Scheduler - Failure to Launch problem - 2147942402
J
JerryZ
I've been using the Scheduler for several weeks and it has been working fine
with SyncToy. However, over the past few days it has stopped working on this
one application with an error message :2147942402. I have not been able to
find information on that error message anywhere. Does anyone know what this
error is?
Thank you.
Jerry
M
Mark L. Ferguson
My help can only be some info for you. Scheduler seems to have some
recurrent permissions problems. It may be that something has changed to
require the 'highest privileges'. There is a checkbox for that in the task
setup properties.
Please use the Communities guidelines when posting.
http://www.microsoft.com/wn3/locales/help/help_en-us.htm
Use the "Ratings" feature. It helps the new users.
Mark L. Ferguson MS-MVP
https://mvp.support.microsoft.com/profile/Mark.Ferguson
"JerryZ" <[email protected]> wrote in message
news:[email protected]
> fine
> this
> this
> error is?
> Thank you.
> Jerry
J
JerryZ
Hi Mark,
Not sure why, but I simply deleted the scheduled task and re-added it, and
it worked. I did have the "Highest Privileges" check box enabled when it
wasn't workin. But things are ok now. Thank you for your reply. Most
appreciated.
Jerry
> setup properties.
> > fine
> > this
> > this
> > error is?
> > Thank you.
> > Jerry
