runtime error
S
sheldonj
I installed WordPerfect Office X3. Quattro Pro X3 has the runtime error-
Program: C:\Program files\WordPerfect OfficeX3\Programs\QPW.exe
abnormal program termination I have reinstalled and have started looking
through the runtime errors but there are soooo many. Is this VISTA or Corels
problem. It's mine I know but I need help. Thanks.
old dog trying to learn new tricks!
M
Mr. Arnold
"sheldonj" <sheldonj@discussions.microsoft.com> wrote in message
news:4113603B-30C6-4A6C-BA78-537E3E2F9144@microsoft.com...
> Corels
http://www.corel.com/servlet/Satellite/us/en/Content/1164926747575
S
sheldonj
I had this installed but tried it again and restarted but the results are
negative. Thanks for reminding me though I could have forgotten to add the up
date.
> > Corels
S
sheldonj
After several tries at Corel I found the answer-it required changes in regedit.
Thanks again for the help
Nelsonb
1
I found this in Corels knowledge base:
[FONT=Arial, Helvetica][/FONT]
[FONT=Arial, Helvetica]To workaround this issue:[/FONT]
  1. [FONT=Arial, Helvetica]Click Start, Programs, Accessories and Run.[/FONT]
  2. [FONT=Arial, Helvetica]In the open window, type: regedit and click OK.[/FONT]
  3. [FONT=Arial, Helvetica]Choose the following path HKEY_CURRENT_USER\Software\Corel\User Assistant\13\Recent Work\Quattro Pro\[/FONT]
  4. [FONT=Arial, Helvetica]Right click on the Quattro Pro folder, select delete.[/FONT]
  5. [FONT=Arial, Helvetica]Say yes when prompted to delete the key.[/FONT]
  6. Close the Registry Editor
  7. Launch Quattro Pro
In my case I am running version 12 instead of X3, so my key was Corel\User Assistant\12, but it works the same.
