Slow performance initializing PowerShell from managed code
  • Thread starter =?Utf-8?B?ZGg=?=
  • Start date
=?Utf-8?B?ZGg=?=
I am building a Ex2007 client in managed code and have been consistently
seeing very slow performance from Monad/PowerShell initialization every time
I execute/debug.
The following two statements:
runspaceConfiguration = RunspaceConfiguration.Create();
and
runspaceConfiguration.AddMshSnapIn(EXCHANGE_MANAGEMENT_ADMIN, out
mshSnapinException);
are the two slowest lines of code, each taking about 13 seconds to execute.
Running release code instead of debug code moves the
RunspaceConfiguration.Create(); 13 second delay to the runspace.Open();
statement for some reason, but it still takes at least 25 seconds to
initialize before I can invoke a cmdlet call.
Using static Runspace and RunspaceConfiguration helps for repeated calls,
but I still have to reload them with each debug session, so a lot of
expensive, unproductive wait time.
Any recommendations on how to get better response time out of PS
initialization from managed code?
=?Utf-8?B?ZGg=?=
btw - this is the code I used to measure performance:
using System;
using System.Collections.Generic;
using System.Management.Automation;
using System.Management.Automation.Runspaces;
namespace PowerShellDemo
class Program
static void Main(string[] args)
RunspaceConfiguration runspaceConfiguration = null;
MshSnapInException mshSnapinException = null;
Runspace runspace = null;
string EXCHANGE_MANAGEMENT_ADMIN =
"Microsoft.Exchange.Management.Msh.Admin";
Console.WriteLine("press any key to make PowerShell call...");
Console.ReadKey();
Output("step", "msec");
Output("----", "----");
DateTime dtStart;
DateTime dtStartStep;
dtStart = DateTime.Now;
dtStartStep = DateTime.Now;
Output("RunspaceConfigurationCreated", dtStartStep);
out mshSnapinException);
Output("MshSnapIn Added", dtStartStep);
runspace = RunspaceFactory.CreateRunspace(runspaceConfiguration);
Output("RunspaceCreated", dtStartStep);
runspace.Open();
Output("RunspaceOpened", dtStartStep);
Command cmd = new Command("get-Date");
ICollection<MshObject> results = null;
Pipeline pipeLine = null;
try
pipeLine = runspace.CreatePipeline();
Output("PipelineCreated", dtStartStep);
using (pipeLine)
pipeLine.Commands.Add(cmd);
results = pipeLine.Invoke();
Output("PipelineInvoked", dtStartStep);
finally
pipeLine = null;
if (null != runspace)
runspace.Close();
runspace.Dispose();
runspace = null;
string result = "";
foreach (MshObject obj in results)
result = obj.ToString();
Output("ResultsRetrieved", dtStartStep);
Output("Total", dtStart);
Console.WriteLine(string.Format("\nget-Date result:\t{0}",
result));
Console.WriteLine("press any key to end...");
Console.ReadKey();
private static void Output(string stepName, DateTime dtStartStep)
TimeSpan tsStep = DateTime.Now - dtStartStep;
int seconds = (int)tsStep.TotalMilliseconds;
Output(stepName + ":", seconds.ToString());
private static void Output(string stepName, string data)
if (stepName.Length < 8)
Console.WriteLine(string.Format("{0}\t\t\t\t{1,11}",
stepName, data));
else if (stepName.Length < 16)
Console.WriteLine(string.Format("{0}\t\t\t{1,11}", stepName,
data));
else if (stepName.Length < 24)
Console.WriteLine(string.Format("{0}\t\t{1,11}", stepName,
data));
else
Console.WriteLine(string.Format("{0}\t{1,11}", stepName,
data));
=?Utf-8?B?S2FybCBQcm9zc2Vy?=
it looks like you are using a very old version of powershell, actually before
powershell was powershell back in the monad 3 betas when it was called MSH?
my only thoughts is that slowdown in compiling the Pcode for powershell to
native code, which normally happens the first time code in a referenced
assembly is run. so you can predo it but doing some strategic references
earlier, and of course you could NGEN it beforehand
but i could be barking up the wrong tree also
Karl
=?Utf-8?B?ZGg=?=
Exchange 2007 is not yet upgraded to the latest PowerShell release, I think
they are calling their version RC0. So that's what I'm stuck with until
Exchange 2007 comes out with their release cand. which is supposed to sync up
with a newer PowerShell.
I will give ngen a try, but my impression is that seems to only contribute a
few seconds. I'm guessing the same delay I see starting up a PowerShell or
Monad command shell, initalizing runspace etc., is what I am seeing everytime
I debug. I communicated with an Exchange guy and he said to talk to the
PowerShell folks. Hopefully I can get some recommendations from the PS team.
thanks,
dh
so if you are not debugging , then it works fine?
> thanks,
> dh
J
Jeffrey Snover [MSFT]
=?Utf-8?B?ZGg=?=
After more investigation it looks like the performance problem I described
may be mostly due to running the test on a virtual server. When I have
access to a physical server with Exch2007 installed I will run the same tests
again for comparison. Then I will also look at the impact of NGen.
thanks for your help,
-dh
