Solved Sleep mouse during sleep mode?
25
I would like to put my wireless mouse in inactive mode during sleep mode. As it is an mouse movement, usually accidental, wakes up the computer. I looked for a way but couldn't find this facility.
Jack
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Hello Jack,
You might check using STEP SIX in the tutorial below as a guide to see if you have a "Power Management" tab to uncheck the "Allow to wake computer" option in it for you mouse in Device Manager.
http://www.vistax64.com/tutorials/63567-power-options-sleep-mode-problems.html
If not, then you can use the STEP FIVE section to manually disable the mouse from waking up your computer.
Just be sure that you at least have the keyboard allowed to wake up the computer, or you will have to press the case power button to wake up your computer instead. ;)
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
10
Also check your BIOS, newer mainboards will allow you to control which peripherials can wake the computer when it is "sleeping". I have a dell laptop and i know mine does, even shuts off the USB ports from taking input causing it to wake.
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
You're welcome Jack. I'm happy to hear all is ok now. :)
You might keep an eye out for newer driver versions for the mouse. This issue may be fixed with a future updated version hopefully.
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
