Some solutions I have constructed (HTA HTML vbScript)
B
Benny Pedersen
<!-- Hi
Below is a HTA Doc, which is under construction.
Anyhow, I think I have found some nice solutions,
I would like to share.
E.x.:
How to change the order of a check box while the HTML is running.
How to invert any check box selected.
How to save the result to a Temp file - The button to do that is named
[Use and Exit].
(The TEMP file is overwritten also when its attribute is read-only.
The VBS file, which created the HTA file should read the check box
values from the TEMP file
- When the HTA file exit; the VBS script continues)...
How to toggle any unchecked check box, etc...
All this is shown below. Just run :)
Benny,
PS. The "GetExifConfig.hta" below was constructed by a VBS file, which
extracted the Exif info from a photo (file drag and drop).
The reason I included a VBS file was that the HTA can't
take arguments by drag and drop. Maybe [GetExifConfig.hta#something]
would work but then we would also have to know how the HTA could
extract the #something,
and I'm not sure it would be possible.
The whole project will later be written in the photoshop forum (see my
Homepage for urls).
www.fineraw.com
Any ideas about how to make the below HTA file less size is welcome.
<html><head><title>GetExifConfig.hta</title>
<HTA:APPLICATION SINGLEINSTANCE="yes"
APPLICATIONNAME="GetExifConfig"></head>
<style>
body{font-family:Verdana;font-size:10pt;background-Color:#f6f6f6;}
..btn{font-family:Verdana;font-size:8pt;width:112px;}
</style><script language="vbScript">
Dim arr(40), iGloVis: iGloVis= 8
Sub SaveConfig() Dim s, i, j
If C1.Checked Then s= "Exif from files" & vbCrLf
If C2.Checked Then s= s & "Write text file" & vbCrLf
For i= 0 To 255
j= "E" & Right("00" & i, 3)
On Error Resume Next
If Eval(j).Checked Then If (Err.Number = 0) Then s= s & j & ", " &
vbCrLf
On Error Goto 0
Next
Dim oTmpF, sTmpF, fso: Set fso= createObject
("scripting.fileSystemObject")
sTmpF= fso.getSpecialFolder(2) & "\GetExifConfig.tmp"
If fso.FileExists(sTmpF) Then
Set oTmpF= fso.GetFile(sTmpF)
If oTmpF.attributes and 1 Then oTmpF.attributes= oTmpF.attributes
-1
If s = "" Then oTmpF.Delete
End If
If (Not s = "") Then
Set oTmpF= fso.openTextFile(sTmpF, 2, True)
oTmpF.Write s: oTmpF.Close
End If
Set oTmpF= Nothing: Set fso= Nothing
Self.Close
End Sub
Sub Profile(byVal s)
Dim i, j, ArrP: If (iGloVis = 1) Then ToggleHideUnChk()
For i= 0 To 255: j= "E" & Right("00" & i, 3): Eval(j).Checked= False
Next
ArrP= Split(Trim(s),Chr(32))
For i= 0 To uBound(ArrP)
j= "E" & Right("00" & ArrP(i), 3): Eval(j).Checked= True
Next
On Error Goto 0
End Sub
Sub ToggleHideUnChk()
Dim i, j
For i= 0 To 255
j= Right("00" & i, 3)
If (Not Eval("E" & j).Checked) Then Eval("S" &
j).Style.Visibility= Mid("VisibleHidden",iGloVis,7)
Next
On Error Goto 0
iGloVis= Abs(iGloVis -9)
End Sub
Sub Invert()
Dim i, j: If (iGloVis = 1) Then ToggleHideUnChk()
For i= 0 To 255
j= Right("00" & i, 3): Eval("E" & j).Checked= (Not Eval("E" &
j).Checked)
Next
On Error Goto 0
End Sub
Sub MakeArr()
Dim j, i, L: L= 9
For i= 0 To 255
If (Eval("E" & j).Checked +2) Then If (Err.Number = 0) Then L= L
+1: arr(L)= j
On Error Goto 0
Next
End Sub
Sub Up(x)
If arr(10) = "" Then MakeArr()
x= Right("00" & x, 3)
Dim s, i
For i= 10 to uBound(arr): If x = arr(i) Then Exit For
Next
If i = 10 Then Down(): Exit Sub
s= Eval("L" & i).InnerHtml
Eval("L" & i).InnerHtml= Eval("L" & i-1).InnerHtml
Eval("L" & i -1).InnerHtml= s
arr(i)= arr(i-1): arr(i-1)= x
' ConfigureArea.Value= Join(arr)
End Sub
Sub Down()
MsgBox "Under Construction", 4096
End Sub
</script><body>
<INPUT class="btn" type="button" value="Refresh"
onclick="Location.Reload(True)">
<INPUT class="btn" type="button" value="Profile 1" onClick='Profile
"30 233 31 1 161 230 231 235 12"'>
<INPUT class="btn" type="button" value="Hide/Show UnChk"
onClick="ToggleHideUnChk">
<INPUT class="btn" type="button" value="Invert" onClick="Invert">
<INPUT class="btn" type="button" value="Use &amp; Exit"
onClick="SaveConfig"><p>
<input type="checkbox" id="C1"> Exif from other photos<br>
<input type="checkbox" id="C2"> Write text file<HR>
<nobr>
<span id="L10"><span id="S000"><INPUT type="button" value="&lt;"
onClick="Up 000"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E000">000:
a_040811_165510_web.jpg</span></span><br>
<span id="L11"><span id="S001"><INPUT type="button" value="&lt;"
onClick="Up 001"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E001">001: 122 KB</span></
span><br>
<span id="L12"><span id="S002"><INPUT type="button" value="&lt;"
onClick="Up 002"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E002">002: JPEG Image</
span></span><br>
<span id="L13"><span id="S003"><INPUT type="button" value="&lt;"
onClick="Up 003"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E003">003: 18-05-2008 10:00</
span></span><br>
<span id="L14"><span id="S004"><INPUT type="button" value="&lt;"
onClick="Up 004"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E004">004: 09-04-2009 23:34</
span></span><br>
<span id="L15"><span id="S005"><INPUT type="button" value="&lt;"
onClick="Up 005"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E005">005: 09-04-2009 23:34</
span></span><br>
<span id="L16"><span id="S006"><INPUT type="button" value="&lt;"
onClick="Up 006"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E006">006: A</span></
span><br>
<span id="L17"><span id="S009"><INPUT type="button" value="&lt;"
onClick="Up 009"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E009">009: Image</span></
span><br>
<span id="L18"><span id="S010"><INPUT type="button" value="&lt;"
onClick="Up 010"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E010">010: Benny-PC\Benny</
span></span><br>
<span id="L19"><span id="S011"><INPUT type="button" value="&lt;"
onClick="Up 011"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E011">011: Picture</span></
span><br>
<span id="L20"><span id="S019"><INPUT type="button" value="&lt;"
onClick="Up 019"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E019">019: Unrated</span></
span><br>
<span id="L21"><span id="S031"><INPUT type="button" value="&lt;"
onClick="Up 031"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E031">031: 900 x 675</span></
span><br>
<span id="L22"><span id="S063"><INPUT type="button" value="&lt;"
onClick="Up 063"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E063">063: BENNY-PC (this
computer)</span></span><br>
<span id="L23"><span id="S155"><INPUT type="button" value="&lt;"
onClick="Up 155"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E155">155:
<span id="L24"><span id="S160"><INPUT type="button" value="&lt;"
onClick="Up 160"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E160">160: 24</span></
span><br>
<span id="L25"><span id="S161"><INPUT type="button" value="&lt;"
onClick="Up 161"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E161">161: 96 dpi</span></
span><br>
<span id="L26"><span id="S162"><INPUT type="button" value="&lt;"
onClick="Up 162"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E162">162: 900 pixels</
span></span><br>
<span id="L27"><span id="S163"><INPUT type="button" value="&lt;"
onClick="Up 163"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E163">163: 96 dpi</span></
span><br>
<span id="L28"><span id="S164"><INPUT type="button" value="&lt;"
onClick="Up 164"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E164">164: 675 pixels</
span></span><br>
<span id="L29"><span id="S165"><INPUT type="button" value="&lt;"
onClick="Up 165"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E165">165: Normal</span></
span><br>
<span id="L30"><span id="S176"><INPUT type="button" value="&lt;"
onClick="Up 176"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E176">176: images</span></
span><br>
<span id="L31"><span id="S177"><INPUT type="button" value="&lt;"
onClick="Up 177"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E177">177: R:\Documents\Doc
\www.fineraw.com\images</span></span><br>
<span id="L32"><span id="S178"><INPUT type="button" value="&lt;"
onClick="Up 178"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E178">178: images (R:
\Documents\Doc\www.fineraw.com)</span></span><br>
<span id="L33"><span id="S180"><INPUT type="button" value="&lt;"
onClick="Up 180"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E180">180: R:\Documents\Doc
\www.fineraw.com\ SNIP</span></span><br>
<span id="L34"><span id="S186"><INPUT type="button" value="&lt;"
onClick="Up 186"><INPUT type="button" value="&gt;"
onClick="Down"><input type="checkbox" id="E186">186: Unresolved</
span></span><br>
</nobr>
<!-- p><textarea name="ConfigureArea" rows="12" cols="64"></textarea -- </body><script language="JavaScript">window.resizeTo
(640,840);window.moveTo(0,0);</script></html>
P
Paul Randall
"Benny Pedersen" <b.pedersen@xxxxxx> wrote in message
news:1fd98074-65b0-451b-85a6-3f3785f5ab59@xxxxxx
> <!-- Hi
Hi, Benny
On my Outlook Express 6 newsgroup reader, I have serious line wrap problems
with your post. Could you zip the file and add a .txt extension to the zip
file, and attach it to another post?
-Thanks
-Paul Randall
B
Benny Pedersen
Ok. The below is the ZIP with the HTA file,
and the same ZIP file but extension TXT
http://www.fineraw.com/tmp/getExif.zip
http://www.fineraw.com/tmp/getExif_zip.txt
The VBS file is not included.
And the two "zip" files above in the TMP folder will later be
substituted with a final version,
Maybe around here:
http://www.elementsvillage.com/forums/showthread.php?p=461078#post461078
Benny,
PS: The extracted Exif was made writeable in Vista, like this:
Notice the chr(63) was one of the problems:
Function MakeExifWriteable(byVal s)
Dim j
For j= 1 to Len(s)
If Asc(Mid(s,j,1)) = 63 Then s= Left(s, j-1) & chr(0) & Mid(s, j+1)
Next
MakeExifWriteable= Replace(s, chr(0), "")
End Function
Most of the HTA was made writeable, something like this:
"HtmToVbs.vbs" (drag and drop the HTA)
Option Explicit
dim fso, sArgF, oArgF, i, arr(), oNewF: i= 0
set fso= createObject("scripting.fileSystemObject")
sArgF= fso.GetFile(WScript.Arguments(0))
Set oArgF= fso.OpenTextFile(sArgF, 1)
Do Until oArgF.AtEndOfStream
i= i +1: ReDim PreServe arr(i): arr(i)= oArgF.ReadLine
arr(i)= Replace(arr(i), vbTab, string(4," "))
arr(i)= """" & Replace(arr(i), """", """""") & """"
Loop
oArgF.Close: Set oArgF= Nothing
Set oNewF= fso.OpenTextFile(sArgF & "#", 2, True)
Set fso= Nothing
oNewF.WriteLine "oAppF.WriteLine " & arr(1) & " & vbCrLf _"
For i= 2 to uBound(arr) -1
If (arr(i) = """""") Then
oNewF.WriteLine "& vbCrLf _"
Else
oNewF.WriteLine "& " & arr(i) & " & vbCrLf _"
End If
Next
oNewF.Close: Set oNewF= Nothing
' CreateObject("WScript.Shell").Run _
' "C:\Windows\Pfe32.exe """ & sArgF & "#"""
On 28 Maj, 07:05, "Paul Randall" <paul...@xxxxxx> wrote:
> "Benny Pedersen" <b.peder...@xxxxxx> wrote in message
> > <!-- Hi
> Hi, Benny
> with your post.  Could you zip the file and add a .txt extension to thezip
> -Thanks
> -Paul Randall
B
Benny Pedersen
Got the move-checkbox-vertical thing to work both
up and down, like this:
ONE LINE: <span id="L10"><span id="S000">
<INPUT type="button" value="&lt;" onClick="VMove -000">
<INPUT type="button" value="&gt;" onClick="VMove 000">
<input type="checkbox" id="E000">000: ...SNIP...</span>
</span><br>
Vertical move, Sub:
Sub VMove(x)
Dim s, i, v: v= Right("-1",(x < 0) +2)
'* First try was: v= Left("-",("-"=Left(x,1)) +1) & 1
x= Right("00" & abs(x), 3)
Next
If arr(i-v) = "" Then Exit Sub
Eval("L" & i).InnerHtml= Eval("L" & i-v).InnerHtml
Eval("L" & i -v).InnerHtml= s
arr(i)= arr(i-v): arr(i-v)= x
End Sub
Benny,
PS: benny.pedersen
+ gmail.com
> Maybe around here: http://www.elementsvillage.com/forums/showthread.php?p=461078#post461078
> Benny,
> Dim j
> For j= 1 to Len(s)
> Next
> End Function
> Option Explicit
> Loop
> Set fso= Nothing
>         Else
>         End If
> Next
> > Hi, Benny
> > -Thanks
> > -Paul Randall- Skjul tekst i anførselstegn -
> - Vis tekst i anførselstegn -
B
Benny Pedersen
<html><head><title>test</title>
<HTA:APPLICATION SINGLEINSTANCE="yes" APPLICATIONNAME="test">
</head><script language="vbScript">
Dim arr(40)
Sub MakeArr()
Dim j, i, L: L= 9
For i= 0 To 255
If (Eval("E" & j).Checked +2) Then If _
(Err.Number = 0) Then L= L +1: arr(L)= j
On Error Goto 0
Next
End Sub
Sub Up(x)VMove-1,x End Sub:Sub Down(x)VMove 1,x End Sub
Sub VMove(v,x)
Dim i: i= 10: While x <> arr(i): i= i +1: wEnd
If arr(i+v) = "" Then Exit Sub
arr(i)= arr(i+v): arr(i+v)= x
x= Eval("L" & i).InnerHtml
Eval("L" & i).InnerHtml= Eval("L" & i+v).InnerHtml
Eval("L" & i +v).InnerHtml= x
End Sub
</script>
<body>
<div id="L10">
<INPUT type="button" value="U" onClick="Up 000">
<INPUT type="button" value="D" onClick="Down 000">
<input type="checkbox" id="E000">000</div>
<div id="L11">
<INPUT type="button" value="U" onClick="Up 007">
<INPUT type="button" value="D" onClick="Down 007">
<input type="checkbox" id="E007">007</div>
<div id="L12">
<INPUT type="button" value="U" onClick="Up 057">
<INPUT type="button" value="D" onClick="Down 057">
<input type="checkbox" id="E057">057</div>
<div id="L13">
<INPUT type="button" value="U" onClick="Up 112">
<INPUT type="button" value="D" onClick="Down 112">
<input type="checkbox" id="E112">112</div>
<div id="L14">
<INPUT type="button" value="U" onClick="Up 123">
<INPUT type="button" value="D" onClick="Down 123">
<input type="checkbox" id="E123">123</div>
</body>
</html>
> http://www.fineraw.com/tmp/getExif.ziphttp://www.fineraw.com/tmp/getExif_zip.txt
> Maybe around here:http://www.elementsvillage.com/forums/showthread.php?p=461078#post461078
> Benny,
> Dim j
> For j= 1 to Len(s)
> Next
> End Function
> Option Explicit
> Loop
> Set fso= Nothing
>         Else
>         End If
> Next
> > Hi, Benny
> > -Thanks
B
Benny Pedersen
Dim arr(40)
Sub MakeArr()
Dim j, i, L: L= 9
For i= 0 To 255
On Error Goto 0
Next
End Sub
Sub Up (x) x=Right("00"&x,3):VMove-1,x:Eval("U"&x).Select:End Sub
Sub Down(x)x=Right("00"&x,3):VMove+1,x:Eval("D"&x).Select:End Sub
Sub VMove(v,byVal x)
End Sub
</script>
<body>
<div id="L10">
<INPUT id="U000" type="button" value="U" onClick="Up 000">
<INPUT id="D000" type="button" value="D" onClick="Down 000">
<input id="E000" type="checkbox">000</div>
<div id="L11">
<INPUT id="U007" type="button" value="U" onClick="Up 007">
<INPUT id="D007" type="button" value="D" onClick="Down 007">
<input id="E007" type="checkbox">007</div>
<div id="L12">
<INPUT id="U057" type="button" value="U" onClick="Up 057">
<INPUT id="D057" type="button" value="D" onClick="Down 057">
<input id="E057" type="checkbox">057</div>
<div id="L13">
<INPUT id="U112" type="button" value="U" onClick="Up 112">
<INPUT id="D112" type="button" value="D" onClick="Down 112">
<input id="E112" type="checkbox">112</div>
<div id="L14">
<INPUT id="U123" type="button" value="U" onClick="Up 123">
<INPUT id="D123" type="button" value="D" onClick="Down 123">
<input id="E123" type="checkbox">123</div>
</body>
</html>
> Benny,
> Dim j
> For j= 1 to Len(s)
> Next
> End Function
> Option Explicit
> Loop
> Set fso= Nothing
>         Else
>         End If
> Next
> > Hi, Benny
> > -Thanks
