Removing Vista from dualboot PC?
N
Noozer
I've got Windows XP and Vista b5365 installed on my only hard drive. I want
to remove Vista from the PC.
Since I'm now tied down with Vistas boot loader, how do I remove Vista
without losing my XP installation?
C
Chinnasamy Arumugam
Look for a directory 'Boot' on your windows XP root directory. Just rename
them and reboot PC. After reboot, you can delete boot directory as well
format/delete your vista partition.
BTW, boot directory will be a hidden directory. So trun on 'Show all files'
on your windows explorer to see. Or you can directory type the directory in
windows explorer URL windows as 'c:\boot' which will enable the directory in
the explorer windows.
Chins
"Noozer" <[email protected]> wrote in message
news:%[email protected]
> want to remove Vista from the PC.
J
Jason
I would recommend backing up all of your files first. You just never know
how beta software may not like deleting or changing things.
Jason
Windows Vista, Build 5308
"Chinnasamy Arumugam" <[email protected]> wrote in message
news:[email protected]
> files' on your windows explorer to see. Or you can directory type the
> directory in windows explorer URL windows as 'c:\boot' which will enable
> the directory in the explorer windows.
> Chins
Z
Zack Whittaker
Very important to backup files before you modify global settings, booting
options and BIOS settings :o)
Zack Whittaker
» ZackNET Enterprises: www.zacknet.co.uk
» MSBlog on ResDev: www.msblog.org
» Vista Knowledge Base: www.vistabase.co.uk
» This mailing is provided "as is" with no warranties, and confers no
rights. All opinions expressed are those of myself unless stated so, and not
of my employer, best friend, Ghandi, my mother or my cat. Glad we cleared
that up!
--: Original message follows :--
"Jason" <[email protected]> wrote in message
> Jason
>> rename them and reboot PC. After reboot, you can delete boot directory as
>> well format/delete your vista partition.
>> Chins
A
Andre Da Costa [Extended64]
You can use VistaBootPro 1.0 to clean up the boot manager, just don't delete
the earlier version of Windows entry:
http://www.pro-networks.org/vistabootpro/
Andre
Extended64 | http://www.extended64.com
Blog | http://www.extended64.com/blogs/andre
http://spaces.msn.com/members/adacosta
> Jason
>> Chins
B
blahhh
If the Vista boot menu allows to dual boot to XP, you don't need to do
anything. It will still allow to do this after removing the Vista partition.
However if you'd like to remove the Vista boot menu then there's a tool to
do that in the Boot folder or the Vista DVD.
