Repair icon the the control panel
D
David Sherman
For some reason, the add/remove program icon in the Control Panel
"Classic View".
How do I restore it?
thanks
Z
Zack Whittaker
It's not there. Instead, select "Programs" then select your option from
there :o)
Zack Whittaker
» ZackNET Enterprises: www.zacknet.co.uk
» MSBlog on ResDev: www.msblog.org
» Vista Knowledge Base: www.vistabase.co.uk
» This mailing is provided "as is" with no warranties, and confers no
rights. All opinions expressed are those of myself unless stated so, and not
of my employer, best friend, Ghandi, my mother or my cat. Glad we cleared
that up!
--: Original message follows :--
"David Sherman" <[email protected]> wrote in message
news:p[email protected]
> "Classic View".
> thanks
A
Andre Da Costa [Extended64]
D
David Sherman
Under Control Panel, there is a program item. The add programs is
empty and there is no remove.
If I go to "Non-classis view, i see an icon that says remove programs.
On Mon, 24 Apr 2006 21:57:12 +0100, "Zack Whittaker"
>there :o)
>Zack Whittaker
>that up!
>> "Classic View".
>> thanks
A
In Build 5365, I see four icons, Currently Running Programs, Installed
Programs, Startup Programs and Windows Features.
Currently Running Programs - Open applications that are running or Task that
are running in the backgroun.
Installed Programs - Programs you have installed on Windows Vista
Startup Programs - Applications that load up in your start up folder, such
as Adobe Gamma, Acrobat Distiller for example.
Windows Features - Components that come installed with Windows, such as
Games, IIS, NFS for example.
Andre
Windows Connected | http://www.windowsconnected.com
Extended64 | http://www.extended64.com
Blog | http://www.extended64.com/blogs/andre
http://spaces.msn.com/members/adacosta
news:[email protected]
>>there :o)
>>Zack Whittaker
>>not
>>that up!
>>> "Classic View".
>>> thanks
D
David Sherman
It is a pain to find. It can be found inder installed programs.
On Mon, 24 Apr 2006 15:14:01 -0700, "Andre Da Costa [Extended64]"
>Depending on the build you are using, its a blank icon, just look for the
>name Programs.
>Andre
>> "Classic View".
>> thanks
A
But "Installed Programs" is located under "Programs"
Andre
>>name Programs.
>>Andre
>>> "Classic View".
>>> thanks
