sfc/scannow - stops at 76 %
S
silverhair
happy new year
LapTop or Notebook
Vista Home Premium - SP 2 - 32 bit
Acer Aspire 5535 - AMD Athlon X2 Dual QL -62 2.00 GHz - 3.00 GB
Problem: sfc/scannow stops at 76 %, gives no Info just that it can not
perform the requested operation
it started when I Restored the System to Factory Install with the Discs ( 2
Discs) sent to me by Acer by mail
SP 1 is already on the Discs, all Updates installed successfully, including
SP 2
Event Viewer shows some Errors but don't know witch are associated with the
sfc/scannow
Problem Reports and Solution (reports but no solution found)
1.-
Problem signature
Problem Event Name: WindowsWcpOtherFailure3
OsVersion: 6.0.6001.18000:1
File: base\wcp\sil\merged\ntu\ntsystem.cpp
Function:Windows::Rtl::SystemImplementation::DirectFileSystemProvider::SysReadFileLine: 1920
Status: c0000011
StackHash: 0x563c8df4
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
2.-
Extra information about the problem
Bucket ID: 182505946
Problem signature
Problem Event Name: CbsPackageServicingFailure
Stack Version: 6.0.6001.18000
Package: Package_for_KB973687~31bf3856ad364e35~x86~~6.0.1.1
Status: 80070026
Failure Source: Execute
Start State: Resolved
Target State: Installed
Locale ID: 1033
Bucket ID: 769551469
I suspect that its related to the CBsPackageServicingFailure or both or more
don't know where to go from here
would really like to get sfc/scannow working
Email with Acer America this Computer is still under Factory Warranty don't
know what it covers, but they DON'T want me to return it to Store in
Winnipeg where I purchased it
don't know if I been screwed, this computer (LapTop) does Not have a
Recovery partition, it has 1 disc C and 1 partition 232 GB
(my Emachine Home Basic Desktop did have a Recovery Partition on D)
the Store made me set, 2 Discs after I complained and Acer sent me a set, 3
Discs after some Emails
already been at the store they are slick and have few answers , don't think
I'll get far at the store
any help with getting the sfc/scannow is much appreciated
fritz
On Thu, 31 Dec 2009 12:51:07 -0600, "silverhair"
<sinnhick@newsgroup> wrote:
>happy new year
>LapTop or Notebook
Restore or recovery disks ? Is there not a hidden partition to factory
install ?
>SP 2
>sfc/scannow
>1.-
>Problem signature
>Status: c0000011
>Locale ID: 1033
>2.-
>Problem signature
>Status: 80070026
>Locale ID: 1033
>fritz
S
silverhair
"Jim" <bojimbo261@newsgroup> wrote in message
news:2u5qj5d06qb5kie02p9mko201v2pju21t9@newsgroup
>>happy new year
>>LapTop or Notebook
>>not
>>( 2
> install ?
Thanks for the reply
sorry Recovery Disks
recover to factory install, all and everything is Reloaded
(including all Oberon Media that all most fills half the computer, I don't
get to chose what programs to reinstall)
hidden partition ?
all I see in disk management: Acer (C:) Simple Basic NFTS Healthy Primary
Partition, capacity 232.88 GB free 188.42 used 44.4 GB
Disk 0 Basic 232.88 GB Online
and CD_ROM 0 DVD (D:)
same under computer
Where Would I look for hidden partition?
>>including
>>SP 2
>>the
>>sfc/scannow
>>1.-
>>Problem signature
>>1920
>>Status: c0000011
>>Locale ID: 1033
>>2.-
>>Problem signature
>>Status: 80070026
>>Locale ID: 1033
>>more
>>don't
>>3
>>think
>>fritz
G
Guest
Type in a command prompt and see if the last line give clues
findstr /c:"[SR]" %windir%\logs\cbs\cbs.log |more
"silverhair" <sinnhick@newsgroup> wrote in message
news:4EA3296A-27F1-48A1-A786-FA7C2E27DA44@newsgroup
>>>happy new year
>>>LapTop or Notebook
>>>not
>>>( 2
>> install ?
> hidden partition ?
> Primary Partition, capacity 232.88 GB free 188.42 used 44.4 GB
> same under computer
>>>including
>>>SP 2
>>>the
>>>sfc/scannow
>>>1.-
>>>Problem signature
>>>1920
>>>Status: c0000011
>>>Locale ID: 1033
>>>2.-
>>>Problem signature
>>>Status: 80070026
>>>Locale ID: 1033
>>>more
>>>don't
>>>set, 3
>>>think
>>>fritz
S
silverhair
thanks
cbs logs after a long long list of CBS sessions and read outs
the LAST line reads:
>>>>>>>Scavenge: Package store indicates there is no component to scavenge,
>>>>>>>skipping<<<<<<<<
I found in Event Viewer on Audit Failure Event ID 5038
Code Integrity determined that the Image of a file is not valid. The file
could be corrupt due to unauthorized modification or the invalid hash could
indicate a potential disk device error.
If the Acer Arcade may be the problem I will remove it quickly
may be I should have the Disk checked
error info:
- System
- Provider
[ Name] Microsoft-Windows-Security-Auditing
[ Guid] {54849625-5478-4994-a5ba-3e3b0328c30d}
EventID 5038
Version 0
Level 0
Task 12290
Opcode 0
Keywords 0x8010000000000000
- TimeCreated
[ SystemTime] 2009-12-31T22:21:30.434Z
EventRecordID 4213
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 56
Channel Security
Computer fritz-PC
Security
- EventData
param1 \Device\HarddiskVolume1\Program Files\Acer Arcade
Deluxe\HomeMedia\Kernel\DMP\NTIPPKernel.sys
If Acer Arcade May be the Problem , I will quickly Remove it
fritz
<.> wrote in message news:u5$4T7niKHA.4048@newsgroup
>>>>happy new year
>>>>LapTop or Notebook
>>>>not
>>>>( 2
>>> install ?
>> don't get to chose what programs to reinstall)
>> hidden partition ?
>> same under computer
>>>>including
>>>>SP 2
>>>>the
>>>>sfc/scannow
>>>>1.-
>>>>Problem signature
>>>>1920
>>>>Status: c0000011
>>>>Locale ID: 1033
>>>>2.-
>>>>Problem signature
>>>>Status: 80070026
>>>>Locale ID: 1033
>>>>more
>>>>don't
>>>>set, 3
>>>>think
>>>>fritz
G
Guest
Scavenge is where uninstalled files are removed.
What happened when you removed Acer?
news:6F141BF6-DB19-4F97-A046-CD5C5A6C96B4@newsgroup
> thanks
>>>>>>>>skipping<<<<<<<<
> could indicate a potential disk device error.
> error info:
> - System
> - Provider
> EventID 5038
> Version 0
> Level 0
> Task 12290
> Opcode 0
> - TimeCreated
> EventRecordID 4213
> Correlation
> - Execution
> [ ProcessID] 4
> [ ThreadID] 56
> Channel Security
> Computer fritz-PC
> Security
> - EventData
> fritz
>>>>>happy new year
>>>>>LapTop or Notebook
>>>>>can not
>>>>>Discs ( 2
>>>> install ?
>>> hidden partition ?
>>> same under computer
>>>>>including
>>>>>SP 2
>>>>>the
>>>>>sfc/scannow
>>>>>1.-
>>>>>Problem signature
>>>>>1920
>>>>>Status: c0000011
>>>>>Locale ID: 1033
>>>>>2.-
>>>>>Problem signature
>>>>>Status: 80070026
>>>>>Locale ID: 1033
>>>>>more
>>>>>don't
>>>>>set, 3
>>>>>think
>>>>>fritz
S
silverhair
fritz
thanks you all,
sfc/scannow still stops at 76 %
Windows Resource Protection could not perform the requested operation,
now it shows Errors, but I have no clue what to do with them.
hope you don't object for having pasted the logs here.
POQ 58 ends.
2010-01-01 16:14:31, Info CSI 0000013d [SR] Verify
complete
2010-01-01 16:14:32, Info CSI 0000013e [SR] Verifying
100 (0x00000064) components
2010-01-01 16:14:32, Info CSI 0000013f [SR] Beginning
Verify and Repair transaction
2010-01-01 16:14:36, Info CSI 00000140 Hashes for file
member
\SystemRoot\WinSxS\x86_microsoft-windows-sidebar_31bf3856ad364e35_6.0.6002.18005_none_d0c824c923c9e622\settings.ini
do not match actual file [l:24{12}]"settings.ini" :
Found: {l:32 b:Qt6PBWgxFudPGuq3ZCTACwMbO+VhNx7YnXChhtFvbxw=} Expected:
{l:32 b:v6OQf2AJO5FVbRBJuIwXxkdkCoOaSk3y0ol6uTH491o=}
2010-01-01 16:14:36, Info CSI 00000141 [SR] Cannot
repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar,
Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture
neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35},
Type neutral, TypeName neutral, PublicKey neutral in the store, hash
mismatch
2010-01-01 16:14:38, Info CSI 00000142 Hashes for file
member
2010-01-01 16:14:38, Info CSI 00000143 [SR] Cannot
mismatch
2010-01-01 16:14:38, Info CSI 00000144 [SR] This
component was referenced by
[l:158{79}]"Package_16_for_KB948465~31bf3856ad364e35~x86~~6.0.1.18005.948465-49_neutral_GDR"
2010-01-01 16:14:43, Error CSI 00000145 (F) c0000280
[Error,Facility=(system),Code=640 (0x0280)] #3021297# from
Windows::Rtl::SystemImplementation::DirectFileSystemProvider::SysCreateFile(flags
= (AllowFileNotFound|AllowSharingViolation), handle = {provider=NULL,
handle=0}, da = (SYNCHRONIZE|FILE_READ_ATTRIBUTES), oa =
@0xffe224->OBJECT_ATTRIBUTES {s:24; rd:NULL;
on:[27]"\??\C:\Users\Default\Videos"; a:(OBJ_CASE_INSENSITIVE)}, iosb =
@0xffe1dc, as = (null), fa = 0, sa =
(FILE_SHARE_READ|FILE_SHARE_WRITE|FILE_SHARE_DELETE), cd = FILE_OPEN, co =
(FILE_DIRECTORY_FILE|FILE_SYNCHRONOUS_IO_NONALERT|0x00004000), eab = NULL,
eal = 0, disp = Invalid)
[gle=0xd0000280]
00000146@newsgroup/1/1:22:14:43.268 (F)
d:\longhorn\base\wcp\sil\merged\ntu\ntsystem.cpp(1849): Error c0000280
[Error,Facility=(system),Code=640 (0x0280)] originated in function
expression: (null)
[gle=0x80004005]
2010-01-01 16:14:50, Error CSI 00000147 (F) c0000280
[Error,Facility=(system),Code=640 (0x0280)] #3021296# from
Windows::Rtl::SystemImplementation::CDirectory::OpenExistingDirectory(...)[gle=0xd0000280]
2010-01-01 16:14:50, Error CSI 00000148 (F) c0000280
[Error,Facility=(system),Code=640 (0x0280)] #3021295# from
Windows::Rtl::SystemImplementation::CDirectory_IRtlDirectoryTearoff::OpenExistingDirectory(flags
= (DirectoryMissingIsOk|SharingViolationIsOk), da = (SYNCHRONIZE), oa =
@0xffe39c->SIL_OBJECT_ATTRIBUTES {s:20; on:"Videos";
a:(OBJ_CASE_INSENSITIVE)}, sa =
(FILE_SHARE_READ|FILE_SHARE_WRITE|FILE_SHARE_DELETE), oo =
(FILE_DIRECTORY_FILE|FILE_SYNCHRONOUS_IO_NONALERT|FILE_OPEN_FOR_BACKUP_INTENT),
dir = NULL, disp = Invalid)
[gle=0xd0000280]
2010-01-01 16:14:50, Error CSI 00000149 (F) c0000280
[Error,Facility=(system),Code=640 (0x0280)] #3020888# from
CFileInstaller::CommitChanges(...)[gle=0xd0000280]
2010-01-01 16:14:50, Error CSI 0000014a (F) c0000280
[Error,Facility=(system),Code=640 (0x0280)] #3020887# from
PrimitiveInstaller::CCoordinator::FinalizeChanges(...)[gle=0xd0000280]
2010-01-01 16:18:37, Info CBS Scavenge: Package store
indicates there is no component to scavenge, skipping.
<.> wrote in message news:O45d6TyiKHA.1540@newsgroup
>> thanks
>>>>>>>>>scavenge, skipping<<<<<<<<
>> error info:
>> - System
>> - Provider
>> EventID 5038
>> Version 0
>> Level 0
>> Task 12290
>> Opcode 0
>> - TimeCreated
>> EventRecordID 4213
>> Correlation
>> - Execution
>> [ ProcessID] 4
>> [ ThreadID] 56
>> Channel Security
>> Computer fritz-PC
>> Security
>> - EventData
>> fritz
>>>>>>happy new year
>>>>>>LapTop or Notebook
>>>>>>can not
>>>>>>Discs ( 2
>>>>> install ?
>>>> hidden partition ?
>>>> same under computer
>>>>>>including
>>>>>>SP 2
>>>>>>with the
>>>>>>sfc/scannow
>>>>>>1.-
>>>>>>Problem signature
>>>>>>1920
>>>>>>Status: c0000011
>>>>>>Locale ID: 1033
>>>>>>2.-
>>>>>>Problem signature
>>>>>>Status: 80070026
>>>>>>Locale ID: 1033
>>>>>>or more
>>>>>>don't
>>>>>>set, 3
>>>>>>think
>>>>>>fritz
G
Guest
#8
Forget anything applying to setting.ini as it a file one writes changes to.
The only error I saw in there is below
// MessageId: STATUS_REPARSE_POINT_NOT_RESOLVED
// MessageText:
// The NTFS symbolic link could not be resolved even though the initial file
name is valid.
#define STATUS_REPARSE_POINT_NOT_RESOLVED ((NTSTATUS)0xC0000280L)
news:26670E26-EC29-4F49-A4D1-863464B9A6B5@newsgroup
> fritz
> thanks you all,
> POQ 58 ends.
> complete
> member
> b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in
> the store, hash mismatch
> member
> [gle=0xd0000280]
> expression: (null)
> [gle=0x80004005]
> [gle=0xd0000280]
>>> thanks
>>> file could be corrupt due to unauthorized modification or the invalid
>>> hash could indicate a potential disk device error.
>>> error info:
>>> - System
>>> - Provider
>>> EventID 5038
>>> Version 0
>>> Level 0
>>> Task 12290
>>> Opcode 0
>>> - TimeCreated
>>> EventRecordID 4213
>>> Correlation
>>> - Execution
>>> [ ProcessID] 4
>>> [ ThreadID] 56
>>> Channel Security
>>> Computer fritz-PC
>>> Security
>>> - EventData
>>> fritz
>>>>>>>happy new year
>>>>>>>LapTop or Notebook
>>>>>>>can not
>>>>>>>Discs ( 2
>>>>>> factory
>>>>>> install ?
>>>>> hidden partition ?
>>>>> same under computer
>>>>>>>including
>>>>>>>SP 2
>>>>>>>with the
>>>>>>>sfc/scannow
>>>>>>>1.-
>>>>>>>Problem signature
>>>>>>>1920
>>>>>>>Status: c0000011
>>>>>>>Locale ID: 1033
>>>>>>>2.-
>>>>>>>Problem signature
>>>>>>>Status: 80070026
>>>>>>>Locale ID: 1033
>>>>>>>or more
>>>>>>>don't
>>>>>>>set, 3
>>>>>>>don't think
>>>>>>>fritz
G
Guest
#9
Did you type what I said. Weonly want lines that have "SR Cannot"
> fritz
> thanks you all,
> POQ 58 ends.
> complete
> member
> member
> [gle=0xd0000280]
> expression: (null)
> [gle=0x80004005]
> [gle=0xd0000280]
>>> thanks
>>> error info:
>>> - System
>>> - Provider
>>> EventID 5038
>>> Version 0
>>> Level 0
>>> Task 12290
>>> Opcode 0
>>> - TimeCreated
>>> EventRecordID 4213
>>> Correlation
>>> - Execution
>>> [ ProcessID] 4
>>> [ ThreadID] 56
>>> Channel Security
>>> Computer fritz-PC
>>> Security
>>> - EventData
>>> fritz
>>>>>>>happy new year
>>>>>>>LapTop or Notebook
>>>>>>>can not
>>>>>>>Discs ( 2
>>>>>> factory
>>>>>> install ?
>>>>> hidden partition ?
>>>>> same under computer
>>>>>>>including
>>>>>>>SP 2
>>>>>>>with the
>>>>>>>sfc/scannow
>>>>>>>1.-
>>>>>>>Problem signature
>>>>>>>1920
>>>>>>>Status: c0000011
>>>>>>>Locale ID: 1033
>>>>>>>2.-
>>>>>>>Problem signature
>>>>>>>Status: 80070026
>>>>>>>Locale ID: 1033
>>>>>>>or more
>>>>>>>don't
>>>>>>>set, 3
>>>>>>>don't think
>>>>>>>fritz
S
silverhair
#10
sorry I have tried that line many many times you gave me but with no
result
I'll check that long list for "[SR]" lines will see what I find
fritz
<.> wrote in message news:Ok6nf2ziKHA.2780@newsgroup
>> fritz
>> thanks you all,
>> POQ 58 ends.
>> complete
>> file member
>> file member
>> = (FILE_DIRECTORY_FILE|FILE_SYNCHRONOUS_IO_NONALERT|0x00004000), eab =
>> NULL, eal = 0, disp = Invalid)
>> [gle=0xd0000280]
>> expression: (null)
>> [gle=0x80004005]
>> [gle=0xd0000280]
>>>> thanks
>>>> error info:
>>>> - System
>>>> - Provider
>>>> EventID 5038
>>>> Version 0
>>>> Level 0
>>>> Task 12290
>>>> Opcode 0
>>>> - TimeCreated
>>>> EventRecordID 4213
>>>> Correlation
>>>> - Execution
>>>> [ ProcessID] 4
>>>> [ ThreadID] 56
>>>> Channel Security
>>>> Computer fritz-PC
>>>> Security
>>>> - EventData
>>>> fritz
>>>>>>>>happy new year
>>>>>>>>LapTop or Notebook
>>>>>>>>can not
>>>>>>>>Discs ( 2
>>>>>>> factory
>>>>>>> install ?
>>>>>> hidden partition ?
>>>>>> same under computer
>>>>>>>>including
>>>>>>>>SP 2
>>>>>>>>with the
>>>>>>>>sfc/scannow
>>>>>>>>1.-
>>>>>>>>Problem signature
>>>>>>>>1920
>>>>>>>>Status: c0000011
>>>>>>>>Locale ID: 1033
>>>>>>>>2.-
>>>>>>>>Problem signature
>>>>>>>>Status: 80070026
>>>>>>>>Locale ID: 1033
>>>>>>>>or more
>>>>>>>>Warranty don't
>>>>>>>>in
>>>>>>>>a set, 3
>>>>>>>>don't think
>>>>>>>>fritz
G
Guest
#11
There is an old log file in the same directory. CBS.Persist.Log. Entries go
from cbs.log to cbs.persist.log. Try the other log file.
news:721F0775-DE68-49DD-8644-597B09DED7A4@newsgroup
> result
> fritz
>>> fritz
>>> thanks you all,
>>> POQ 58 ends.
>>> complete
>>> Verifying 100 (0x00000064) components
>>> Beginning Verify and Repair transaction
>>> file member
>>> Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA =
>>> PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1
>>> nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral,
>>> TypeName neutral, PublicKey neutral in the store, hash mismatch
>>> file member
>>> [gle=0xd0000280]
>>> expression: (null)
>>> [gle=0x80004005]
>>> [gle=0xd0000280]
>>> store indicates there is no component to scavenge, skipping.
>>>>> thanks
>>>>> error info:
>>>>> - System
>>>>> - Provider
>>>>> EventID 5038
>>>>> Version 0
>>>>> Level 0
>>>>> Task 12290
>>>>> Opcode 0
>>>>> - TimeCreated
>>>>> EventRecordID 4213
>>>>> Correlation
>>>>> - Execution
>>>>> [ ProcessID] 4
>>>>> [ ThreadID] 56
>>>>> Channel Security
>>>>> Computer fritz-PC
>>>>> Security
>>>>> - EventData
>>>>> fritz
>>>>>>>>>happy new year
>>>>>>>>>LapTop or Notebook
>>>>>>>>>it can not
>>>>>>>>>Discs ( 2
>>>>>>>> factory
>>>>>>>> install ?
>>>>>>> hidden partition ?
>>>>>>> same under computer
>>>>>>>>>including
>>>>>>>>>SP 2
>>>>>>>>>with the
>>>>>>>>>sfc/scannow
>>>>>>>>>1.-
>>>>>>>>>Problem signature
>>>>>>>>>1920
>>>>>>>>>Status: c0000011
>>>>>>>>>Locale ID: 1033
>>>>>>>>>2.-
>>>>>>>>>Problem signature
>>>>>>>>>Status: 80070026
>>>>>>>>>Locale ID: 1033
>>>>>>>>>both or more
>>>>>>>>>Warranty don't
>>>>>>>>>in
>>>>>>>>>a
>>>>>>>>>D)
>>>>>>>>>a set, 3
>>>>>>>>>don't think
>>>>>>>>>fritz
S
silverhair
#12
wow
in the command prompt after I hit enter it showed NOTHING
then I right clicked on my line in Command Prompt
then, select all, come here and paste, and it shows here, didn't know
this,
but you already seen this , so it changes nothing
CSI 00000141 [SR] Cannot repair member file
[l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version =
6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral,
VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type
neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
> result
> fritz
>>> fritz
>>> thanks you all,
>>> POQ 58 ends.
>>> complete
>>> file member
>>> file member
>>> [gle=0xd0000280]
>>> expression: (null)
>>> [gle=0x80004005]
>>> [gle=0xd0000280]
>>>>> thanks
>>>>> error info:
>>>>> - System
>>>>> - Provider
>>>>> EventID 5038
>>>>> Version 0
>>>>> Level 0
>>>>> Task 12290
>>>>> Opcode 0
>>>>> - TimeCreated
>>>>> EventRecordID 4213
>>>>> Correlation
>>>>> - Execution
>>>>> [ ProcessID] 4
>>>>> [ ThreadID] 56
>>>>> Channel Security
>>>>> Computer fritz-PC
>>>>> Security
>>>>> - EventData
>>>>> fritz
>>>>>>>>>happy new year
>>>>>>>>>LapTop or Notebook
>>>>>>>>>it can not
>>>>>>>>>Discs ( 2
>>>>>>>> factory
>>>>>>>> install ?
>>>>>>> hidden partition ?
>>>>>>> same under computer
>>>>>>>>>including
>>>>>>>>>SP 2
>>>>>>>>>with the
>>>>>>>>>sfc/scannow
>>>>>>>>>1.-
>>>>>>>>>Problem signature
>>>>>>>>>1920
>>>>>>>>>Status: c0000011
>>>>>>>>>Locale ID: 1033
>>>>>>>>>2.-
>>>>>>>>>Problem signature
>>>>>>>>>Status: 80070026
>>>>>>>>>Locale ID: 1033
>>>>>>>>>both or more
>>>>>>>>>Warranty don't
>>>>>>>>>in
>>>>>>>>>a
>>>>>>>>>D)
>>>>>>>>>a set, 3
>>>>>>>>>don't think
>>>>>>>>>fritz
S
silverhair
#13
hello
thanks for your effort, guess this is the end of this
would it help if I removed the side bar ? don't use it much, but is nice to
have, so I can see how cold it is, its - 30 c. here,
the problem started in that gap
the CBS.persist logs start 2008-02-05 to 2008-08-19
then nothing , till 2009-12-29 to 2009-12-30
date of purchase 2009-05
fritz
news:44714AF8-6A27-4B47-9ECB-FD5056EFCA2D@newsgroup
> wow
> this,
>> result
>> fritz
>>>> fritz
>>>> thanks you all,
>>>> POQ 58 ends.
>>>> complete
>>>> file member
>>>> file member
>>>> co = (FILE_DIRECTORY_FILE|FILE_SYNCHRONOUS_IO_NONALERT|0x00004000), eab
>>>> = NULL, eal = 0, disp = Invalid)
>>>> [gle=0xd0000280]
>>>> expression: (null)
>>>> [gle=0x80004005]
>>>> [gle=0xd0000280]
>>>>>> thanks
>>>>>> error info:
>>>>>> - System
>>>>>> - Provider
>>>>>> EventID 5038
>>>>>> Version 0
>>>>>> Level 0
>>>>>> Task 12290
>>>>>> Opcode 0
>>>>>> - TimeCreated
>>>>>> EventRecordID 4213
>>>>>> Correlation
>>>>>> - Execution
>>>>>> [ ProcessID] 4
>>>>>> [ ThreadID] 56
>>>>>> Channel Security
>>>>>> Computer fritz-PC
>>>>>> Security
>>>>>> - EventData
>>>>>> fritz
>>>>>>>>>>happy new year
>>>>>>>>>>LapTop or Notebook
>>>>>>>>>>GB
>>>>>>>>>>it can not
>>>>>>>>>>Discs ( 2
>>>>>>>>> factory
>>>>>>>>> install ?
>>>>>>>> I don't get to chose what programs to reinstall)
>>>>>>>> hidden partition ?
>>>>>>>> same under computer
>>>>>>>>>>including
>>>>>>>>>>SP 2
>>>>>>>>>>with the
>>>>>>>>>>sfc/scannow
>>>>>>>>>>1.-
>>>>>>>>>>Problem signature
>>>>>>>>>>1920
>>>>>>>>>>Status: c0000011
>>>>>>>>>>Locale ID: 1033
>>>>>>>>>>2.-
>>>>>>>>>>Problem signature
>>>>>>>>>>Status: 80070026
>>>>>>>>>>Locale ID: 1033
>>>>>>>>>>both or more
>>>>>>>>>>Warranty don't
>>>>>>>>>>in
>>>>>>>>>>a
>>>>>>>>>>D)
>>>>>>>>>>me a set, 3
>>>>>>>>>>don't think
>>>>>>>>>>fritz
G
Guest
#14
It's a hot 30 degrees celsius here, and humid. Is there a reason for running
sfc?
news:648A4F9C-097F-4A46-A474-C7753CA736E5@newsgroup
> hello
> to have, so I can see how cold it is, its - 30 c. here,
> fritz
>> wow
>> this,
>>> result
>>> fritz
>>>>> fritz
>>>>> thanks you all,
>>>>> POQ 58 ends.
>>>>> complete
>>>>> file member
>>>>> Expected: {l:32 b:v6OQf2AJO5FVbRBJuIwXxkdkCoOaSk3y0ol6uTH491o=}
>>>>> file member
>>>>> c0000280 [Error,Facility=(system),Code=640 (0x0280)] #3021297# from
>>>>> = @0xffe1dc, as = (null), fa = 0, sa =
>>>>> eab = NULL, eal = 0, disp = Invalid)
>>>>> [gle=0xd0000280]
>>>>> expression: (null)
>>>>> [gle=0x80004005]
>>>>> c0000280 [Error,Facility=(system),Code=640 (0x0280)] #3021296# from
>>>>> c0000280 [Error,Facility=(system),Code=640 (0x0280)] #3021295# from
>>>>> = @0xffe39c->SIL_OBJECT_ATTRIBUTES {s:20; on:"Videos";
>>>>> [gle=0xd0000280]
>>>>> c0000280 [Error,Facility=(system),Code=640 (0x0280)] #3020888# from
>>>>> c0000280 [Error,Facility=(system),Code=640 (0x0280)] #3020887# from
>>>>>>> thanks
>>>>>>> invalid hash could indicate a potential disk device error.
>>>>>>> error info:
>>>>>>> - System
>>>>>>> - Provider
>>>>>>> EventID 5038
>>>>>>> Version 0
>>>>>>> Level 0
>>>>>>> Task 12290
>>>>>>> Opcode 0
>>>>>>> - TimeCreated
>>>>>>> EventRecordID 4213
>>>>>>> Correlation
>>>>>>> - Execution
>>>>>>> [ ProcessID] 4
>>>>>>> [ ThreadID] 56
>>>>>>> Channel Security
>>>>>>> Computer fritz-PC
>>>>>>> Security
>>>>>>> - EventData
>>>>>>> fritz
>>>>>>>>>>>happy new year
>>>>>>>>>>>LapTop or Notebook
>>>>>>>>>>>GB
>>>>>>>>>>>it can not
>>>>>>>>>>>the Discs ( 2
>>>>>>>>>> factory
>>>>>>>>>> install ?
>>>>>>>>> hidden partition ?
>>>>>>>>> Healthy Primary Partition, capacity 232.88 GB free 188.42 used
>>>>>>>>> 44.4 GB
>>>>>>>>> same under computer
>>>>>>>>>>>including
>>>>>>>>>>>SP 2
>>>>>>>>>>>associated with the
>>>>>>>>>>>sfc/scannow
>>>>>>>>>>>1.-
>>>>>>>>>>>Problem signature
>>>>>>>>>>>1920
>>>>>>>>>>>Status: c0000011
>>>>>>>>>>>Locale ID: 1033
>>>>>>>>>>>2.-
>>>>>>>>>>>Problem signature
>>>>>>>>>>>Status: 80070026
>>>>>>>>>>>Locale ID: 1033
>>>>>>>>>>>both or more
>>>>>>>>>>>Warranty don't
>>>>>>>>>>>Store in
>>>>>>>>>>>have a
>>>>>>>>>>>D)
>>>>>>>>>>>me a set, 3
>>>>>>>>>>>don't think
>>>>>>>>>>>fritz
