Replacing Multiple Characters In A String
J
JMinnick
I created a powershell script to create directories and rename files based on
MP3 tags..
MP3 tags occasionally have characters the can't be used in filenames/folders..
My solution looks a bit ugly.. Is there a more efficient way to replace all
the special characters in a string than this?
((((((((((" " + $media.Tag.Album).Trim()).Replace( ":" , " " )).Replace("?"
, " ")).Replace("/" , " ")).Replace("\" , " ")).Replace("|" ,"
")).Replace("*" , " ")).Replace("<" , " ")).Replace(">" , " ")).Replace('"' ,
Note: $media.Tag.Album would return a string like "Is there A Key?/Are you
there?".
Creating a folder or file with that name would fail..
My solution does remove all the special characters in a string. A couple of
the characters are replaced with nothing rather than a space which was
intentional.
Any suggestions?
Thanks
B
Brandon Shell [MVP]
look at the -replace operator
It will replace a RegEx with another string
$string -replace "ThisRegEx","WithThisOne"
Brandon Shell
Blog: http://www.bsonposh.com/
PSH Scripts Project: www.codeplex.com/psobject
J> I created a powershell script to create directories and rename files
J> based on MP3 tags..
J>
J> MP3 tags occasionally have characters the can't be used in
J> filenames/folders..
J>
J> My solution looks a bit ugly.. Is there a more efficient way to
J> replace all the special characters in a string than this?
J>
J> ---------------------------------------------------------------------
J> ------------
J>
J> ((((((((((" " + $media.Tag.Album).Trim()).Replace( ":" , " "
J> )).Replace("?" , " ")).Replace("/" , " ")).Replace("\" , "
J> ")).Replace("|" ," ")).Replace("*" , " ")).Replace("<" , "
J> ")).Replace(">" , " ")).Replace('"' , "")
J>
J> ------------
J>
J> Note: $media.Tag.Album would return a string like "Is there A
J> Key?/Are you there?".
J>
J> Creating a folder or file with that name would fail..
J>
J> My solution does remove all the special characters in a string. A
J> couple of the characters are replaced with nothing rather than a
J> space which was intentional.
J>
J> Any suggestions?
J>
J> Thanks
J>
K
Kiron
PowerShell's Test-Path has an -IsValid switch that will check a path's syntax, if it returns $false then replace the unwanted chars:
# build an alternaton regex pattern with the unwanted chars:
$fChars = ':', '?', '/', '\', '|', '*', '<', '>', '"'
$pat = [string]::join('|', ($fChars | % {[regex]::escape($_)}))
$name = '"Is there A Key?/Are you there?"'
# replace any unwanted char wth a '_' if path is not valid
if (!(test-path $name -isValid)) {$name = $name -replace $pat, '_'}
$name
# replace any unwanted char wth nothing if path is not valid
if (!(test-path $name -isValid)) {$name = $name -replace $pat}
$name
Kiron
K
Kiron
Missed the ' ' for some and nothing for the rest unwanted chars...
# build two alternation regex patterns with the unwanted chars:
$fChars1 = ':', '?', '/', '\', '*', '<', '>'
$fChars2 = '|', '"'
$pat1 = [string]::join('|', ($fChars1 | % {[regex]::escape($_)}))
$pat2 = [string]::join('|', ($fChars2 | % {[regex]::escape($_)}))
# replace the unwanted char wth a ' ' or nothing if path is not valid
$name = $name -replace $pat1, ' ' -replace $pat2
$name
Kiron
J
JMinnick
Cool. Very interesting.
Thanks for your help!
> $fChars2 = '|', '"'
> $name
> Kiron
