Solved Screen flicking while opening an MP4 file
patronator
Hello,
actually i'm new to vista.. i have used n xp and win7 earlier.. jus now have installed vista home premium in my system(core 2 duo, 2.7GHz, 3GB RAM, 358MB graphics). i have a small problem after getting the new os.. i can play the usual audio/video files.. but when ever i jus click, or try to open a mp4 file, the screen starts to flicker and its like total refresh(opens all the minimised program).. this flicking happens for a while then it stops when i close the mp4 video file..
can any1 help on this prob..
Thank you..
Dinesh
    dell inspiron 1525
    core 2 du0, 2.7GHz
    intel 965 express mother board
    3068MB RAM
    358MB
    -na-
    mobile intel 965 express chipset
tom982
٩(͡๏̯͡๏)۶
Hello Dinesh and welcome to the forums :party:
Remove any 3rd party codecs you have installed, then install Shark007's codec pack:
Shark007.net - Windows Vista Codec Package
This should clear up any issues you're having :)
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
patronator
Respected,
Thank you so much for your response.. but the codec which you specified did not solve my problem.. any ways your idea sparked my bulb.. so i just tried installing k-lite mega codec in my system.. that solved my problem now.. thanks anyways..
    dell inspiron 1525
    core 2 du0, 2.7GHz
    3068MB RAM
    358MB
    -na-
tom982
٩(͡๏̯͡๏)۶
Hi Dinesh :)
Great job for fixing your problem! Thanks for taking the time to share your solution with us, I'm sure others experiencing this problem will really appreciate your efforts.
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
