Safe Mode
D
dualc
I am running Vista Home Basic. When I reboot and try to go to safe mode I
find that there is no F8 button to take me to the boot up menu. How do I
boot up in Safe Mode?
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
A
Andre Da Costa[ActiveWin]
Open the Run command Windows key + R
type 'msconfig' without qoutes, hit enter
Select 'Boot' tab
Under 'Boot Options' check the Safe Boot check box
Select 'Minimal' radio box or 'Network' if you need Internet Access in safe
mode
Click OK, a dialog box will appear, click OK to restart
When you want to return to 'Normal Mode' follow the same instructions above
in 'Safe Mode' but uncheck "Safe Mode" click OK then then your computer will
reboot.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog/cns!E8E5CC039D51E3DB!9709.entry
"dualc" <dualc@xxxxxx> wrote in message
news:3E69D26E-7D24-4013-A32F-8146D04E1641@xxxxxx
> I
D
dualc
"brink" wrote:
> Hi Dualc,
> The F8 key should be on your keyboard. This tutorial will show you how
> to boot into safe mode. Just select "Safe Mode" when you go to the
> "Advanced Boot Options" menu.
> http://www.vistax64.com/tutorials/88009-advanced-boot-options.html
> Hope this helps,
> Shawn
> brink
> *There are no dumb questions, just the people that do not ask them.*
> WWW.VISTAX64.COM (\"HTTP://WWW.VISTAX64.COM\")
> *Please post feedback to help others.*
Brink
The tutorial site had the answer. I of course know there is an F8 key on my
keyboard. I was hitting it, but only once and at the wrong time. I did as
the tutorial said and got the menu, and I got into safe mode.
The reason I wanted safe mode is that I have been trying to run system
restore, and I kept getting a message that it could not complete due to an
unknown error. Running is Safe Mode solved the problem. Thanks to both you
and Shawn for your imput.
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
"brink" wrote:
Brink
Dualc,
Glad to hear that you got the problem resolved. That timing to hit F8 can be tricky. Just not enough time.
Thank you for the feedback,
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
