Right click and Windows Explorer hangs/not responding
  • Thread starter Sage - John Leonard
  • Start date
S
Sage - John Leonard
Using Vista Busniess on Dell Optiplex 755.
Whenever I right click a folder or file, Windows Explorer goes into Not
Responding.
I have reset the folders and run sfc /scannow.
No changes!
When I run in Safe Mode - all is ok??
any thoughts?
thx
M
Malke
> Responding.
> No changes!
Problems with right-clicking are usually caused by third-party software that
has inserted itself into the context menu. In your case, the culprit is
something running in Regular Mode. The easiest way to troubleshoot this is
by using the free ShellExView program. Here are some links about it, too (it
doesn't matter that they reference XP):
Right-click is slow or weird behavior caused by context menu handlers -
http://windowsxp.mvps.org/slowrightclick.htm
Manage the context-menu entries for folders, drives and Namespace objects -
http://windowsxp.mvps.org/context_folders.htm
http://www.nirsoft.net/utils/shexview.html - ShellExView
Malke
MS-MVP
Elephant Boy Computers - Don't Panic!
http://www.elephantboycomputers.com/#FAQ
S
Sage - John Leonard
As implied below, I di all the Non Microsoft Context Menus - no luck!
I ran a couple of Restore Points and they did not install correctly?
So I un-did them.
Does this al mean I should do a Vista Repair?
If I do will that take care of the Windows explorer Hanging/Not Responding
problem?
thx
"Sage - John Leonard" <sagegrp@xxxxxx> wrote in message
news:C4397623-AD17-477A-99CE-A18BB536B292@xxxxxx
> Tried this and it did not seem to help.
> I have mostly Microsoft for "Context Menu"
> Even if I right click an icon (shortcut) on my Desktop - it hangs (Not
> Responding)?
> Any other thoughts?
> thx
> "Malke" <malke@xxxxxx> wrote in message
> news:OAoJ72oJKHA.6016@xxxxxx
>>> Responding.
>>> No changes!
>> that
>> is
>> (it
>> objects -
>> Malke
>> MS-MVP
S
Sage - John Leonard
Ran a Restore Point in Safe mode and al my problems with right clicking
went away.
thx for you help
news:0AD47D64-8EEF-4C1B-8EAB-4995CCE16810@xxxxxx
> So I un-did them.
> problem?
> thx
>> Responding)?
>> Any other thoughts?
>> thx
>>>> Responding.
>>>> No changes!
>>> that
>>> is
>>> (it
>>> objects -
>>> Malke
>>> MS-MVP
