Running in multiple comps
R
Rajeev
I'm trying to find a way to run the following script in multiple
remote computers.
Move-Item c:\test\*.log d:\test
$Size = Get-Item d:\test
if ($size.length/1MB -ge 1024)
$a = Get-ChildItem "d:\test"
foreach($x in $a)
$y = ((Get-Date) - $x.LastWriteTime).Days
if ($y -ge 10 -and $x.PsISContainer -ne $True)
{$x.Delete()}
Can anyone help please. Thanks
J
Joel (Jaykul) Bennett
The best way would be using invoke-expression with the V2 CTP
bits ....
$cmd= @:
foreach($x in $a)
{$x.Delete()}
invoke-expression -computername (get-content machines.txt) -command
$cmd
B
Brandon Shell [MVP]
Use UNC paths for Computers
Something like this
foreach($comp in $computers)
Move-Item \\$comp\c$\test\*.log \\$comp\d$\test
$Size = Get-Item \\$comp\d$\test
$a = Get-ChildItem \\$comp\d$\test
foreach($x in $a)
{$x.Delete()}
Brandon Shell
Blog: http://www.bsonposh.com/
PSH Scripts Project: www.codeplex.com/psobject
R> Hi,
R>
R> I'm trying to find a way to run the following script in multiple
R> remote computers.
R>
R> Move-Item c:\test\*.log d:\test
R> $Size = Get-Item d:\test
R> if ($size.length/1MB -ge 1024)
R> {
R> $a = Get-ChildItem "d:\test"
R> foreach($x in $a)
R> {
R> $y = ((Get-Date) - $x.LastWriteTime).Days
R> if ($y -ge 10 -and $x.PsISContainer -ne $True)
R> {$x.Delete()}
R> }
R> }
R> Can anyone help please. Thanks
R>
M
Marco Shaw [MVP]
Rajeev wrote:
> Hi,
> remote computers.
> foreach($x in $a)
> {$x.Delete()}
OK, you're looking for remoting functionality so you can run a
PowerShell command from where you're sitting, and have it run on remote
machines and return the info back to you?
There is this functionality in the v2 CTP (next version of PowerShell
currently under development), but this is not meant for a production
environment.
In version 1, there isn't a real efficient/easy way to do this.
Do you have winrm installed in your environment?
Marco
Microsoft MVP - Windows PowerShell
http://www.microsoft.com/mvp
PowerGadgets MVP
http://www.powergadgets.com/mvp
Blog:
http://marcoshaw.blogspot.com
S
Shay Levi
$computers = "comp1","comp2","comp3"
$computers | foreach {
dir \\$_\c$\test\*.log | where {!$_.PsISContainer -and ($_.length -ge
1mb) -and ((Get-Date) - $_.LastWriteTime).Days -ge 10 )} | remove-item -force
-whatIf
Shay Levi
$cript Fanatic
http://scriptolog.blogspot.com
> Hi,
> remote computers.
> foreach($x in $a)
> {$x.Delete()}
J
or you could use psexec to copy over the script and ...
But for this particular script, I gotta agree with Brandon
R
Rajeev
#8
Thanks Brandon. I had a thought about that. Still wanted to check if i
could take the names from a file. This should be fine.
One more question: how will i run this script again after say 10hrs
Thanks
B
Brandon Shell [MVP]
#9
schedule tasked.
Brandon Shell
R> Thanks Brandon. I had a thought about that. Still wanted to check if
R> i could take the names from a file. This should be fine.
R>
R> One more question: how will i run this script again after say 10hrs
R>
R> Thanks
R>
R
Rajeev
#10
Thanks Shay Levi,
How would i run the same process after 10 hrs... This should
automatically run every 10 hrs.
Thanks
M
Marco Shaw [MVP]
#11
R
RichS
#12
If you need to distribute the script and\or powershell to multiple computers
have a look at the Special Operations Software Command product
Richard Siddaway
Please note that all scripts are supplied "as is" and with no warranty
Blog: http://richardsiddaway.spaces.live.com/
PowerShell User Group: http://www.get-psuguk.org.uk
"Marco Shaw [MVP]" wrote:
> Rajeev wrote:
> > Thanks Shay Levi,
> > Thanks
> You may want to review:
> http://blog.sapien.com/current/2006/12/25/more-fun-with-scheduled-powershell.html
> Like Brandon says... Use the built-in Task Scheduler.
> PowerGadgets MVP
> Blog:
