SBS2008 Re-connect computers to domain after fresh server install
M
mrceolla
How do I reconnect computers to a domain after they have already been
connected once? The server install is fresh and unaware that the
computers were once part of the domain.
Our new HP ML350 G6 SBS 2008 server became unbootable after some HP
update. It was only a few weeks old and only a few of us tech guys
were connecting to it. We hadn't yet setup any sort of backup for
this new server so we had to reinstall and start from scratch. During
this whole downtime the computers that were connecting to it were
never restarted, the users never logged off, and outlook was never
closed in fear of loosing access to any redirected folders and cached
exchange email.
The users have been recreated on this fresh install. Outlook did not
like reconnecting. It asked us to restart and upon restart our
mailboxes were fresh and empty. We made sure to export to pst before
closing outlook so all is OK there.
Next we want to re-add or re-connect our computers to the server. The
connect program at http://connect is a possibility but I need to know
what that will do to our current profiles and/or exchange data.
During the connect program it asks if you want to transfer any
settings from existing profiles. But the list of profiles are only
local users and our domain profiles were not there. So if I choose
"none" what will happen? Will it create a fresh profile? Is there a
way I can manually add the computers and bypass the connect program?
Any advice would be greatly appreciated. Have a great day!
Mike
K
kj [SBS MVP]
Your previous profiles were under the old domain GUID/SIDS.
Even if you named the domain the same and the SBS server the same, you have
a unique domain. Your workstations will have to join anew and you'll need to
manually migrate the old domain profiles and profile data to the new domain
profiles.
> exchange email.
> Mike
/kj
M
mrceolla
Thank you for your reply.
So what should my next step be?
We haven't logged off since the first OS install died. We've
reconnected to Exchange and re-imported all of our email. We have
also reconnected to the redirected/synced folders (desktop and my
documents only).
Do we run the connect program? If so, should we select our old local
profiles or "<None>" during the process?
I would assume that we could log back into the machines as the domain
admin and then copy the profile settings from the old domain profile
to the new domain profile...or will that not be possible?
I guess basically I'm wondering the best way to manually migrate the
old domain profiles and profile data to the new domain profiles...as
you stated above.
Thank you so much,
Mike
On Oct 9, 6:55 pm, "kj [SBS MVP]" <KevinJ....@newsgroup>
> a unique domain. Your workstations will have to join anew and you'll needto
> profiles.
> > exchange email.
> > connect program athttp://connectis a possibility but I need to know
> > "none" what will happen?  Will it create a fresh profile?  Is therea
> /kj- Hide quoted text -
> - Show quoted text -
K
kj [SBS MVP]
Pretty much as you've figured. Use the admin to move data from old domain
profile to new domain profile. SBS will only migrate local profiles to
(current) SBS domain profile.
Tricky are the offline files and exchange ost data, but sounds like you have
those covered.
> documents only).
> you stated above.
> Thank you so much,
> Mike
>> you have a unique domain. Your workstations will have to join anew
>> and you'll need to manually migrate the old domain profiles and
>>> been connected once? The server install is fresh and unaware that
>>> the computers were once part of the domain.
>>> During this whole downtime the computers that were connecting to it
>>> were never restarted, the users never logged off, and outlook was
>>> never closed in fear of loosing access to any redirected folders
>>> and cached exchange email.
>>> The connect program athttp://connectis a possibility but I need to
>>> know what that will do to our current profiles and/or exchange data.
/kj
