Resource Monitor question...
R
rwphilips
Within Resource Monitor (from Task Manager) in the Memory area there
is an item called Hard Faults. What exactly does that mean??
thanks, Rich
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
thanks, Rich
Hi Rich,
"The number of hard faults per minute currently resulting from the application instance.
A hard fault (also known as a page fault) occurs when the page of the referenced address is no longer in physical memory and has been swapped out or is available from a backing file on disk. It is not an error. However, a high number of hard faults may explain the slow response time of an application if it must continually read data back from disk rather than from physical memory."
In the Resoure Monitor, click on Help and type "hard Fault" (no quotes) in the Search tab. You will get more information on this and all the other items to.
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
R
rwphilips
I have 2 gigs of memory and the resource monitor shows about 45%
used... I assume that includes all the background services also.
On Sun, 2 Dec 2007 00:26:11 -0600, brink
>> thanks, Rich
>Hi Rich,
>other items to.
>Hope this helps,
>Shawn
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Rich,
Yes, the background services will definitely use their share of memory. The biggest use of memory is Superfetch. It preloads data it thinks you will need next to help make things run faster. You can read more about Superfetch in this tutorial. See the related links to change what you want Superfetch to preload.
http://www.vistax64.com/tutorials/72293-superfetch-memory-prefetcher.html
My memory hovers around the 45% used mark too.
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
