Sorting, grouping data
M
Marco Shaw
I've got a web page I want to download. I contains roughly 100 records. I
want to sort and group the data based on certain fields. I also want to
calculate medians based on some of the records grouped together.
Any hints/tips to get me going? Do I want to pull this into Excel to
manipulate?
Marco
J
Jeffery Hicks
> manipulate?
> Marco
Use and ADO Recordset.
Jeffery Hicks - www.ScriptingAnswers.com
SAPIEN Technologies - Scripting, Simplified. www.SAPIEN.com
Scripting books: www.SAPIENPress.com
D
dreeschkind
Well, first you need get the web page. If it is just a plain HTML file that
doesn't involve any interaction like filling out forms etc. then it should be
sufficient to use:
$url = "http://www.example.com/data.html"
$data = (new-object System.Net.WebClient).DownloadString($url)
Then you need to crack that string into the field/value pairs that you are
interested in.
If the web page is written in proper XHTML, casting the $data string to
[XML] will probably make this part easier. Otherwise you will probably need
to use regular expressions and/or string split methods to extract the
relevant information.
Depending on the format of the records it might make sense to create a
"synthetic class" for these records and store them all in an array. (See
thread "PowerShell Class") This will make sorting and grouping easier.
> I want to sort and group the data based on certain fields.
See Help for Sort-Object and Group-Object Cmdlets.
> I also want to calculate medians based on some of the records grouped together.
Pipe the grouped objects to the ForEach Cmdlet and use begin/process/end
scriptblocks or write your own function to calculate medians based on
$input/$_.
> manipulate?
See Help for Export-Csv Cmdlet.
greetings
dreeschkind
M
Marco Shaw
> I want to sort and group the data based on certain fields. I also want to
Thanks Jeffery and dreeschkind for your suggestiongs.
I've retrieved the page, and have been able to cut out a lot of stuff, by
finding a open and close tag that occurs once around the data I want.
Now, some remaining things I need to resolve:
1. I probably should remove some of the <*> HTML tags, and everything in
them. That should be easy enough, and I'll go searching for a .NET regex
expression for stripping or replacing.
2. My data isn't very orderly... It looks something like:
Header1 Header2
Header3 Datarow1col1 Datarow1col2
Datarow1col3...
Using something like this, I've been able to split all the entries:
[regex]::Matches((gc file),"<xx>(.*?)</xx>")
The problem is, I need to format this like this:
Datarow1col1 Datarow1col2 Datarow1col3
Datarow2col1 Datarow2col2 Datarow2col3
etc.
I also need to omit the column header, but have some ideas I haven't tried
yet.
How can I take all of this data, all poorly formatted to start with, and
make a nice 3 column x N row table, so I can continue massaging the data?
I've tried to explain as best I could...
Marco
L
Lee Holmes [MSFT]
See if this gives you any pointers, Marco:
http://www.leeholmes.com/blog/PowerShellTheOracleInstantAnswersFromYourPrompt.aspx
Lee Holmes [MSFT]
Windows PowerShell Development
Microsoft Corporation
"Marco Shaw" <marco@Znbnet.nb.ca> wrote in message
news:OBgKmpHAHHA.4060@TK2MSFTNGP03.phx.gbl...
> Header1 Header2
> Datarow1col3...
> etc.
> yet.
> Marco
