Slow Wireless
K
kekesala
I have two Laptops an Acer & Fujitsu siemens both use an atheros network
adapterto connect wirelessly to my Belkin router. The laptops are similar in
spec however the acer connects to my Belkin router with excellent speed
(streaming content perfectly), my fujitsu connects but is extremely slow
(Streaming is unwatchable). The connection strength is excellent on both
machines. Both laptops are in the same room. I have spoken to Fujitsu who
state there is no problem with the network adapter as the signal strength is
excellent, it must be a software conflict. Can anyone help with improving my
connection speed.
R
Robert L. \(MS-MVP\)
You may want to disable IPv6? Or this post may help.
Vista Slow issuesVista Slow issues ... of Vista) it is very slow to resolve
folder names. For example I have a . ...
http://www.chicagotech.net/vista/vistaslow.htm ...
www.chicagotech.net/netforums/viewtopic.php?p=870&sid=c0043257d9d922b48594bce4c02afc2e
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
"kekesala" <kekesala@xxxxxx> wrote in message
news:863EA97A-0A0B-4CDE-A867-ADC7313F0E78@xxxxxx
> in
> is
> my
> connection speed.
K
kekesala
Thanks Robert
Could you explain how to do this
> > in
> > is
> > my
> > connection speed.
R
This how to may help.
Vista IPCONFIG and Network SettingsHow to remove IPv6 and Tunnel completely
on Vista · How to disable ICS public connection in Vista · How to: Enabling
ICS on Vista ...
www.howtonetworking.com/vista/vistaipconfig.htm
news:EB78F7BE-414E-4B1D-B1BA-0E08993AE206@xxxxxx
> Thanks Robert
>> resolve
>> > similar
>> > in
>> > slow
>> > both
>> > who
>> > strength
>> > is
>> > improving
>> > my
>> > connection speed.
K
kekesala
Thanks Robert
I did try this with no improvement, however just by accident I removed all
my peripherals connected by USB and my internet worked perfectly. By trial
and error I established it was a USB Hub that was causing the problem even
though it works perfectly well. This may be worth noting for people with
similar problems with slow wireless.
> ICS on Vista ...
> > Thanks Robert
> >> resolve
> >> > similar
> >> > in
> >> > slow
> >> > both
> >> > who
> >> > strength
> >> > is
> >> > improving
> >> > my
> >> > connection speed.
