Restart, shutdown, etc. missing from start menu
vdesai
5
Ok my problem is that suddenly some of the entries disappeared from the menu that comes up in the start menu, I have googled to see it there is a solution and it was not, tried system restore, and I even replaced patched uxtheme (and other) file(s) to the originals. Ill attach my CBS.log from the sfc scan. Images of the problem below.
how it should look is:
Thank you for your help :)
Sorry Had to zip the log up.
johngalt
Antidisestablishmentarian
3,921
Location
3rd Rock
I am not sure why, and I am not an expert in reading CBS.logs, but it seemed to me that there are *way* too many entries for things that were fixed.
I would get some HD diagnostics from your HD manufacturer, and check the HD 0- and if all goes well, then re-install.
    Windows 10 Insider Preview current build
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Classified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    SanDisk Ultra SDSSDHII-960G-G25 SATA III SSD (System)
    Crucial MX100 CT256MX100SSD1 SATA III SSD (User Tree)
    2 * Seagate Barracuda 7200.12 ST31000528AS SATA II
    Seagate ST1500DL001 7200 RPM SATA II
    Intel SSDSA2M080G2GC SATA II SSD
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    300+ Mbps downstream / 30+ Mbps upstream
    Windows 10 Insider Preview (current)
    Dell Inspiron 3521
    Intel(R) Celeron(R) CPU 1007U @ 1.50GHz
    Dell
    Intel(R) HD Graphics
    Intel(R) Display Audio | Realtek Audio
    Inspiron 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Dell
    Dell
    Dell
    Logitech MX Master | Synaptics TouchPad
    Dell
    300+ Mbps downstream | 30+ Mbps upstream
sidney1st
968
Location
Paris
Using uxtheme may occur a lot of problems with sp1.
Open gpedit.
Go to User configuration/Administrative templates/Start menu and Taskbar/
set the remove and prevent access to the shutdown ........... to its default value.
Bare Foot Kid
R.I.P. August 13th 2014
2,616
Location
The Lowcountry
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
vdesai
5
Ill give these suggestions a try once I go home thanks for all the help, ya and The CBS.log is from four or five scans :P ill try and do a new scan and clear the cbs log once I get home.
johngalt
3,921
Location
3rd Rock
That would be a lot of help - let's see what your current status is in regards to the cbs logs and try the suggestions given to see if you can get it fixed - obviously, a reinstall takes tie and you want to avoid that if possible....
    The Beast Model V
    2 * 1920 x 1080
    Logitech MX Master
    Dell Inspiron 3521
    Dell
    Inspiron 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Dell
    Dell
    Dell
    Dell
vdesai
5
I gave them all a try, did a chkdsk and scanned my disk to see if it was going bad but nope no problems there. And I have the new log attached. From what I can tell the only corrupt file is shellbrd.dll if nothing works ill just try a repair install and if that doesn't work clean install ftw.
