Scripting.FileSystemObject with VBScript in HTML page
R
RaYlee
I am a newbie to VBScript and I am working on a web page which requires to
save some data
into directory folder. So I searched the web and found some source codes to
do it, however,
it seems the codes are not working at all.
I guess it may be guarded by the IE browser to prevent the code from
execution.
Does any expert tell me whether I should use this way to create folder and
file in file system
via html page? If possible, must I set anythings in IE browser to allow this
operation?
The source code:
<FORM NAME="Form1">
<TABLE BORDER=0 width=100%>
<TR>
<TD ALIGN="left">Click <a href="javascript:framePrint('content');">HERE</a>
to print the following contents online.</TD>
<TD ALIGN="right"><INPUT TYPE="Button" NAME="Button1" VALUE="Batch Print">
<SCRIPT FOR="Button1" EVENT="onClick" LANGUAGE="VBScript">
MsgBox "Test Starts"
Dim objFSO, objFolder
Set objFSO = CreateObject("Scripting.FileSystemObject")
MsgBox "FSO Created"
If objFSO.FolderExists(strDirectory) Then
Set objFolder = objFSO.GetFolder(strDirectory)
Else
Set objFolder = objFSO.CreateFolder(strDirectory)
End If
MsgBox "Test Completed!"
</SCRIPT>
</TD>
</TR>
</TABLE>
</FORM>
Only "Test Starts" is shown and no "FsO Created" is displayed.
Thanks for your attention and help in advance,
Raymond
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4323 (20090810) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
E
ekkehard.horner
RaYlee schrieb:
> Hi,
> save some data
> do it, however,
> execution.
> file in file system
> operation?
> The source code:
> <FORM NAME="Form1">
> <TR>
> Else
> End If
> </SCRIPT>
> </TD>
> </TR>
> </TABLE>
> </FORM>
> Raymond
> http://www.eset.com
use a .hta file instead of a .thml file. Avoid to lower the security level
of IE.
M
mr_unreliable
> save some data into directory folder. So I searched the web and found some
> source codes to do it, however, it seems the codes are not working at all.
> execution.
hi RaYlee, did you understand Ekkehardt's response? It was timely,
but a little brief.
I think what he intended to say was that you couldn't use the "fso"
object in browser (IE) code. That is because with fso you can change
and/or delete stuff on somebody's system. And if that were ever
allowed then any web page could potentially cause is serious damage...
What he suggested was to use an "HTA" application -- which is a web
page with an "HTA" extension instead of an "HTM" extension (plus an
hta tag). An HTA miniapp is not subject to the same security
restrictions as an HTM page.
cheers, jw
____________________________________________________________
You got questions? WE GOT ANSWERS!!! ..(but, no guarantee
the answers will be applicable to the questions)
T
Tim Williams
Should add that HTA is *not* a viable solution unless this is an intranet
project. You'd have to be crazy to open an HTA from an internet location.
The usual way to do this would be to have the server send the data with the
appropriate headers, and have the end-user decide what to do with it
(open/save).
Tim
"mr_unreliable" <[email protected]> wrote in message
news:[email protected]
>> to save some data into directory folder. So I searched the web and found
>> some
>> all.
>> execution.
> but a little brief.
> cheers, jw
M
mayayana
the
> (open/save).
It's designed not to work remotely at all. That's
the one restriction. A person who clicks a link
should not even be given a choice about opening
the page. They just get a "where do you want to
put it?" window. In fact, I sometimes get that even
when it's local. I don't remember why. Maybe it was
a case where I ran the HTA through other code? I'm
not sure.
M
mr_unreliable
hi RaYlee,
Here is another approach you might consider. Use an "installer".
There are all sorts of installers out there, many are free.
Most likely you will already have microsoft's own installer
(called "msi") installed on your system. Microsoft uses its
installer to upgrade your system.
An installer will do almost anything you can imagine.
For example, you can create sub-directories (er, folders)
and stuff data into those newly-created folders.
The usual webpage treatment for installer downloads would
be to post some instructions to the user, such as: "if you
want me to install this new data on your system, download
this file to your desktop and click on it... ".
cheers, jw
