side by side error
Status
Not open for further replies.
N
I am recieving the same error when I try to open both Windows Media Player
and Windows Photo Gallery. This error has only occured in the past month when
I first started using Vista both programs worked great now I get the
following error :
The application has failed to start because its side-by-side configuration
is incorrect. Please see the application event log for more detail.
In the event log there is nothing any help on how to fix this problem would
be greatly appreciated.
R
Ronnie Vernon MVP
Nora
The "side-by-side" component is associated with the Vista Windows Resource
Protection (WRP). You may have a corrupted file in the SxS folder.
To resolve this issue, use the System File Checker tool (SFC.exe) to repair
these files.
To do this, follow these steps:
1. Open an elevated command prompt. To do this, click Start, click All
Programs, click Accessories, right-click Command Prompt, and then click Run
as administrator. If you are prompted for an administrator password or for a
confirmation, type the password, or click Allow/Continue.
2. Type the following command, and then press ENTER:
sfc /scannow
(The sfc /scannow command scans all protected system files and replaces
incorrect versions with correct Microsoft versions.)
This may take some time to run, so be patient.
Let us know the results.
Ronnie Vernon
Microsoft MVP
Windows Shell/User
"Nora" <Nora@xxxxxx> wrote in message
news:CACA5F62-722D-49E0-9AB4-1957922D71C6@xxxxxx
> when
> following error :
> would
N
Okay I tried to do the sfc scan it began the verification phase got to 43%
then it says windows resource protection could not perform the requested
operation. I tried it a couple more times just to see if it would work and it
still comes up with that it can't perform the requested operation. Any
suggestions on how to fix that or any other suggestions on how to fix the
problem would be greatly appreciated.
"Ronnie Vernon MVP" wrote:
> Nora
> these files.
> sfc /scannow
> Ronnie Vernon
> Microsoft MVP
> Windows Shell/User
> > when
> > following error :
> > would
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
Hi Nora,
You may need to run CHKDSK (Check Disk) first, then run the SFC /SCANNOW command. This tutorial will show you how to run the CHKDSK.
http://www.vistax64.com/tutorials/67612-checkdisk.html
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
R
Ronnie Vernon MVP
Nora
Try running sfc /scannow in Safe Mode.
Reboot the computer and start tapping the F8 Key as soon as the computer
starts to boot. Keep tapping the key until you see a black screen with a
menu.
Use the Arrow Keys to select Safe Mode. It will take a few minutes to boot
to safe mode. Once there, follow the same steps to run the system file
checker.
Ronnie Vernon
Microsoft MVP
Windows Shell/User
news:EFED0F25-35C9-4B89-BF76-4A7FDFC3A4E3@xxxxxx
> it
>> Nora
>> Resource
>> repair
>> these files.
>> Run
>> for a
>> sfc /scannow
>> Ronnie Vernon
>> Microsoft MVP
>> Windows Shell/User
>> >Player
>> > month
>> > when
>> > following error :
>> > configuration
>> > would
N
Okay also tried in safe mode and got the same message windows resource
protection could not perform the requested operation and it comes up right
after it gets to 43% in the verification process. Any other suggestions on
how to fix this or the original problem would be greatly appreciated
> Nora
> menu.
> checker.
> Ronnie Vernon
> Microsoft MVP
> Windows Shell/User
> > it
> >> Nora
> >> Resource
> >> repair
> >> these files.
> >> Run
> >> for a
> >> sfc /scannow
> >> Ronnie Vernon
> >> Microsoft MVP
> >> Windows Shell/User
> >> >Player
> >> > month
> >> > when
> >> > following error :
> >> > configuration
> >> > would
S
Steven Wabik
well, what are some of the details that it gives you in the event log?
knowing those may help. and what version of vista do you have?
news:3190002B-7503-4FC6-A40A-5B9321DF3FE0@xxxxxx
>> Nora
>> menu.
>> boot
>> checker.
>> Ronnie Vernon
>> Microsoft MVP
>> Windows Shell/User
>> > 43%
>> > requested
>> > and
>> > it
>> > the
>> >> Nora
>> >> Resource
>> >> repair
>> >> these files.
>> >> click
>> >> Run
>> >> for a
>> >> sfc /scannow
>> >> replaces
>> >> Ronnie Vernon
>> >> Microsoft MVP
>> >> Windows Shell/User
>> >> >Player
>> >> > month
>> >> > when
>> >> > following error :
>> >> > configuration
>> >> > problem
>> >> > would
N
#8
Thats the problem there is nothing in the event log about the side by side
error which is one of the reason i have no idea how to fix it. Also I'm using
Windows Vista 32-bit Home Premium edition.
> >> Nora
> >> menu.
> >> boot
> >> checker.
> >> Ronnie Vernon
> >> Microsoft MVP
> >> Windows Shell/User
> >> > 43%
> >> > requested
> >> > and
> >> > it
> >> > the
> >> >> Nora
> >> >> Resource
> >> >> repair
> >> >> these files.
> >> >> click
> >> >> Run
> >> >> for a
> >> >> sfc /scannow
> >> >> replaces
> >> >> Ronnie Vernon
> >> >> Microsoft MVP
> >> >> Windows Shell/User
> >> >> >Player
> >> >> > month
> >> >> > when
> >> >> > following error :
> >> >> > configuration
> >> >> > problem
> >> >> > would
S
Steven Wabik
#9
do you have an OEM or retail edition of vista? if vista came preinstalled on
your PC, try contcting the manufacturer of the PC for help. they might have
a solution. or they may just tell you to reinstall the OS eventually...
another idea is to update the OS with all the availible updates if you have
not already done so. that always helps with something...
news:3CD02856-C094-411D-AEC0-D3B6402068B7@xxxxxx
> using
>> > right
>> > on
>> >> Nora
>> >> computer
>> >> a
>> >> menu.
>> >> boot
>> >> checker.
>> >> Ronnie Vernon
>> >> Microsoft MVP
>> >> Windows Shell/User
>> >> > to
>> >> > 43%
>> >> > requested
>> >> > work
>> >> > and
>> >> > it
>> >> > Any
>> >> > fix
>> >> > the
>> >> >> Nora
>> >> >> Resource
>> >> >> to
>> >> >> repair
>> >> >> these files.
>> >> >> All
>> >> >> click
>> >> >> Run
>> >> >> or
>> >> >> for a
>> >> >> sfc /scannow
>> >> >> replaces
>> >> >> Ronnie Vernon
>> >> >> Microsoft MVP
>> >> >> Windows Shell/User
>> >> >> >Media
>> >> >> >Player
>> >> >> > past
>> >> >> > month
>> >> >> > when
>> >> >> > the
>> >> >> > following error :
>> >> >> > configuration
>> >> >> > detail.
>> >> >> > problem
>> >> >> > would
N
#10
My vista came preinstalled on my Dell computer. I contacted dell tech support
first they were of zero help they basically told me there was no fix and to
restore my computer to a previous date. Also i have done all available
updates. Thanks for the suggestions though. Have any more ideas how you think
i can solve this would be greatly appreciated.
> > using
> >> > right
> >> > on
> >> >> Nora
> >> >> computer
> >> >> a
> >> >> menu.
> >> >> boot
> >> >> checker.
> >> >> Ronnie Vernon
> >> >> Microsoft MVP
> >> >> Windows Shell/User
> >> >> > to
> >> >> > 43%
> >> >> > requested
> >> >> > work
> >> >> > and
> >> >> > it
> >> >> > Any
> >> >> > fix
> >> >> > the
> >> >> >> Nora
> >> >> >> Resource
> >> >> >> to
> >> >> >> repair
> >> >> >> these files.
> >> >> >> All
> >> >> >> click
> >> >> >> Run
> >> >> >> or
> >> >> >> for a
> >> >> >> sfc /scannow
> >> >> >> replaces
> >> >> >> Ronnie Vernon
> >> >> >> Microsoft MVP
> >> >> >> Windows Shell/User
> >> >> >> >Media
> >> >> >> >Player
> >> >> >> > past
> >> >> >> > month
> >> >> >> > when
> >> >> >> > the
> >> >> >> > following error :
> >> >> >> > configuration
> >> >> >> > detail.
> >> >> >> > problem
> >> >> >> > would
Spikey
1
#11
I think the problem is related to Vista's (Windows Resource Protection) aka (Data Execution Protection) in XP, I had a simular problem in XP and disabled DEP to fix it, I haven't tried it in Vista yet, I am getting the same error code in Vista too so I will be trying this when I get home. I will post my findings.
Ok in my case this was caused by DirectX not being updated, once I upgraded my DirectX problem was solved.
M
mudblood
#12
side by side error fix
tap F8
choose repair my computer
choose command prompt
type chkdsk /f c:
once its done with the process just type exit again. it will boot back to windows and goodluck!
it worked in my computer. hopefully it will work for you too! = )
Status
