SHUTDOWN
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
D
Dwarf
Hi Greg,
Firstly, please don't use all capitals. This is considered to be shouting,
and some people will not respond to a post that is in all capitals. Use
capitals only when you need to emphasise something.
To change the action of the default shutdown option on the start menu, do
the following. Open 'Control Panel', 'Hardware and sound', 'Power options'.
Click 'Change plan settings' under the selected option. Click 'Change
advanced power settings'. Expand the 'Power buttons and lid' option. Open the
'Start menu power button'. The current option is usually 'Sleep', but if you
click on this, you can change it to what you like from 'Sleep', 'Hibernate'
and 'Shut down'. As 'Shut down' is the option you require, select that. Click
'OK' and close all other windows. If you click on your start menu, you will
find the shutdown option is now what you require.
Dwarf
"GREG" wrote:
> HOW CAN I SET THE SHUTDOWN OPTION WINDOW TO ALWAYS SELECT "SHUTDOWN" AS THE
> DEFAULT
S
Stubbo of Oz
On Wed, 6 Feb 2008 12:02:01 -0800, Dwarf
<Dwarf@xxxxxx> wrote:
>Hi Greg,
>Dwarf
Thanks Dwarf - I have always wanted to be able to do that!!!
Stubbo of Sydney
