RunDLL , Error in C:\Users\"name"\AppData\Local\Temp\qbgjcifd.dll
S
HELP PLEASE, i got my new laptop with windows vista home premium, only 4 days
with me, brand new laptop.
the error last line written including the topic message : Missing entry:run
plz help, i understand from searching the web that this could possible be a
virus, it happened today this error, this error comes out when i enter to my
user account, afte the desktop icons appear it pumps out, the problem all the
desktop icon and the windows bar dissapear and only the watch that is on the
desktop is there, the background picture is there, i cant access any program
nor enter any key in the keyboard, the only thing i can do is moving the
mouse and shutting down manually, i have another user account, its PERFECTLY
RUNNING with no errors, this error happened exactly about the time i lefted
the house and camed back 3 hours later, at that time my laptop was
downloading and istalling "sonyerricson"update service (note this is the only
program not availabe in the healthy user i have) when i camed back i found
the error whith the update download for my mobile is finished.
my 2nd problem which complicated things is that the affected user has alot
of IMPORTANT DOCUMENTS and its protected with a password and afingerprint to,
i CANT ACCESS CONTROLL PANEL AND DISABLE IT BECAUSE OF THE ORIGINAL PROBLEM,
i wanted atleast to transfer the files from a user to the other user.
PLEASE HELP ME
J
Joolz
Hi Sami
I have a very similar problem to you, my error message reads
error in C:\Users\Julie\AppData\Local\Temp\wtkcohst.dll
Missing entry:run
My problems are all the same as well
I think this is a virus but im not getting very far in sorting it out.
Joolz
Joolz
Posted via http://www.vistaheads.com
U
usasma
Re: RunDLL , Error in C:\Users\"name"\AppData\Local\Temp\qbgjcifd.
Have you tried clearing out your Temp files (in Safe Mode if needs be)?
You can use this free program to help: http://www.ccleaner.com/
- John
"Joolz" wrote:
> Hi Sami
> Missing entry:run
> Joolz
> Joolz
S
i have the same problem and using ccleaner doesn't work.
> - John
> "Joolz" wrote:
> > Hi Sami
> > Missing entry:run
> > Joolz
> > Joolz
J
Joolz
I gave up trying to fix it, I appeared to have Lop virus and Virtumonde.
I have re-installed my windows back to factory settings and it all seems
fine again, but I re-installed it from my hardrive rather than from a
DVD, so im hoping it doesnt come back.
Joolz
V
venkatesh kumar
Solution to RUN error
This error occurs when u accidentally deleted some dll file in temp folder.. the file may also ve been deleted by your anti virus.. To fix it go to ur PC's resitry editor.. To open the editor Start>Run> and type "regedit". There go to HT_LOCAL_MACHINE>Software>Microsoft>Run and locate the DLL file that causes the error or Edit>Find and search for the file that creates the error.. In your case wtkcohst.dll.. You'll get a service that uses that file.. U just delete it.. U re now free of that error.. Reboot n enjoy..
