Removing a cancelled update
Fredidog
This is actually a repeat of an old thread from 2007 but a solution never appeared because of two unanswered questions, at least, as far as I know. I would like an answer because I have this same problem. I am running Vista Home Premium 64bits. The thread goes like this: I cancelled a Windows Live Essentials 2011, KB2434419, update (ii's optional). No problem, the cancellation appears in the Update Installation History but not in the Updates Uninstalled List, so, I can't remove it. The questions never answered back then in 2007 were "Which update are we talking about" and "Is this Can this Update be removed by uninstalling it after install." Both of these are actually questions without the question marks. In my case I do not want to reinstall, I just want to remove the reference to in the Update Installation History. Has anyone had to solve this and, if so, how? Perhaps I should reinstall it and all the rest then remove them. Thanks...
    Heinz 57 Varieties
    Intel P43 Chipset
    Asus P5QL Pro
    NVIDIA 9400 GT
    Realtek High Definition
    acer 23"
ilikefree
Go to Windows Updates and search for updates. When you see the one you don't want right click it and select hide. You won't see it again unless you show hidden updates.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
