Set pc to hibernate/shutdown/logoff etc after certain time
damo76
5
hey i have a windows vista 64 bit desktop pc and i here theres no power options for the desktop pc's so is there any other way i can set my pc to hibernate/shutdown/logoff etc etc after a certain time?
thanks
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Re: Notification Area - System Icons
Hello Damo, and welcome to Vista Forums.
Desktops do not have the Power icon in the taskbar notification area only. They still have one in the Control Panel (Classic View) to adjust the power settings though. :)
Power Plan Settings - Change - Windows 7 Forums
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Correct, depending on how you set the power plan settings. :)
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
damo76
5
i have looked into the power menu on in the control button it only gives me a choice when to send it to sleep is there a way i can make it shut down in a certain time instead of to sleep? thanks again mate :)
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
You cannot through the power plan settings, but you can do so with this workaround instead: :)
Create a shut down shortcut with a delay notice so you will know when it is about to shut down the computer.
Create a task in task Scheduler to run the shut down shortcut at the time you want your computer to be shut down.
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
damo76
5
thanks brink :D that is extrmely helpful also just wondering but say if i was copying some files and i wanted to go to bed is there a way i can tell the pc to shut off when the copying had finished? if so could you explain how that would be possible thanks again :)
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
#8
Sleep or hibernation mode would be great for that type of situation. When the computer is done downloading, the computer would then go to sleep or hibernation after it sat idle for the amount of time you set in your power plan options.
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
#10
Correct, but that is just the delay notice from the shortcut after you run the shortcut before the shortcut actually shuts down the computer to give you a chance to abort it. The time you want to set is the task in Task Scheduler to run the shortcut at.
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
