Running a Command line script from within powershell.
R
I have a 3rd party command line tool I need to run from within a
powershell script.
What is the current method for doing this? I need the calling
powershell script to wait for the 3rd party tool to finish before
moving on...
the tool has a number of input I need to provide...
I'm trying to do something like this !
$Tool="D:\tool.exe"
$Password="passw0rd"
$InputFile="D:\tmp\input.txt"
$CmdLine = $Tool + " -u=User -p=" + $Password + " -i=" + $InputFile +"
-m=mode"
NOW HOW WOULD I RUN THE $CmdLine !?
Thanks in advance.
Russ.
S
Shay Levi
Pipe it to out-null to make the current command wait until it finishes before
moving on.
Shay Levi
$cript Fanatic
http://scriptolog.blogspot.com
> powershell script.
> moving on...
> $Tool="D:\tool.exe"
> -m=mode"
> Thanks in advance.
> Russ.
R
invoke-expression doesn't appear to do anything !?
I've tried the command line in a dos prompt and it works fine.
Any other ideas out there please?
I've tried :
invoke-expression -command $CmdLine
and
invoke-expression -command $CmdLine | out-null
Neither appear to even attempt to run the $CmdLine.
Thanks Again.
Russ
S
Shay Levi
Runing native commands (executables) in PowerShell is much like running them
in DOS, type:
ipconfig /all
and get the output just as if you typed it in CMD.
As for your 3rd party tool, I can't test its exact parameters but the above
can be a candidate to explain how to invoke commands:
$tool="ipconfig.exe"
$cmdLine = "/all"
invoke-expression "$tool $cmdLine"
Then pipe to out-null
invoke-expression "$tool $cmdLine" | out-null
Shay Levi
$cript Fanatic
> invoke-expression doesn't appear to do anything !? I've tried the
> I've tried :
> and
> Thanks Again.
> Russ
R
Hi Shay,
Even if I simplify the commandline down to the absolute minimum,
powershell doesn't even attempt to run it? is there a security issue
here maybe?
I've tested invoke-expression with a dir listing, works fine.
I've tried putting the EXE line in a BAT file and executing that, It
runs the BAT and does DOS commands within but will not run the EXE.
$Test = "dir > D:\Teamcenter\import\tmp\test.out"
invoke-expression -command "$Test"
# WORKS
Invoke-Expression -Command "D:\ren\ips
\v2007\ips_data_upload_2007_6_7_1_nti.exe"
# FAILS - Doesn't even attempt to run the EXE.
Just to reiterate the EXE does work normally via DOS.
All ideas/suggestion greatly appreciated!
Cheers
Russ
S
Shay Levi
It should run. Take the tasklist.exe for example:
invoke-expression "C:\windows\system32\tasklist.exe"
Another way is to invoke commands is with the Call operator (ampersand sign):
& "C:\windows\system32\tasklist.exe" /SVC
There is also a great blog post by Keith Hill (I recommend the whole series):
Effective PowerShell Item 10: Understanding PowerShell Parsing Modes
http://keithhill.spaces.live.com/Blog/cns!5A8D2641E0963A97!6058.entry
Shay Levi
$cript Fanatic
> Hi Shay,
> here maybe?
> # WORKS
> Cheers
> Russ
R
#8
Hi Shay.
Thanks for the responses, I've found the issue!..
I need to use invoke-item not invoke-expression.
Thanks for your help.
Cheers
Russ
