safe to delete AppData/Local?
G
Gizzo
Is it safe to delete or change the location of AppData/Local and its
subdirectories? I'm trying to regain space in C:
Thanks
S
Synapse Syndrome
"Gizzo" <gbacareza@xxxxxx> wrote in message
news:d764adfa-2d70-4d0a-82c3-fb3c0a58517f@xxxxxx
No. That's where all your programs store their settings. Run the Disk
Cleanup Wizard and delete all but last Restore Point if you are so short of
space.
ss.
R
Richard G. Harper
No.
Richard G. Harper [MVP Shell/User] rgharper@xxxxxx
* NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/
* PLEASE post all messages and replies in the newsgroups
* The Website - http://rgharper.mvps.org/
> Thanks
R
Rainer Meier
> space.
Well, this is only partially true. The AppData\Local and
AppData\LocalLow folders are the folders where applications store their
"local machine only" settings. This means that these files are by
default not synchronized to the roaming profile share (usually only in
use for corporate users).
The AppData\Roaming folder contains the settings for the applications
(at least according to the guidelines). The AppData\Local folder should
actually only contain volatile data or data which can be re-generated
easily such as caches.
In case you use roaming profiles you sign off at one machine then the
AppData\Roaming tree is synchronized to the roaming profile share. When
you log in on another machine your profile gets pulled from the roaming
profile server. This by definition does not include the AppData\Local
folder. Therefore on this machine this folder is basically empty.
Windows will then create some default structures like Temp or Temporary
Internet Files folders automatically (empty). Applications which do not
respect the volatile nature of the AppData\Local folder do not respect
the guidelines (I usually try to avoid using such programs).
Therefore it is theoretically safe to remove all files from
AppData\Local\*\** folders. However I am quite sure you cannot delete it
entirely as Windows will complain that it needs it (at run time).
In case the OP likes to free some space he should clean
AppData\Local\Temp\* and look out for some large folders to clean up
selectively. For example Outlook tends to write the mail archive folder
there (AppData\Local\Microsoft\Outlook\Archive.pst. Just note that this
is entirely correct from my point of view. This makes the Archive local.
If I roam to another PC I don't need the archive. In case my HDD dies I
just lose the archive (ie old e-mail). As the archive is usually growing
quite fast it would be very bad to store it within the AppData\Roaming
and synchronize it to the server at each login/logoff.
br,
Rainer
G
Gizzo
> > space.
> br,
> Rainer
Thanks for all the replies. I've decided to just buy a new HD. I
backed up my entire PC. Problem is Windows Complete PC Restore can't
even find the image DVD but that should be another thread. Thanks.
