Screen turns grey and freezes (random)
Ok. Randomly, but not too often, my screen with completely turn grey and freeze that way. No choice but to do a hard reboot. I'm not sure if this is the error occurring from it, but I believe it is. If not let me know what I need to do or what information I need to provide. Thanks. The following boot-start or system-start driver(s) failed to load: i8042prt sptd
    Velocity Micro / ProMagix E2215
    Intel Core 2 Duo E6600
    Asus P5N-E SLI
    DDR2 4096MB (4 Sticks)
    GIGABYTE GeForce 9800 GTX+
    HDTV 42"
    1366 x 768
    WDC WD10 01FALS-00J7B SCSI
    931GB
    550W ?
    Velocity Micro
    Lots of Fans
    15mbps Cable: Comcast
VaguelyRapt
Electrosexual
Power User
Google finds nothing about i8042prt sptd, unfortunately..
Can you find anything in Event Viewer prior to the freezing that looks suspicious?
    HP dv5-1120ej Notebook PC
    Intel Dual 2.16GHz
    NVidia GeForce 9200M GS, 256MB
    320GB internal, 320GB external, 1TB external to come (big download library XD)
    Fast enough
    Firefox, Foobar, and AutoHotkey! Go open source!
i8042prt and sptd are seperate, below each other, forums posts delete spaces.. But yeah. Hmm, nothing else really except 'The EMS LCD-Link driver V1.0 service failed to start due to the following error: The system cannot find the file specified.' and 'The application \Device\HarddiskVolume1\Windows\System32\WUDFHost.exe with process id 2504 stopped the removal or ejection for the device USB\VID_04B0&PID_012E\000030348423.'
    Asus P5N-E SLI
    HDTV 42"
    1366 x 768
    931GB
    550W ?
    Velocity Micro
    Lots of Fans
VaguelyRapt
Electrosexual
Power User
Looks like those two are drivers that are malfunctioning. I think the first one looks more suspicious (and it seems it's some sort of driver for some usb device). Any way you can try and eliminate which usb peripherals may be causing this? (Try switching your usb keyboard, disconnect any digital cameras, etc.)
Edit: Regarding the drivers from startup, here's something you may find useful:
http://www.vistax64.com/vista-hardware-devices/70621-i8042prt.html
http://en.wikipedia.org/wiki/SPTD, http://www.chip.in/forums/viewtopic.php?f=1&t=47002, http://forums.techguy.org/all-other-software/474836-daemon-alcohol-problem.html - do you have daemon or alcohol120 installed? Try an update?
    Intel Dual 2.16GHz
    Fast enough
