Set-Location: Changing to user's home directory
A
Alex K. Angelopoulos [MVP]
What's the intent behind this? To me that seems a little awkward, but I may
be over-influenced by prior expectations.
You actually can get the same effect by using ~:
Set-Location ~
sl ~
dir ~
"Gantenbein" <nospam> wrote in message
news:%23ueu8wDoGHA.3424@TK2MSFTNGP02.phx.gbl...
> Would it be possible that a simple 'Set-Location' or 'cd' with no
> arguments changes to $home?
G
Gantenbein
"Alex K. Angelopoulos [MVP]" <aka@online.mvps.org> wrote in message
news:ufUb%236DoGHA.1204@TK2MSFTNGP04.phx.gbl...
> may be over-influenced by prior expectations.
I'm used to that from Unix shells like bash.
> Set-Location ~
> sl ~
> dir ~
Ok, maybe that's short enough.
A
I see - I just tried that in Cygwin and of course it works.
You should probably file this as a suggestion on the Connect site; it's
worth doing since it clearly has precedent. If you post back with the URL
for the suggestion once you make it, people can vote for it. :)
https://connect.microsoft.com
news:uItx9$DoGHA.780@TK2MSFTNGP04.phx.gbl...
>> Set-Location ~
>> sl ~
>> dir ~
K
Keith Hill [MVP]
"Gantenbein" <nospam> wrote in message news:%23ueu8wDoGHA.3424@TK2MSFTNGP02.phx.gbl...
> Would it be possible that a simple 'Set-Location' or 'cd' with no arguments
> changes to $home?
For what it's worth, this is the CD function that I use. It supports paths like "...." and is also stack based and accepts "cd -" and "cd +" to move up and down through the stack. If you execute "cd", it will display the current stack of directories:
4# cd
# Directory Stack:
0 C:\
1 C:\Documents and Settings\Keith
2 C:\Temp
3 C:\WINDOWS
-> 4 C:\WINDOWS\Assembly\GAC
You can then jump to a particular dir by number e.g. "cd -1" to cd to the directory in stack entry #1.
Keith
function GetAdminStatus {
# Does the current user had admin privileges
$adminSid = [Security.Principal.WellKnownSidType]::BuiltinAdministratorsSid
$groups = $([Security.Principal.WindowsIdentity]::GetCurrent()).Groups
foreach ($sid in $groups) {
$txSid = $sid.Translate([Security.Principal.SecurityIdentifier])
if ($txSid.IsWellKnown($adminSid)) {
return $true
return $false
# Custom CD function
[bool]$global:__isAdmin = GetAdminStatus
$global:__cd_backstack > $null
$global:__cd_forestack > $null
$global:__profileLoadCount += 1
if ($global:__profileLoadCount -eq 1) {
$global:__cd_windowTitle = "PoSH"
remove-item alias:cd -force -ea:silentlycontinue
function cd ([string]$path) {
# If more than one arg, let set-location handle this error
if ($args.Length -gt 0) {
write-error "Takes only one argument."
return
# Handle the rest of the commands plus a path arg
if ($path -eq "?") {
"Usage: cd path | command"
"Commands:"
" <no arg> : Display the directory stack"
" ~ : Change directory to your `$Home directory"
" - : Change directory to the previous directory in the stack"
" + : Change directory to the next directory in the stack"
" -number : Change directory to the specified directory in the stack"
" ..[.]* : Change directory to a parent directory of the current directory"
" ? : Display this usage information"
return
# If not created, initialize ArrayList to track directories
if ($global:__cd_backstack -eq $null) {
$global:__cd_backstack = new-object "System.Collections.ArrayList"
$global:__cd_forestack = new-object "System.Collections.ArrayList"
$curPath = $(get-location)
# Dump the directory stack
if (!$path) {
# Command to dump the back & fore stacks
" # Directory Stack:"
if ($global:__cd_backstack.Count -ge 0) {
for ($i = 0; $i -lt $global:__cd_backstack.Count; $i++) {
" {0,3} {1}" -f $i, $global:__cd_backstack[$i]
write-host ("-> {0,3} {1}" -f $i++, $curPath)
if ($global:__cd_forestack.Count -ge 0) {
$ndx = $i
for ($i = 0; $i -lt $global:__cd_forestack.Count; $i++) {
" {0,3} {1}" -f ($ndx+$i), $global:__cd_forestack[$i]
return
# Expand ..[.]+ out to ..\..[\..]+
if ($path -like "*...*") {
$regex = new-object System.Text.RegularExpressions.regex("\.\.\.")
while ($regex.ismatch($path)) {
$path = $regex.Replace($path, "..\..")
if ($path -eq "-") {
if ($global:__cd_backstack.Count -eq 0) {
write-host "`nThe backward stack is empty.`n"
else {
$lastNdx = $global:__cd_backstack.Count - 1
$prevPath = $global:__cd_backstack[$lastNdx]
set-location $prevPath
[void]$global:__cd_forestack.Insert(0, $curPath)
$global:__cd_backstack.RemoveAt($lastNdx)
elseif ($path -eq "+") {
if ($global:__cd_forestack.Count -eq 0) {
write-host "`nThe foreward stack is empty.`n"
else {
$nextPath = $global:__cd_forestack[0]
set-location $nextPath
[void]$global:__cd_backstack.Add($curPath)
$global:__cd_forestack.RemoveAt(0)
elseif ($path -like "-[0-9]*")
[int]$num = $path.replace("-","")
$backstackSize = $global:__cd_backstack.Count
$forestackSize = $global:__cd_forestack.Count
if ($num -eq $backstackSize) {
write-host "`nDude, you're already there!`n"
elseif ($num -lt $backstackSize) {
$selectedPath = $global:__cd_backstack[$num]
set-location $selectedPath
$global:__cd_backstack.RemoveAt($num)
[int]$ndx = $num
[int]$count = $global:__cd_backstack.Count - $ndx
if ($count -gt 0) {
$itemsToMove = $global:__cd_backstack.GetRange($ndx, $count)
$global:__cd_forestack.InsertRange(0, $itemsToMove)
$global:__cd_backstack.RemoveRange($ndx, $count)
elseif ($num -gt $backstackSize -and $num -lt ($backstackSize + 1 + $forestackSize)) {
[int]$ndx = $num - ($backstackSize + 1)
$selectedPath = $global:__cd_forestack[$ndx]
$global:__cd_forestack.RemoveAt($ndx)
[int]$count = $ndx
if ($count -gt 0) {
$itemsToMove = $global:__cd_forestack.GetRange(0, $count)
$global:__cd_backstack.InsertRange(($global:__cd_backstack.Count), $itemsToMove)
$global:__cd_forestack.RemoveRange(0, $count)
else {
write-host "`n$num is out of range.`n"
else
set-location $path -ea:stop
$global:__cd_forestack.Clear();
$adminStatus = ""
if ($global:__isAdmin) { $adminStatus = " #" }
$host.ui.rawui.windowTitle = $global:__cd_windowTitle + $adminStatus + " - " + $(get-location)
B
Bruce Payette [MSFT]
You can write your own cd function btw. Here's an example that is more UNIX
like. It does
cd # cd to home directory
and
cd - # cd to previous directory
You can add this function to $PROFILE
-bruce
# remove any existing cd alias...
rm -force alias:/cd 2> $null
function cd {
if ($args.Length) { $path = $args[0] } else { $path = '~' }
# .'ing shortcuts
switch ($path)
"..." { $path = "..\.." }
"...." { $path = "..\..\.." }
if (test-path variable:global:oldpath)
write-host "cd'ing back to $global:OLDPATH"
$temp = pwd
set-location $global:OLDPATH
$global:OLDPATH=$temp
else
write-host '$OLDPATH not set'
default {
$temp = pwd
set-location $path
if ($?) {
$global:OLDPATH = $temp
else
write-host "cd failed!"
Windows PowerShell Technical Lead
Microsoft Corporation
news:ucNagfEoGHA.1592@TK2MSFTNGP04.phx.gbl...
>>> Set-Location ~
>>> sl ~
>>> dir ~
