Setting environment variables?
C
Chaz
I want to set a permanent environment variable for the currently logged on
user - as far as I can tell this would be done from the Environment Variables
dialog under the Advanced settings of the System control panel.
BUT - I'm a normal user, and can only access the Advanced Settings by
providing Admin credentials. At which point the User variables that can be
set in the dialog are for the admin account that I just authenticated with!
Is there any way I can get round this and set up persistent environment
variables as a non-admin user?
J
Jimmy Brush
Nice bug find! :)
Yes, you can get around this with the setx command.
- Open a command prompt
- Type: setx variable value
Note, that value must be enclosed in quotes if it contains any spaces.
For example,
setx MYDIR "c:\documents and settings\"
For more info on setx, check out:
http://www.ss64.com/nt/setx.html
http://technet2.microsoft.com/WindowsServer/en/Library/9e0748f8-5c67-4dc4-b8dc-11a8481d86331033.mspx
C
Chaz
Doh! Thanks for the pointer.
I hope this kind of bug gets caught over time. I'm sure there are a number
of similar instances where you can't just lock down the entire functionality
of an existing dialog box without breaking something!
Old Holborn
How to set environment variables for a non admin user
This is just a Linux fan posting the solution for
an old thread of this forum. Accept my apologies
if it has been already answered in another thread.
Google still links there, and no answer can be
posted as it is too old. :(
The how-to can be found here, as stated in the
'Microsoft Help and Support' site.
Cheers.
    Intel Pentium Dual CPU E2180 @ 2x2.00GHz
    Asus P5B-MX WIFI-AP
    4GB (2x SuperTalent T8UB2GC5)
    nVidia 8600GT (512MB DDR3)
    on-board
    Mitsubishi Diamond Plus 93SB
    WDC WD4000AAKS-00TMA0 (400GB) - internal
    WDC WD1001FALS-00J7B0 (1TB) - internal
    WDC WD400JB (40GB) - external (usb NAS)
    450W
    CoolerMaster Elite
    Compaq
    Compaq
    12798/1020 kbit/s
    Modem/Router: Fritz!BOX Fon WLAN 7140 Annex A
