Remove partitions on external hard drive
K
Ken Isaacson
Vista SP2
I have an external hard drive that's divided into 2 partitions. I want to
reformat the drive and eliminate the partitions. (Or do I say I want to have
only 1 partition?)
How do I get rid of the two partitions?
Thanks.
Ken Isaacson
SILENT COUNSEL, a legal thriller
www.KenIsaacson.com
K
Ken Blake, MVP
On Sun, 20 Dec 2009 16:55:23 -0500, "Ken Isaacson"
<KJIsaacson[nospam]@gmail.com> wrote:
> Vista SP2
No.
> (Or do I say I want to have only 1 partition?)
Yes, exactly right!
Just follow the prompts when you partition it.
Ken Blake, Microsoft MVP (Windows Desktop Experience) since 2003
Please Reply to the Newsgroup
On Sun, 20 Dec 2009 16:55:23 -0500, Ken Isaacson wrote:
> Vista SP2
> to reformat the drive and eliminate the partitions. (Or do I say I want
> Thanks.
> Ken Isaacson
> www.KenIsaacson.com
Remove one partition and expand the other into the vacated space. The
partedmagic Live CD will easily do that for you.
D
Dusko Savatovic
Open Disk Management console:
In Search box type
diskmgmt.msc
Right click on diskmgmt.msc and 'Run as administrator'.
In your disk, you will see two partitions.
Select each partition and "Delete Volume".
In unalocated space create partiotion of your choice.
"Ken Isaacson" <KJIsaacson[nospam]@gmail.com> wrote in message
news:765F7B7E-9F93-4241-A00B-AF98A34CE738@newsgroup
> Vista SP2
> Thanks.
> Ken Isaacson
> www.KenIsaacson.com
