Replying with non-default account
berserker
44
Is there an option to reply to e-mail with the same account rather than the default account?
For example, gmail is my default account. However, if I reply to an e-mail sent to my Cox account Windows Live Mail chooses gmail as the "from" account. I have to manually select the Cox account as the "from" account. Is there a way to make WLM automatically set the "from" account to be the same as the "to" account when replying to e-mail?
TIA
    Intel Core2 Quad Q6600
    Gigabyte GA-P35-DS4 rev. 2.0
    8GB G.SKILL DDR2 800
    VisionTek Radeon HD 4870
    Two WD Caviar SE16 250GB SATA 2 in RAID0. Two Seagate Barracuda 7200.10 500 GB SATA 2 in RAID1.
G
Galen
My reply is at the bottom of your sent message.
In news:861c34ff2902a878f60f5d8151ae07a1@xxxxxx-gateway.com,
berserker <guest@xxxxxx-email.com> typed:
> TIA
It isn't a very helpful answer but the answer is, as near as I can tell, an
emphatic no. What you can TRY is to remove the outbound settings from the
one you don't want to use as default and see if that automagically does it
for you. You can *try* it but I have no clue if that will even work. (Save
the settings somewhere if you don't know them by heart or can't easily find
them in case it doesn't work.)
Galen (Not Current MS-MVP)
My Geek Site: http://kgiii.info
Web Hosting: http://whathostingshould.be
"In solving a problem of this sort, the grand thing is to be able to reason
backwards. That is a very useful accomplishment, and a
very easy one, but people do not practise it much. In the every-day affairs
of life it is more useful to reason forwards, and so
the other comes to be neglected. There are fifty who can reason
synthetically for one who can reason analytically." - Sherlock
Holmes
G
Galen
In news:%23$2VZUUFJHA.5060@xxxxxx,
....winston <winstonmvp@xxxxxx> typed:
> Still using the logo ?
Yip. As I recall such was allowed per the usage rights/limitations.
(Assuming you mean the MVP logo on my site.)
Hmm... No one's complained about it in the past year or so. (I skipped the
2k7 season to do some travels and poke at new stuff.)
Holmes
W
...winston
Afaik... the logo usage is year to year(renewable) expiring after a year from license agreement or end of status.
...winston
ms-mvp mail
"Galen" <galennews@xxxxxx> wrote in message news:OrF3ggVFJHA.3392@xxxxxx
> Yip. As I recall such was allowed per the usage rights/limitations. (Assuming you mean the MVP logo on my site.)
> Hmm... No one's complained about it in the past year or so. (I skipped the 2k7 season to do some travels and poke at new stuff.)
> "In solving a problem of this sort, the grand thing is to be able to reason backwards. That is a very useful accomplishment, and
> a
> very easy one, but people do not practise it much. In the every-day affairs of life it is more useful to reason forwards, and so
> the other comes to be neglected. There are fifty who can reason synthetically for one who can reason analytically." - Sherlock
> Holmes
G
Galen
In news:OXge2uVFJHA.3408@xxxxxx,
>> a
>> Holmes
Meh... If they yell I'll remove it and find something witty for it. It has
been about a year and I actually get a lot of traffic from Microsoft users
themselves on the site and no one from Microsoft has worried about it so
far. Heck, even my old lead doesn't worry about it AFAIK. Then again there
are still a few MVPs who are members of the site so maybe that's why they
don't care.
Holmes
Barman58
Staff member
1,797
Location
Newport, South Wales, UK
Hi berserker,
This is a little out of left field ...
gmail has the very option that you are looking for.
if you elect to allow gmail to collect your other mail [settings - accounts FYI] you can select to use original account for reply
not sure how it would work with remote access via wlm, depends on how they have their SMTP set-up i guess, but who knows it may be an option worth looking at :confused:
I've got my setup to do this with some accounts so if you want to test things PM me and I'll give you a mail address to check what happens with my T Bird IMAP SET-UP. :)
  • Show second system?
    No
    Operating System
    Windows 10 Pro 1709 Fall Creators Update (16299.192)
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    2 x 1920x1080 @50Hz
    Internal
    Crucial CT256MX100SSD1 256GB SSD,
    WDC WD30EZRX-00D8PB0 3TB,
    Toshiba HDWD130 3TB
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS 4TB +1TB
    Wireless Logitec - MX Master + M570 Trackball
    Wireless Logitec MK710 + K400+
    37.8 MB Down 9.5 MB Up
M
Michael Santovec
#8
It should be doing what you want. It should use the account that
Downloaded the message. That works fine for me.
Are you perhaps having Gmail fetch your COX mail and then it downloads
via Gmail? That would cause your problem.
Or if you moved the message out of WLM and then back into it, it would
lose track of the account that downloaded it.
You can use View, Columns to add the Account column to your folder and
see what account WLM thinks downloaded the message.
Mike - http://pages.prodigy.net/michael_santovec/techhelp.htm
"berserker" <guest@xxxxxx-email.com> wrote in message
news:861c34ff2902a878f60f5d8151ae07a1@xxxxxx-gateway.com...
> than
> "from"
> TIA
> berserker
berserker
44
#9
Are you perhaps having Gmail fetch your COX mail and then it downloads via Gmail? That would cause your problem.
Bingo. Gmail is fetching my mail and then WLM downloads it via IMAP.
Thanks for the reply. I'll just have to manually choose my "from" account.
