Searching for content in text files with powershell
S
snofire
Hey all,
I need a powershell script that will search through all of the text files in
a directory, and copy those files that contain a given term into another
file. This is the line I am having trouble with:
Get-Content *.* | Select-String -pattern "$term" -context 20,20
-caseSensitive | Out-File E:\test.txt
With this, the script locates the terms all right, but because I had to use
context 20,20 in order to get the whole file where the term lives, it grabs a
bunch of useless data as well. Is there any way that I can just paste a file
where the term occurs?
S
Shay Levi
Hi snofire, try this:
Select-String -pattern "$term" -context 20,20 -caseSensitive -Path <path>\*.*
-list | foreach { cat $_.path | Add-Content -Path c:\matches.txt -force}
Since you copy each matched file full content to another file, I don't think
the -context 20,20 is necessary.
If you need to perform recursive search, use:
get-childitem <path> -filter <wildcard> -recurse | Select-String -pattern
"$term" ... | foreach { cat $_.path | Add-Content -Path c:\matches.txt -force}
Shay Levi
$cript Fanatic
http://scriptolog.blogspot.com
Hebrew weblog: http://blogs.microsoft.co.il/blogs/scriptfanatic
> Hey all,
> files in a directory, and copy those files that contain a given term
> into another file. This is the line I am having trouble with:
> to use context 20,20 in order to get the whole file where the term
> lives, it grabs a bunch of useless data as well. Is there any way that
> I can just paste a file where the term occurs?
S
Shay Levi
The second command should look like this: (without ... )
"$term" | foreach { cat $_.path | Add-Content -Path c:\matches.txt -force}
Shay Levi
$cript Fanatic
> <path>\*.* -list | foreach { cat $_.path | Add-Content -Path
> think
> -pattern "$term" ... | foreach { cat $_.path | Add-Content -Path
> Shay Levi
> $cript Fanatic
>> Hey all,
>> that I can just paste a file where the term occurs?
K
Kiron
Use Select-String's -Quiet switch --it returns a boolean value-- and filter the files that match with Where-Object to set their content to the new file:
set-content E:\test.txt (
get-childItem *.txt |
where {select-string $term $_ -quiet} |
get-content
Kiron
