Reverse Stereo? Left to Right?
P
Peter
Hi
Can I make Vista to reverse the stereo sound -- having the left sound play
on the right side and vice versa?
I have external speakers hooked up to my computer, and due to the short
cables on the speakers, it works better if the left speaker is on the right,
but thus my stereo is wrong...
Any ideas?
C
Carey Frisch [MVP]
Just reverse the physical placement of your speakers.
Carey Frisch
Microsoft MVP
Windows Shell/User
"Peter" <Peter@xxxxxx> wrote in message
news:0465AACA-35BE-41C0-A868-BED567AE8EC6@xxxxxx
Hi
Any ideas?
J
jonathan perreault
advice would be get small extension cable i don't think you can but i never
tried
Jonathan Perreault
Personnal Advice To You:
#1: Do Not Undermine Windows's Work, Or It'll Undermine You As A User.
#2: Torture Windows (Any) Now Before It Tortures You
Best Comments From Users:
No Matter The Problem Even With Linux, It's Microsoft's And Windows's Faults
A common mistake that people make when trying to design something completely
foolproof is to underestimate the ingenuity of complete fools.
> Hi
> right,
> Any ideas?
J
jonathan perreault
don't think that's what she/he meant.
Jonathan Perreault
"Carey Frisch [MVP]" <cnfrisch@xxxxxx> wrote in message
news:434FC804-3C0A-4F4C-A938-8DBAB050B0E6@xxxxxx
> Carey Frisch
> Microsoft MVP
> Windows Shell/User
> Hi
> right,
> Any ideas?
yes, such cables exist - often sold as extensions for headsets.
Try a Radio Shack or other electronics store.
Val
"jonathan perreault" <jonperreault@xxxxxx> wrote in message
news:F3597D85-8D85-411C-89BE-7E6A40AAE575@xxxxxx
tried
Jonathan Perreault
> Hi
> right,
> Any ideas?
L
Lang Murphy
> Hi
> right,
> Any ideas?
You should be able to get extension cables for just about any type of
connector. Most PC speaker systems use mini-jacks... you should be able to
find a mini-jack extension at your local Radio Shack.
Lang
Hi.. I have not dealt with Vista yet. But on my XP machine, I'm using
Realtek sound card and the drivers I got comes with a utility. Maybe you
should find out the manufacturer of your sound card and download the drivers
plus utility to fine tune your sound card, if such utility exist. Just a
thought.
Regards.
> Hi
> right,
> Any ideas?
G
Gene K
#8
You can buy either longer cables or buy adapters (female jacks at both ends)
to create your own longer cables.
Gene K
> never tried
> Jonathan Perreault
> Faults
> completely foolproof is to underestimate the ingenuity of complete fools.
>> Hi
>> play
>> right,
>> Any ideas?
J
jonathan perreault
#9
what i meant by i don't think you can is i don't think you can do what you
were talking about but like i was saying in the first place which no one is
answering your answer is that you are better off with a extension cable
Jonathan Perreault
> never tried
> Jonathan Perreault
> Faults
>> Hi
>> play
>> right,
>> Any ideas?
H
HeyBub
#10
Peter wrote:
> Hi
> play on the right side and vice versa?
> short cables on the speakers, it works better if the left speaker is
> on the right, but thus my stereo is wrong...
Reminds me of the sign scrawled on the wall behind the commode:
"If you can read this, report to the Student Health Center to have your head
reversed."
B
Bruce Chambers
#11
Peter wrote:
> Hi
> Any ideas?
Consult the maker of your sound card to see if they built that
capability into their hardware and its device drivers.
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety. ~Benjamin Franklin
Many people would rather die than think; in fact, most do. ~Bertrand Russell
The philosopher has never killed any priests, whereas the priest has
killed a great many philosophers.
~ Denis Diderot
