SKY EMAIL
W
waynemoggie
Please help! My sky email was working fine up until this mornign in windows
live- now im getting... error 8000ccc92, asking me for my password and
username?? I enter the right ones and it wont accept them!
I went onto the skyuser site to see how to configure a new account, and ive
done that, and now im getting errors!
Your IMAP server wishes to alert you to the following: Web login required
(Failure)"
Can anyone explain step by step what I need to do to get it to work? Thanks!
G
Gary VanderMolen
If you are sure you are you are entering the correct username and
password, one possible cause for that error is account corruption.
One thing you should try as a quick fix is to delete that corrupted
mail account, restart Windows Mail, then recreate that account.
If that doesn't fix it, more drastic measures will have to be taken.
Which antivirus are you running?
As a minimum, email scanning in the antivirus must be turned off,
although that may not be sufficient to eliminate all bad effects.
In a worst case scenario, your antivirus may need to be uninstalled.
If turning off the email scanning function does not resolve your problem,
consider upgrading to Windows Live Mail, because it is less prone to
suffering bad effects from overly aggressive antivirus programs.
http://get.live.com/wlmail/overview
Email scanning in any antivirus must be disabled, for reasons
explained here:
http://thundercloud.net/infoave/tutorials/email-scanning/index.htm
Gary VanderMolen, MS-MVP (Mail)
"waynemoggie" <waynemoggie@xxxxxx> wrote in message news:B6D602ED-7179-4ACE-94EA-A0EE98076FE1@xxxxxx
> (Failure)"
G
Gary VanderMolen
We would need to see your exact error message.
Right-click on your error message, copy, then paste it into a reply here.
"Rob" <Rob@xxxxxx> wrote in message news:ED2E3A87-82BE-4EED-91D7-5D856AFE5536@xxxxxx
> I am receiving this same error and I use Google e-mail. If you go to some
> other threads under Windows Mail, it appears other individuals are having the
> same issue and are reporting it as of today's date.. I think it is Windows
> Mail issue.
L
l3igl3ang
I getting these errors as well and there peeing me off! When i first added my
emails to outlook i added 3 aol accounts and 3 gmail accounts and everything
worked good well untill a week ago 2 of the gmails started saying that crap
about wrong login and password so i went to gmail.com logged in just fine so
then i 2x checked my settings against the working one every setting was the
same so just a bit ago i deleted both gmails and reset them up one started
working the other still same problem any ideas what could cause this?
i never had these kinda problems with aol email
G
Gary VanderMolen
A likely reason for the username/password failing is account corruption
caused by your antivirus.
One thing you should try as a possible quick fix is to delete that corrupted
http://download.live.com/wlmail
explained here:
"l3igl3ang" <l3igl3ang@xxxxxx> wrote in message news:E8DBACDB-004D-4883-BB88-5D42996834F8@xxxxxx
