SBS2008 / TS (RDS) Question
R
Richard K
I have a business that recently purchased a new SBS2008 Std solution. They
asked me to look at it to get my thoughts on how it was configured and how
they can effectively implement a LOB solution with remote users. They have
about 15 users in the office and another 50 remote users who need to reach
the LOB solution. I am thinking a good way to implement this for the remote
users is with Terminal Server (RDS for Server 2008/R2).
1. They purchased an OEM SBS2008 Std so in order to implement Terminal
Server they are going to need a Server 2008 license and TS (RDS) Cals for
each remote user. (TS solution to be put on another physical box and not
the SBS) Since this LOB application will be accessed by all inside and
remote users am I assuming correctly that they will need SBS2008 Cals in
addition to the TS Cals for all of these remote users?
2. Can TS cals be concurrent user based (e.g. 50 remote users but only 10
at a time using an TS session so how many cals do I need?)
If there is anything else I need to think about and look into I would
greatly appreciate pointing me in the right direction. I am good with the
SBS but not the TS (now RDS) services and how best to implement this LOB
solution.
Thanks!
-Richard K
L
Larry Struckmeyer[SBS-MVP]
Hi Richard:
The "internal users", the 15 or so that have their own desktops and play
in the LAN are (or should be) covered by their SBS User Cals... so they can
connect from their stations while at work or from RWW to their stations while
out of the office.
The SBS covers same version or older servers in the LAN so no Windows Server
CALS needed.
The "external users" will be authenticating against the SBS, so they will
need SBS CALS, and, as you pointed out, TS cals. The only question I have
is if these "external users" are unique humans connecting from unique computers.
If there is "shift work" or such, where multiple users use the same computers,
say, 50 Users and 25 Computers, then you could use 25 Device CALs. Otherwise,
50 of one or the other, probably User.
Larry
Please post the resolution to your
issue so others may benefit
Get Your SBS Health Check at
www.sbsbpa.com
> They asked me to look at it to get my thoughts on how it was
> configured and how they can effectively implement a LOB solution with
> remote users. They have about 15 users in the office and another 50
> remote users who need to reach the LOB solution. I am thinking a good
> way to implement this for the remote users is with Terminal Server
> Terminal Server they are going to need a Server 2008 license and TS
> (RDS) Cals for each remote user. (TS solution to be put on another
> physical box and not the SBS) Since this LOB application will be
> accessed by all inside and remote users am I assuming correctly that
> they will need SBS2008 Cals in addition to the TS Cals for all of
> these remote users?
> only 10 at a time using an TS session so how many cals do I need?)
> the SBS but not the TS (now RDS) services and how best to implement
> this LOB solution.
> Thanks!
> -Richard K
C
Cliff Galiher - MVP
Just to clarify, you won't need TS CALs for the internal users only *if* you
are installing the app on each internal users' local desktop.
If you choose to use RDS for both internal and remote users to simplify
managements (a reasonable choice to make) then TS CALs will be required for
internal and external users alike.
-Cliff
"Larry Struckmeyer[SBS-MVP]" <[email protected]> wrote in message
news:[email protected]
> Hi Richard:
> can connect from their stations while at work or from RWW to their
> stations while out of the office.
> Server CALS needed.
> computers. If there is "shift work" or such, where multiple users use the
> same computers, say, 50 Users and 25 Computers, then you could use 25
> Device CALs. Otherwise, 50 of one or the other, probably User.
> Larry
> www.sbsbpa.com
>> these remote users?
>> this LOB solution.
>> Thanks!
>> -Richard K
C
Charlie Russel - MVP
First, a strong recommendation to choose Server 2008 R2 for your Terminal
Server. (New name is Remote Desktop Session Host.) RDS is just better in
2008 R2, and the licensing is slightly more flexible if you have to move
licensing servers. Plus with R2 you'll get the new features coming in the
Service Pack.
You must have a separate license for each user or device that connects to
the terminal server. They need both a Server license and a TS CAL (RDS CAL
for 2008 R2, but they are interchangeable with 2008 CALs.) If they share
devices, then get device CALs. Otherwise, User CALs are easier. But each
discreet user needs their own CALs. There is no concurrent licensing here,
I'm afraid.
Charlie.
http://msmvps.com/blogs/russel
"Richard K" <[email protected]> wrote in message
news:uQZ9Hur%[email protected]
>remote users is with Terminal Server (RDS for Server 2008/R2).
> solution.
> Thanks!
> -Richard K
R
Richard K
In this case they purchased the SBS2008 Standard and not premium so they
will need to purchase 2008 Server software. I agree on the internal 15
users with them not needing a TS cal with the LOB installed on the their
desktops and they can RWW into their desktops remotely. My bigger concern
is the 50 external users. Yes I can probably make a case where those 50
external users can be consolidated into about 15 unique devices with about
3-4 users at that device so I am thinking 15 ts device cals in addition to
the 2008 server license they need to purchase.
The one last question I'm not quite understanding..... these remote users
will be authenticating against the SBS when the remote in with the 2008
server as a member server. Do I need to cover SBS cals for them as well or
are they good with the server and 15 device cals.
-Richard
> Hi Richard:
> Server CALS needed.
> Larry
> www.sbsbpa.com
>> these remote users?
>> this LOB solution.
>> Thanks!
>> -Richard K
C
Cliff Galiher - MVP
If you go TS then you will need SBS user CALs as well.
-Cliff
news:u892OTt#[email protected]
> or are they good with the server and 15 device cals.
> -Richard
> message news:[email protected]
>> Hi Richard:
>> Server CALS needed.
>> have is if these "external users" are unique humans connecting from
>> unique computers. If there is "shift work" or such, where multiple users
>> use the same computers, say, 50 Users and 25 Computers, then you could
>> use 25 Device CALs. Otherwise, 50 of one or the other, probably User.
>> Larry
>> www.sbsbpa.com
>>> these remote users?
>>> this LOB solution.
>>> Thanks!
>>> -Richard K
R
Richard K
OK, let's see if I have the numbers right
15 internal users (SBS2008 with 5 cals + 10 extra SBS std cals)
50 external users hitting the TS server via 15 unique computers (1 2008
Server, 15 TS device cals, 15 SBS device cals)
Do I have that right?
Just in case.... since these 50 external users don't have an internal
computer to RWW into I will need to go the TS route for their desktops so
they can access the LOB application. I'm thinking not but if I go the
device cal route then can each of these 50 external users have a unique SBS
login/email account on the SBS/E2k7?
Any other alternatives that I should look at?
Thanks cliff!
"Cliff Galiher - MVP" <[email protected]> wrote in message
news:#wZYCYt#[email protected]
> -Cliff
>> concern is the 50 external users. Yes I can probably make a case where
>> those 50 external users can be consolidated into about 15 unique devices
>> with about 3-4 users at that device so I am thinking 15 ts device cals in
>> addition to the 2008 server license they need to purchase.
>> -Richard
>>> Hi Richard:
>>> Server CALS needed.
>>> will need SBS CALS, and, as you pointed out, TS cals. The only question
>>> I have is if these "external users" are unique humans connecting from
>>> Larry
>>> www.sbsbpa.com
>>>> these remote users?
>>>> this LOB solution.
>>>> Thanks!
>>>> -Richard K
L
SBS as well as TS allow for Device Licenses or CALS, so speak with MS Licensing
as I described earlier.
Any advice you get here is not definitive, however well informed.
iirc, there is an upgrade from SBS 2008 standard to SBS 2008 Premium....????
http://www.microsoft.com/sbs/en/us/upgrade.aspx
Larry
www.sbsbpa.com
> they will need to purchase 2008 Server software. I agree on the
> internal 15 users with them not needing a TS cal with the LOB
> installed on the their desktops and they can RWW into their desktops
> remotely. My bigger concern is the 50 external users. Yes I can
> probably make a case where those 50 external users can be consolidated
> into about 15 unique devices with about 3-4 users at that device so I
> am thinking 15 ts device cals in addition to the 2008 server license
> users will be authenticating against the SBS when the remote in with
> the 2008 server as a member server. Do I need to cover SBS cals for
> them as well or are they good with the server and 15 device cals.
> -Richard
>> Hi Richard:
>> play in the LAN are (or should be) covered by their SBS User Cals...
>> so they can connect from their stations while at work or from RWW to
>> their stations while out of the office.
>> Server CALS needed.
>> question I have is if these "external users" are unique humans
>> connecting from unique computers. If there is "shift work" or such,
>> where multiple users use the same computers, say, 50 Users and 25
>> Computers, then you could use 25 Device CALs. Otherwise, 50 of one
>> Larry
>> www.sbsbpa.com
>>> solution. They asked me to look at it to get my thoughts on how it
>>> was configured and how they can effectively implement a LOB solution
>>> with remote users. They have about 15 users in the office and
>>> another 50 remote users who need to reach the LOB solution. I am
>>> thinking a good way to implement this for the remote users is with
>>> these remote users?
>>> would greatly appreciate pointing me in the right direction. I am
>>> good with the SBS but not the TS (now RDS) services and how best to
>>> implement this LOB solution.
>>> Thanks!
>>> -Richard K
L
Yes... the device CAL was specifically created to allow for "shift work",
where there are more users than computers.
Larry
www.sbsbpa.com
> 2008
> so they can access the LOB application. I'm thinking not but if I go
> the device cal route then can each of these 50 external users have a
> unique SBS login/email account on the SBS/E2k7?
> Thanks cliff!
>> -Cliff
>>> consolidated into about 15 unique devices with about 3-4 users at
>>> that device so I am thinking 15 ts device cals in addition to the
>>> -Richard
>>>> Hi Richard:
>>>> Cals... so they can connect from their stations while at work or
>>>> from RWW to their stations while out of the office.
>>>> Windows Server CALS needed.
>>>> they will need SBS CALS, and, as you pointed out, TS cals. The
>>>> only question I have is if these "external users" are unique humans
>>>> Larry
>>>> www.sbsbpa.com
>>>>> solution with remote users. They have about 15 users in the
>>>>> office and another 50 remote users who need to reach the LOB
>>>>> TS (RDS) Cals for each remote user. (TS solution to be put on
>>>>> another physical box and not the SBS) Since this LOB application
>>>>> will be accessed by all inside and remote users am I assuming
>>>>> correctly that they will need SBS2008 Cals in addition to the TS
>>>>> to implement this LOB solution.
>>>>> Thanks!
>>>>> -Richard K
