Set security DACL issues
J
Jason Ferguson
I'm trying to debug a script that imports share info to recreate backup
shares, however I've run into a problem with a line of code:
PS H:\> $sd = new-object system.management.managementclass
Win32_SecurityDescriptor
PS H:\> $sd
NameSpace: ROOT\cimv2
Name Methods Properties
Win32_SecurityDescriptor {} {ControlFlags,
DACL, Group, Owner...}
PS H:\> $sd.DACL = @()
Gives the error:
Property 'DACL' cannot be found on this object; make sure it exists and is
settable.
At line:1 char:5
+ $sd. <<<< DACL = @()
+ CategoryInfo : InvalidOperation: (:) [], RuntimeException
+ FullyQualifiedErrorId : PropertyAssignmentException
Any ideas and pointers to why this is happening? I'm only two weeks into
working with powershell and am getting to grips with the basics.
C
Chris Dent
It's part of the Properties set:
$sd.Properties.DACL
HTH
Chris
Jason Ferguson wrote:
> Hi,
> PS H:\> $sd
> Gives the error:
> settable.
> At line:1 char:5
J
Jason Ferguson
Thanks Chris that makes a bit more sense but I'm still having issues working
with it.
PS H:\> $sd.properties.DACL = @()
settable.
At line:1 char:16
+ $sd.properties. <<<< DACL = @()
I suspect it's something to do with the way the original script was written.
> $sd.Properties.DACL
> HTH
> Chris
> > Hi,
> > PS H:\> $sd
> > Gives the error:
> > settable.
> > At line:1 char:5
C
Chris Dent
Hi Jason,
Apologies, it should have been $SD.Properties["DACL"]. However, if
you're creating a security descriptor you need the ManagementObject not
the ManagementClass.
Extending that with a bit of an example we end up with:
# A shortcut to create the management class
$SDClass = [WMIClass]"Win32_SecurityDescriptor"
# Create a new instance of the management object from the class.
$SD = $SDClass.CreateInstance()
# Create an Access Control Entry - shorter version of creation
$ACE = ([WMIClass]"Win32_ACE").CreateInstance()
# Create a Trustee
$Trustee = ([WMIClass]"Win32_Trustee").CreateInstance()
# Assign a username and password. Setting a SID is an alternative here.
$Trustee.Name = "someone"
$Trustee.Domain = "domain"
# Assign the trustee to the ACE
$ACE.Trustee = $Trustee
# These need values according to the rights you wish to grant
# An Allow ACE:
$ACE.AceType = [Security.AccessControl.AceType]::AccessAllowed
# Full Control:
$ACE.AccessMask = [Security.AccessControl.FileSystemRights]::FullControl
# Add the new ACE to the (currently blank) DACL
$SD.DACL = $ACE
# etc...
You're trying to create a Security Descriptor for use with the Create
method under Win32_Share?
AccessMask values are here:
http://msdn.microsoft.com/en-us/library/system.security.accesscontrol.filesystemrights.aspx
AceTypes here:
http://msdn.microsoft.com/en-us/library/system.security.accesscontrol.acetype.aspx
AceFlags aren't really relevant for shares, they tend to be nothing.
HTH
Chris
