Slow start up
G
ggustar
I have Vista premium installed, it has been taking 10 minutes to load lately.
On looking in the start up menu, I see I have 3 "Microsoft Windows host
process (Rundll32)" installed at start up. Could this be the reason for a
slow start up? they all look the same. Could I just disable 2 of them?
Brink
Staff member
mvp
Hi GGustar,
I would check in your "Startup Programs" to see what is listed to run at the startup of Vista. Disable the ones you do not want, to test if it helps. If you are sure you want it to not start with Vista, then remove it. You can see how to do this here:
http://www.vistax64.com/tutorials/79612-startup-programs-enable-disable.html
G
ggustar
Thank you for reply, but this is my question, I have already looked in the
Start up menu and found 3 identical programs that start up
"Microsoft Windows host process (Rundll32)"
My question is can I delete or disable 2 of them without any ill effects?
"brink" wrote:
> > lately.
> > a
> Hi GGustar,
> Shawn
> brink
> *There are no dumb questions, just the people that do not ask them.*
> _http://www.Vistax64.com (\"http://www.Vistax64.com\")_
> *Please post feedback to help others.*
Brink
Staff member
mvp
GGustar,
If you are able to disable 2 of them, then yes go ahead. Worst case you will need to boot into Safe Mode and enable them again.
If not, then you might try a repair install to try and avoid a clean install. It should leave your settings and programs intact afterwards. You can look here for how to do it.
http://www.vistax64.com/tutorials/88236-repair-install-vista.html
