Sorting output in Ascending rather than Descending
J
j0seg
Hi all,
Okay I've been doing some searches online, and also reading in my powershell
books, but I cant seem to find the command to sort in ascending, and I know I
can sort in Descending but when I enter sort-object -ascend or -asc I get an
error..but -desc seems to work...if I try to leave sort-object blank I also
get an error. So I figured I'd ask for a lil help...
Joseg
S
Shay Levi
There is no Ascending parameter on select-object, it's the default behavior.
What do you get for:
dir | sort
Can you see that the files are sorted in Ascending order?
Can you post your command?
Shay Levi
$cript Fanatic
http://scriptolog.blogspot.com
> Hi all,
> powershell books, but I cant seem to find the command to sort in
> ascending, and I know I can sort in Descending but when I enter
> sort-object -ascend or -asc I get an error..but -desc seems to
> work...if I try to leave sort-object blank I also get an error. So I
> Joseg
