same error 0x800CCC79
weldeep
4
My error message is
The message could not be sent. The authentication setting might not be correct for your outgoing e-mail [SMTP] server. For help solving this problem, go to Help, search for "Troubleshoot Windows Mail", and read the "I'm having problems sending e-mail" section. If you need help determining the proper server settings, please contact your e-mail service provider.
The rejected e-mail address was xxx.xxx@xxx.it'. Subject 'test', Account: 'xxx', Server: 'xxx.xxx.it', Protocol: SMTP, Server Response: '550 No RDNS entry for 59.92.187.217', Port: 25, Secure(SSL): No, Server Error: 550, Error Number: 0x800CCC79
I am in India. Using 3 ISPs at different times. Same problem with all ISPs.
Searched a lot for this problem, couldn't find answer anywhere.
In the meantime, problem was solved automatically, but has again popped up now.
Email was working fine for last 1 and half yrs. All the settings are perfect. All of a sudden this started.
Pls help.
Vinay
G
Gary VanderMolen
Attempting to use an SMTP server not owned by your Internet
connection provider is usually problematical.
Use one of the following workarounds when sending away from
your home ISP:
1. Use webmail for sending (via your browser).
2. Ask your home ISP if they have a port other than '25' for SMTP.
3. If you frequently send from multiple locations, get a free Gmail
account, configure it for POP access, and use it for your sending chores.
Gary VanderMolen, MS-MVP (Mail)
"weldeep" <guest@xxxxxx-email.com> wrote in message news:65e242955f728f6deb1fed7dfabc15f9@xxxxxx-gateway.com...
> My error message is
> service provider.
> The rejected e-mail address was 'xxx.xxx@xxxxxx'' (xxx.xxx@xxxxxx).
> ISPs.
> up now.
> Pls help.
> Vinay
> weldeep
weldeep
4
Thanks Gary VanderMolen for your reply.
1. Use webmail for sending (via your browser). - I am using that already but it's nuisance to log in everytime as it automatically logs off after some time. U can't drag and drop attachments like in widows mail. all the other disadvantages which u know.
2. Ask your home ISP if they have a port other than '25' for SMTP.- I contacted them but the call center guys don't seem to be knowing what's that. i'm in india and mostly using bsnl as isp (Bharat Sanchar Nigam Ltd.)
account, configure it for POP access, and use it for your sending chores. - I survive only on sending and receiving emails.
I can't do without them. I have even configured gmail but the same problem with this as well, as written in point 1 about webmail.
pls suggest anything else could be of help. could there be something wrong with our company's email server? it's in italy.
G
Gary VanderMolen
There is nothing wrong with your mail server in Italy.
It notices you are connecting from a foreign country, so as
an anti-spam measure it makes some extra checks on the validity
of your point of origin. One of those checks fails (reverse DNS not
available for the BSNL connection).
Your objection to Gmail doesn't hold water. Gmail is not webmail only,
it also offers POP/SMTP access via your Windows Mail program:
http://mail.google.com/support/bin/answer.py?answer=86383
You can even configure the 'From' address in Gmail to be
you@xxxxxx, see
http://mail.google.com/support/bin/answer.py?hl=en&ctx=mail&answer=22370
"weldeep" <guest@xxxxxx-email.com> wrote in message news:f3cdffc5edfd9b487ab5a4176ebbb484@xxxxxx-gateway.com...
> that. i'm in india and mostly using bsnl as isp ('Bharat Sanchar Nigam
> Ltd.'
> (http://www.bsnl.co.in/faq/faqans.php?paramCategory=BSNL Broadband))
> weldeep
weldeep
4
Thanks again Gary, I was wrong about Gmail. My ignorance. I do not know as well,
how to set the Gmail account in windows mail. I tried the steps given in the link sent by you. But it configured only my gmail and not the official mail which I'm using.
I didn't understand step nos 7, and step 9 as to which email id i should type. what's Google Apps users?
My email id is different from my user id in the company's server.
for ex: user id : my.name@companyserver.it
password : xxxxx
email id : my.name@companyname.it
so when i had confirgured windows mail it was easy. but to configure windows mail, using gmail pop/smtp for my official address - is bit confusing.
hope u help me further.
thnks in adv.
Windows Mail - Gmail Help
you@xxxxxx, see
Adding a custom 'From' address - Gmail Help
> Ltd.'
> (Bharat Sanchar Nigam Ltd.))
> weldeep
G
Gary VanderMolen
First things first. Have you applied for and obtained a Gmail address?
http://mail.google.com/mail/signup
Then enter that address in Steps 7 and 9 (for the time being).
Once you get that account set up in Windows Mail, test it out to
make sure it is working properly, both sending and receiving.
Once that is done, proceed with the customization procedure per
After you complete those 9 steps, make the corresponding change
in Windows Mail. Go to Tools, Accounts, select that Gmail account,
Properties, and on the General tab change the 'E-mail address' entry
to what you just got approved through the Gmail customization process.
Your correspondents will not be aware that you are sending through
a different SMTP server because the 'From' address they see is the
same as before.
"weldeep" <guest@xxxxxx-email.com> wrote in message news:34d2634fdbc4140093a60656872bc604@xxxxxx-gateway.com...
> as well,
> for ex: user id : my.'name@xxxxxx' (my.name@xxxxxx)
> password : xxxxx
> email id : my.name@xxxxxx
> confusing.
> thnks in adv.
>> 'Windows Mail - Gmail Help'
>> (http://mail.google.com/support/bin/answer.py?answer=86383)
>> you@xxxxxx, see
>> 'Adding a custom 'From' address - Gmail Help'
>> (http://mail.google.com/support/bin/answer.py?hl=en&ctx=mail&answer=22370)
>> news:f3cdffc5edfd9b487ab5a4176ebbb484@xxxxxx-gateway.com...> > >
>> > logs
>> > what's
>> > Nigam
>> > > Ltd.'
>> > > ('Bharat Sanchar Nigam Ltd.'
>> > (http://www.bsnl.co.in/faq/faqans.php?paramCategory=BSNL Broadband)))
>> > > weldeep > >
> weldeep
weldeep
4
Thanks a lot gary,
I successfully configured gmail pop. Only thing is my emails are going as myid@gmail.com but when reply button is clicked for my email, my official email id appears, (i did that setting)
wish there was something with gmail where in the receiver should receive my email as myname@mycompany.com instead of myid@gmail.com
thanks anyway. it was of lot of help as i was having problems with this for many days now.
cheers
same as before.
> as well,
> password : xxxxx
> confusing.
> thnks in adv.
>> (Windows Mail - Gmail Help)
>> you@xxxxxx, see
>> (Adding a custom 'From' address - Gmail Help)
> weldeep
