Return from a piped foreach in function
Azureus
Hello,
I am observing a curious behavior in PowerShell 2.0. The code:
function test()
1,2,3 | %{if($_ -eq 2){return}else{Write-Host $_}}
test
outputs
1
3
while the code:
function test()
$a = 1,2,3
foreach($b in $a)
if($b -eq 2){return}else{Write-Host $b}
test
outputs
1
In the first example, why does the return statement not return from the function?
M
Marco Shaw [MVP]
> -In the first example, why does the return statement not return from
> the function?
PS>help about_return
It appears you must return "something" if you want to actually see output.
Marco
P
PaulChavez
I think because ForEach-Object processes each item in the pipeline, but the
foreach statement processes the collection as a whole.
So in the first function the return keyword ends processing of that one item
in the pipeline, in the second function you're breaking out of the entire
foreach statement.
Paul
"Azureus" wrote:
> Hello,
> -function test()
> test-
> outputs
> -1
> 3-
> while the code:
> function test()
> $a = 1,2,3
> foreach($b in $a)
> test-
> outputs
> -1
> the function?
> Azureus
