sp 1 how do i know if it installed
370
hi . like to how to check and see if i have sp 1 installed in my pc .
and do i really need it .??????.
i did check in symtem tools information [value] but it is not listed in there .
so is that mean that it not installed .
i did put a new hhd on the 26 of last month and installed vista .
thank you
    build by me last summer
    cpu.3.00.ghz
    asrock fm2 -75 pro
    g-skill 1333 7-7-7-21 4 gbs
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    apevia.atx-as500 blue led
    thermatake armor a 30
    5= 80 mm led fans
    logitech
    logitech mk 300
richc46
Staff member
20,105
Location
Fairfield County, CT
370
Try this what did it say?
Click Start and type WinVer in the SearchBar then hit enter.
here is what it show .
but i did some reading since i post .and i thing that i will pass on it .
because i don't really need it any way for what i use my pc for
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
whs
2,026
Location
Germany/Florida
    Dell
    Q6600
    HP w2207h
    2x250GB HDDs
    1x60GB OCZ SSD
    6 external disks 60 to 640GBs
370
ok here is what i did .it did came up for download but me the stupid i hide it .
so to see if it was there i restored all my hiding update .and it was .
so you want me to install it now right .
what happen is when i installed vista i had that uodate showing up all the time.
[office xp service pack 3 ] but i not running xp .so i hide it .about 4 of them .
so when i saw sp 1 i did the same thing i hide it .lol .
well it not funny when you are a begainer on a pc .
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
richc46
Staff member
20,105
Location
370
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
370
#8
all done now .
it took a bet of time to download.
thank you
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
whs
2,026
Location
Germany/Florida
#9
Why don't you just install it. Be patient, it takes 30 to 60 minutes depending on your hardware.
    Dell
    Q6600
    HP w2207h
    2x250GB HDDs
    1x60GB OCZ SSD
370
#10
i just did .like i said above .
i said that it took a wild to download .
yes about 40 minutes do download.
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
richc46
Staff member
20,105
Location
#11
WHS, knows now that you did. He was typing at the same time as you. In any event, glad that you are all set, for the time being.
370
#12
here it is .now it is showing .
look
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech
    logitech mk 300
richc46
Staff member
20,105
Location
#13
It happened again, you and I were typing at the same time.
whs
2,026
Location
Germany/Florida
#14
Yeah, I understand that did download, but did you also install it?
    Dell
    Q6600
    HP w2207h
    2x250GB HDDs
    1x60GB OCZ SSD
