SFC /scannow found two termserv.dll files it couldn't repair
R
I looked at the CBS.log and found that doing a search this has been going on
since 1/2008 and my system runs fine. I just rebooted yesterday with 1252
hours of processor idle time so I think the system is stable.
I looked at repairing the dll file from the vista disk but I think I could
learn Chinese sooner than follow all these steps to take ownership and get
the files from the disk.
Thanks for any help, Rich
T
Tae Song
What instructions did you look at?
Are you sure it's TERMSERV.DLL and not TERMSRV.DLL?
Can you post the relevant portion of your CBS.LOG
"Rich" <madeyoulook@xxxxxx> wrote in message
news:erYMZhW4JHA.1808@xxxxxx
> on since 1/2008 and my system runs fine. I just rebooted yesterday with
> 1252 hours of processor idle time so I think the system is stable.
R
"Tae Song" <tae_song@xxxxxx> wrote in message
news:2ED9D378-F22D-47DE-BA2C-7E96D075B46E@xxxxxx
>> could learn Chinese sooner than follow all these steps to take ownership
>> and get the files from the disk.
I did a search on the web and I have to install a program to extract the dll
from the massive file etc.
If you can tell me how to do this easier I would appreciate it!
Rich
Here is the pertinent part of the cbs.log:
Found: {l:32 b:eu2l0R7OF4eD0nDgwyjzEjBSdVWPi5TNwcPivgyh0HY=} Expected: {l:32
b:J9eGRMrbwRw6teDBD4VP1DvNQ7bpHB7R9tNbxQEUdwE=}
2009-05-30 14:23:47, Info CSI 00000248 [SR] Cannot
repair member file [l:22{11}]"termsrv.dll" of
Microsoft-Windows-TerminalServices-RemoteConnectionManager, Version =
6.0.6001.18000, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral,
VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type
neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2009-05-30 14:23:47, Info CSI 00000249 Hashes for file
member
\SystemRoot\WinSxS\x86_microsoft-windows-t..teconnectionmanager_31bf3856ad364e35_6.0.6001.18000_none_8e9f41c854441762\termsrv.dll
do not match actual file [l:22{11}]"termsrv.dll" :
{l:32 b:J9eGRMrbwRw6teDBD4VP1DvNQ7bpHB7R9tNbxQEUdwE=}
2009-05-30 14:23:47, Info CSI 0000024a [SR] Cannot
2009-05-30 14:23:47, Info CSI 0000024b Hashes for file
member \??\C:\Windows\System32\termsrv.dll do not match actual file
2009-05-30 14:23:47, Info CSI 0000024c Hashes for file
member
2009-05-30 14:23:47, Info CSI 0000024d [SR] Could not
reproject corrupted file
[ml:520{260},l:46{23}]"\??\C:\Windows\System32"\[l:22{11}]"termsrv.dll";
source file in store is also corrupted
T
Tae Song
news:OMES$Jf4JHA.5276@xxxxxx
>>> going on since 1/2008 and my system runs fine. I just rebooted yesterday
>>> with 1252 hours of processor idle time so I think the system is stable.
> dll from the massive file etc.
> Rich
> member
> member
You only listed one of the two files it couldn't fix. Go back and copy
paste from "Beginning Verify and Repair transaction" to the end of the
section.
It won't do you any good to copy termsrv.dll from the DVD, because it's
different version than the one that Windows thinks should be installed.
I'm guessing the file is termmgr.dll, but without missing section in the log
I could be wrong.
The version on the DVD is probably 6.0.6000.16386. The one Windows thinks
you should have is 6.0.6001.18000. Once this is fixed, Windows Update will
probably download and eventually install termsrv.dll 6.0.6002.18005.
So this what you can do...
Run regedit and run Find on:
Find all instances and export/save the entry, then delete it.
After this if you run SFC /SCANNOW, you should have only one file left to
fix.
R
news:BDB7C8E5-765F-4981-846C-329AAA70B683@xxxxxx
>>>> yesterday with 1252 hours of processor idle time so I think the system
>>>> is stable.
>>>> ownership and get the files from the disk.
>> Rich
>> file member
>> file member \??\C:\Windows\System32\termsrv.dll do not match actual file
>> file member
> section.
> log I could be wrong.
> thinks you should have is 6.0.6001.18000. Once this is fixed, Windows
> Update will probably download and eventually install termsrv.dll
> 6.0.6002.18005.
> fix.
OK I deleted that and then ran SFC and now it finds no errors!
Thanks a lot for the help, Rich
T
Tae Song
news:OpMzkki4JHA.5616@xxxxxx
>>>>> is stable.
>>> Rich
>>> file member
>>> file member
>>> not reproject corrupted file
>> section.
>> 6.0.6002.18005.
>> fix.
Guess I was wrong about the second file then. One file was creating both
problems... :\
