Bill
>>>>>>>> $server="server"
>>>>>>>> Shay Levi
>>>>>>>> $cript Fanatic
>>>>>>>>> Shay Levi
>>>>>>>>> $cript Fanatic
>>>>>>>>>> Hi Shay,
>>>>>>>>>> Thanks
>>>>>>>>>> Bill
>>>>>>>>>> "Shay Levi" wrote:
>>>>>>>>>>> Bill
>>>>>>>>>>> just
>>>>>>>>>>> list
>>>>>>>>>>> their
>>>>>>>>>>> Properties)
>>>>>>>>>>> didn't resolve
>>>>>>>>>>> it.
>>>>>>>>>>> I'm still on it...
>>>>>>>>>>> Shay Levi
>>>>>>>>>>> $cript Fanatic
>>>>>>>>>>>> $server="server"
>>>>>>>>>>>> Shay Levi
>>>>>>>>>>>> $cript Fanatic
>>>>>>>>>>>>> Hi Shay,
>>>>>>>>>>>>> issue.
>>>>>>>>>>>>> simple as recycling a remote application pool would be so
>>>>>>>>>>>>> hard :)
>>>>>>>>>>>>> Bill
>>>>>>>>>>>>> "Shay Levi" wrote:
>>>>>>>>>>>>>> Bill
>>>>>>>>>>>>>> server(s:)
>>>>>>>>>>>>>> "Component
>>>>>>>>>>>>>> Services" >
>>>>>>>>>>>>>> Computers
>>>>>>>>>>>>>> Internet
>>>>>>>>>>>>>> Services
>>>>>>>>>>>>>> 6. Test again
>>>>>>>>>>>>>> the
>>>>>>>>>>>>>> "COM
>>>>>>>>>>>>>> Security" tab.
>>>>>>>>>>>>>> Shay Levi
>>>>>>>>>>>>>> $cript Fanatic
>>>>>>>>>>>>>>> Shay,
>>>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>>>> Bill
>>>>>>>>>>>>>>>> pools is a recommended practice.
>>>>>>>>>>>>>>>> should
>>>>>>>>>>>>>>>> say
>>>>>>>>>>>>>>>> that
>>>>>>>>>>>>>>>> they are
>>>>>>>>>>>>>>>> aliases for:
>>>>>>>>>>>>>>>> % = foreach-object
>>>>>>>>>>>>>>>> foreach-object
>>>>>>>>>>>>>>>> {$_.name}
>>>>>>>>>>>>>>>> Shay Levi
>>>>>>>>>>>>>>>> $cript Fanatic
>>>>>>>>>>>>>>>>> l.
>>>>>>>>>>>>>>>>> N
>>>>>>>>>>>>>>>>> a
>>>>>>>>>>>>>>>>> me
>>>>>>>>>>>>>>>>> W
>>>>>>>>>>>>>>>>> 3S
>>>>>>>>>>>>>>>>> V
>>>>>>>>>>>>>>>>> C/
>>>>>>>>>>>>>>>>> A
>>>>>>>>>>>>>>>>> -computer
>>>>>>>>>>>>>>>>> Shay Levi
>>>>>>>>>>>>>>>>> $cript Fanatic
>>>>>>>>>>>>>>>>>> PowerShell.
>>>>>>>>>>>>>>>>>> script:
>>>>>>>>>>>>>>>>>> Err.Clear
>>>>>>>>>>>>>>>>>> Dim objWMIService
>>>>>>>>>>>>>>>>>> Dim colItems
S
Shay Levi
#20
Bill
I'm still struggling with the WMI method, I tried so many variations and
still gets access denied.
In the meantime I was able to recycle via ADSI, can you confirm?
$server="server"
$pool=[adsi]"IIS://$server/W3SVC/AppPools/DefaultAppPool"
$pool.psbase.Invoke("recycle")
I can see that the w3wp process id is changing.
Shay Levi
$cript Fanatic
> Shay Levi
> $cript Fanatic
>> Hi Shay,
>> you.
>> have timed out.
>> Thanks
>> Bill
>> "Shay Levi" wrote:
>>> I also found this:
>>> (IIS
>>> 6.0)
>>> r y/IIS/aa7f3ea9-0639-475f-b6c7-883cbde6f3a0.mspx?mfr=true
>>> Shay Levi
>>> $cript Fanatic
>>>> pPreferredLocale =
>>>> lFlags = 0x0
>>>> AuthnSvc
>>>> namespace is
>>>> attempted
>>>> connection
>>>> PacketPrivacy
>>>> r
>>>> iv acy;
>>>> Shay Levi
>>>> $cript Fanatic
>>>>> Bill
>>>>> return
>>>>> any error
>>>>> on $_.recycle
>>>>> $_.recycle().
>>>>> Shay Levi
>>>>> $cript Fanatic
>>>>>> Hi Shay,
>>>>>> longer get an access denied error, but the application pools on
>>>>>> the remote server don't actually recycle.
>>>>>> try some things.
>>>>>> Bill
>>>>>>> $server="server"
>>>>>>> e
>>>>>>> tP
>>>>>>> r
>>>>>>> i
>>>>>>> vacy;
>>>>>>> $_.recycle;
>>>>>>> if($?){
>>>>>>> } else {
>>>>>>> $_.name + " error";
>>>>>>> Shay Levi
>>>>>>> $cript Fanatic
>>>>>>>> Shay Levi
>>>>>>>> $cript Fanatic
>>>>>>>>> Bill
>>>>>>>>> $server="server"
>>>>>>>>> Shay Levi
>>>>>>>>> $cript Fanatic
>>>>>>>>>> Shay Levi
>>>>>>>>>> $cript Fanatic
>>>>>>>>>>> Hi Shay,
>>>>>>>>>>> Thanks
>>>>>>>>>>> Bill
>>>>>>>>>>> "Shay Levi" wrote:
>>>>>>>>>>>> Bill
>>>>>>>>>>>> just
>>>>>>>>>>>> list
>>>>>>>>>>>> their
>>>>>>>>>>>> Properties)
>>>>>>>>>>>> didn't resolve
>>>>>>>>>>>> it.
>>>>>>>>>>>> I'm still on it...
>>>>>>>>>>>> Shay Levi
>>>>>>>>>>>> $cript Fanatic
>>>>>>>>>>>>> $server="server"
>>>>>>>>>>>>> Shay Levi
>>>>>>>>>>>>> $cript Fanatic
>>>>>>>>>>>>>> Hi Shay,
>>>>>>>>>>>>>> issue.
>>>>>>>>>>>>>> VB Script works and the PowerShell does not, leads me to
>>>>>>>>>>>>>> class instead of using the built in commands.
>>>>>>>>>>>>>> hard :)
>>>>>>>>>>>>>> Bill
>>>>>>>>>>>>>> "Shay Levi" wrote:
>>>>>>>>>>>>>>> Bill
>>>>>>>>>>>>>>> server(s:)
>>>>>>>>>>>>>>> "Component
>>>>>>>>>>>>>>> Services" >
>>>>>>>>>>>>>>> Computers
>>>>>>>>>>>>>>> Internet
>>>>>>>>>>>>>>> Services
>>>>>>>>>>>>>>> 6. Test again
>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>> "COM
>>>>>>>>>>>>>>> Security" tab.
>>>>>>>>>>>>>>> Shay Levi
>>>>>>>>>>>>>>> $cript Fanatic
>>>>>>>>>>>>>>>> Shay,
>>>>>>>>>>>>>>>> servers. The VB Script I supplied still works in all
>>>>>>>>>>>>>>>> cases, which leads me to believe I am not setting the
>>>>>>>>>>>>>>>> correctly.
>>>>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>>>>> Bill
>>>>>>>>>>>>>>>>> {$_.name}
>>>>>>>>>>>>>>>>> should
>>>>>>>>>>>>>>>>> say
>>>>>>>>>>>>>>>>> that
>>>>>>>>>>>>>>>>> they are
>>>>>>>>>>>>>>>>> aliases for:
>>>>>>>>>>>>>>>>> % = foreach-object
>>>>>>>>>>>>>>>>> foreach-object
>>>>>>>>>>>>>>>>> {$_.name}
>>>>>>>>>>>>>>>>> Shay Levi
>>>>>>>>>>>>>>>>> $cript Fanatic
>>>>>>>>>>>>>>>>>> o
>>>>>>>>>>>>>>>>>> l.
>>>>>>>>>>>>>>>>>> N
>>>>>>>>>>>>>>>>>> a
>>>>>>>>>>>>>>>>>> me
>>>>>>>>>>>>>>>>>> W
>>>>>>>>>>>>>>>>>> 3S
>>>>>>>>>>>>>>>>>> V
>>>>>>>>>>>>>>>>>> C/
>>>>>>>>>>>>>>>>>> A
>>>>>>>>>>>>>>>>>> -computer
>>>>>>>>>>>>>>>>>> Shay Levi
>>>>>>>>>>>>>>>>>> $cript Fanatic
>>>>>>>>>>>>>>>>>>> PowerShell.
>>>>>>>>>>>>>>>>>>> script:
>>>>>>>>>>>>>>>>>>> Err.Clear
>>>>>>>>>>>>>>>>>>> Dim objWMIService
>>>>>>>>>>>>>>>>>>> Dim colItems
