restart a process in XP ..
M
Hi there,
I'm not a programmer and would really appricate some help here. I need a
VB script to get the PID of a running process from the name and then
kill it and/or restart it. I read about taskkill, but that opens a DOS
box and requires the name of the process, the PID of which changes.
Don't ask me to study examples as when I learned BASIC we were still
using single letter variable names .. :)
$winkill "someProcess" .. kill it ...
$winkill -r "someProcess" .. kill it and restart ...
P
Pegasus \(MVP\)
"Mark" <markbilk@xxxxxx> wrote in message
news:g4iqju$42p$1@xxxxxx
> Hi there,
> VB script to get the PID of a running process from the name and then kill
> it and/or restart it. I read about taskkill, but that opens a DOS box and
> Don't ask me to study examples as when I learned BASIC we were still using
This is my lazy day so I'll give you a one-line batch file solution that
would
kill the task "Duc20".
@echo off
for /f "tokens=2" %%a in ('tasklist ^| find /i "duc20"') do taskkill /pid
%%a
M
> This is my lazy day so I'll give you a one-line batch file solution that would kill the task "Duc20".
> @echo off
> for /f "tokens=2" %%a in ('tasklist ^| find /i "duc20"') do taskkill /pid %%a
kool ..
I've been reading up and I see some other references to PID, I'll try
the cut and paste method ..
P
Pegasus \(MVP\)
news:g4iskm$75f$1@xxxxxx
>> @echo off
>> %%a
> kool ..
> I've been reading up and I see some other references to PID, I'll try the
You could, of course, kill the task by its name, then restart it:
@echo off
tasklist | find /i "duc20" && taskkill /im "duc20.exe" /f
"c:\Program Files\Duc\Duc20.exe"
The above code assumes that you're running Windows XP Professional.
