SP1 fails
R
SP1 fails and tells me I'm missing update KB947821. I have now installed it
successfully four times but SP1 fails and gives me the same message. What
should I do?
T
Trevor
>should I do?
Have you rebooted since installing the update? If not, try that. And
also then, check for more updates again before SP1.
Trev
R
"Trevor" <noway@xxxxxx> wrote in message
news:i8p5u3dsr0cv9chm5g29al0v96bjmf7ivs@xxxxxx
>>it
>>should I do?
> Trev
I tried re-booting. This time I was not told to re-install KB947821.
But.....I still cannot install SP1. The error is 800B0100 and no other
error. I have looked up the error code but applies to other listed codes I
have not received.
T
TaurArian
"Ryka" <Ryka@xxxxxx> wrote in message
news:5DC8C96B-B401-48D9-8D88-246284501355@xxxxxx
| >>it
| >>should I do?
| > Trev
| have not received.
Description of the CheckSUR update for Windows Vista and for Windows Vista for x64-based
systems
http://support.microsoft.com/kb/947821
0x800B0100 - TRUST_E_NOSIGNATURE - No signature was present in the subject.
Things to know before you download Windows Vista SP1
http://technet.microsoft.com/en-us/windowsvista/bb968859.aspx
Windows Vista Service Pack 1 (All Languages)
Unlimited installation and compatibility support is available at no charge until March 18,
2009.
"If your Microsoft product was already installed on your computer when you purchased it,
contact your computer manufacturer to see if no-charge support is available to you.
Support for preinstalled products is available from Microsoft for a fee. Some issues may
require more Advanced support for which there is a charge."
https://support.microsoft.com/oas/default.aspx?ln=en-us&x=8&y=7&prid=11274&gprid=500921
TaurArian [MVP] 2005-2008 - Update Services
http://taurarian.mvps.org
How to ask a question: http://support.microsoft.com/kb/555375
Computer Maintenance: Acronis / Diskeeper / Paragon / Raxco
R
I spent two hours on the phone with Support last night. I finally got the
Stand Alone downloaded but no way no how will it install. I have disabled
and uninstalled things, run ckdsk, scannow, memory dt, and other diagnostic
tools - nothing shows that there is a problem but after 30 minutes of
install I get the same failure message - Internal Error and Code 800B0100.
Quit trying while I got back on line to check some other things but I want
to try to install it again - but I do not know what more to try!
"TaurArian" <taurarianREMOVECAPS@xxxxxx> wrote in message
news:eKH9uMviIHA.6032@xxxxxx
> installed
> | >>it
> What
> | >>should I do?
> | > Trev
> I
> | have not received.
> for x64-based
> systems
> subject.
> until March 18,
> 2009.
> purchased it,
> available to you.
> Some issues may
T
TaurArian
Did the tech suggest anything like this -
http://www.microsoft.com/communitie...78c1&mid=e833aa54-cab4-4dc7-9292-8e1a243078c1
You'll need to go back to MS Support.
news:679BF101-527A-4CD3-A40F-FBDFFEB1AAF9@xxxxxx
| > installed
| > | >>it
| > What
| > | >>should I do?
| > | > Trev
| > I
| > | have not received.
| > for x64-based
| > systems
| > subject.
| > until March 18,
| > 2009.
| > purchased it,
| > available to you.
| > Some issues may
.Joe
1337 spammer
912
Location
127.0.0.1
Vista Windows Update error 800B0100 solution. in Windows Update
Home
How to ask a question: How to ask a question
| > installed
| > | >>it
| > What
| > | >>should I do?
| > | > Trev
| > I
| > | have not received.
| > for x64-based
| > systems
| > Description of the CheckSUR update for Windows Vista and for Windows Vista for x64-based systems
| > subject.
| > Windows Vista Service Pack 1 - Things to Know Before You Download
| > until March 18,
| > 2009.
| > purchased it,
| > available to you.
| > Some issues may
| > Home
You can get free support from Microsoft about SP1. Here's the link: https://support.microsoft.com/oas/default.aspx?ln=en-us&x=8&y=7&prid=11274&gprid=500921
I hope this helps.
    Intel Q6600 Quad Core 2.4 Ghz
    Dell 0TP406
    Nvidia 8800 GT 512 MB
    Dual Dell 22" Widescreen
    3360x1050
    320 GB Internal Main
    500 GB USB External
    160 GB USB External
    2TB USB External
    DSL 3MB
F
fatwendy
#8
Hi Ryka
I have had exactly the same problems as you both with the Windows Update and
with the standalone.
I run Vista Home Premium x64, and have done every update to date without
problem.
But SP1 keeps failing each time I try to windows update, and every now and
again it becomes unavailable and I have to reinstall update KB947821 as well
before retrying the SP1 download.
Pulling my hair out, but please let me know if you get a solution.
Cheers
FW
> > installed
> > | >>it
> > What
> > | >>should I do?
> > | > Trev
> > I
> > | have not received.
> > for x64-based
> > systems
> > subject.
> > until March 18,
> > 2009.
> > purchased it,
> > available to you.
> > Some issues may
M
monique
#9
"Had to start over with factory and then only would sp1 install without the
0x800B0100 code. Had to manual install and not use automatic. kept updating
until it showed up.
