Screen saver goes to black screen
T
topcat
With my new Vista Ultimate I notice after a while the screen saver is gone
and the montior is black. Any way to keep the screen saver on all the time?
Thank you. Bob
L
lforbes
Yes - Go to Control Panel - Power Options and set the options not to go to
standbye or turn off monitor.
Cheers,
Lara
> Thank you. Bob
T
topcat
Alli I see in power options are Balanced, Power Saver & Hign Perfromance.
> Cheers,
> Lara
> > Thank you. Bob
L
lforbes
Pick the one that is highlighted and click on "Change Plan Settings" written
underneath. Change the turn off Display to "Never"
Cheers,
Lara
> > Cheers,
> > Lara
> > > Thank you. Bob
T
topcat
Thank you. That worked. Bob
> Cheers,
> Lara
> > > Cheers,
> > > Lara
> > > > Thank you. Bob
