Repair Vista without install DVD?
R
romanom
I have an HP notebook with Vista Home Premium and after running SFC I have a
few corrupted files.
Question is there a way to bring in the original files when the OEM didn't
send an install DVD or will offer one at all?
All I have is the recovery partition with the option to "repair to original
factory condition" which from what I gather means erasing all my settings and
personal files.
I have made a recovery disc (from the partition) and I have the "Anytime
Upgrade DVD," and I'm curious is there any way to access the upgrade DVD to
get to those files or even do a real repair of Vista without losing settings
and personal files?
P
philo
"romanom" <romanom@xxxxxx> wrote in message
news:4519225B-02CA-49B8-8952-A1361F3989CA@xxxxxx
a
original
and
> personal files.
to
settings
> and personal files?
I'd use *extreme* caution when using SFC.
To be honest with you...I don't know if the previous problems with SFC have
been fixed with Vista...
but my guess is that they have not been.
SFC (at least in the past) usually did way more harm than good.
First off..SFC stores system files in it's archive. Unless the archive
itself is updated each time Windows itself is updated...
SFC will recognize the *newer* files as corrupted...and if you opt to fix
them...you will replace the updated system files with their older version.
I'd leave SFC completely alone and use "system restore" if you run into any
major problems
T
Tom Ferguson
At this time, you can use your recovery disk
or back up your user files, repair to original factory condition, go to
Microsoft update and jump through those hoops, restore user files
or purchase a retail version, back up user files, wipe the HD, install
retail version, &c.
Tom
MSMVP 1998-2007
>a
> original
> and
> personal files.
> to
> settings
> and personal files?
C
Curious
Have you tried running check disk to fix the corrupted files?
My computer/ right click on the drive/properties/Tools menu
>a
> original
> and
> personal files.
> to
> settings
> and personal files?
M
mee mee
I am having problems too. I have corrupted files that are slowing the
entire vista down. I need a back up disc of some kind, to reinstall the
vista. Can you or someone help me?
> a
> original
> and
> > personal files.
> to
> settings
> > and personal files?
> major problems
P
philo
"mee mee" <mee mee@xxxxxx> wrote in message
news:644632D2-49B9-4A64-8140-95270261B0F8@xxxxxx
> "philo" wrote:
About all you can do for starters is try a "system restore"
M
mee mee
I did try to restore. Didn't work. It restored, but still having major
problems. Where do I buy a restore disk?
P
philo
#8
"mee mee" <meemee@xxxxxx> wrote in message
news:A1340818-D2A1-4EC2-BCE1-754EEB906E17@xxxxxx
Contact the manufacturer of you machine
T
Twayne
#9
> have a few corrupted files.
> didn't send an install DVD or will offer one at all?
> original factory condition" which from what I gather means erasing
> all my settings and personal files.
> "Anytime Upgrade DVD," and I'm curious is there any way to access the
> upgrade DVD to get to those files or even do a real repair of Vista
> without losing settings and personal files?
Uhh, once you get things straightened out again, consider this a warning
that you should be BACKING UP YOUR DATA! You spent the money on Vista,
now spend a couple dollars on an imaging program for your backup needs.
You should probably read your documentation a little closer; there are
usually two methods of recovery; one which should not damage data, and
the other which definitely will remove all your data.
A backup is ALWAYS necessary before messing with anything to do with
the OS in order to avoid problems such as this.
Best of luck,
Twayne
Tired of MS Office and their shananigans?
Try this free replacement:
http://www.openoffice.org
T
Twayne
#10
>> I have a few corrupted files.
>> the upgrade DVD to get to those files or even do a real repair of
>> Vista without losing settings and personal files?
> SFC have been fixed with Vista...
> fix them...you will replace the updated system files with their older
> version.
> into any major problems
Well, we now know what YOU would do! And what your opinion of SFC is.
None of which had anything to do with the OP's problem or assistance for
him in any way. Did you forget part of your post? Or was that all you
had to say?
Twayne
M
Mike Hall - MVP
#11
>a
> original
> and
> personal files.
> to
> settings
> and personal files?
The last time I came across an HP, there was a facility to do a repair. Back
up , that is to say save, your important stuff to CD or DVD.
Then run the HP recovery function. If there is an option to repair, take it
or else go for destructive recovery..
Mike Hall - MVP
http://msmvps.com/blogs/mikehall/default.aspx
P
philo
#12
"Twayne" <nodoby@xxxxxx> wrote in message
news:lUvnj.5274$z_6.697@xxxxxx
> > version.
> had to say?
The OP said SFC found corrupt files...however the files may not be
corrupt...
the so called corruption could be due to an un-updated data base...
that's why running SFC can be a bad idea.
