speed fan
516
Location
North Carolina
I cant use speed fan to control any of my fans. I can see all the info but it will not allow me to configure or change any of the settings. Am I missing something or not doing something. Need help.
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
skunksmash
im coming for cake
2,254
Location
norfolk
Hi bassfisher6522....
i think speedfan will only control fans with a 4pin header from the mobo, most board headers are 3pin.
by default the only one you should be able to control with this app is the HSF
i can only control 1 fan from here, as you can see my HSF is @ 50%
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
516
Location
North Carolina
:)SK
OK thanks for the info, next question? How do I know what fan goes to what device? Example fan 1 is the fan for CPU. If fan 1 is for CPU how do I find this out and how do I change it in speed fan. I know more questions. Just trying to figure this app out. Thanks again.
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
skunksmash
im coming for cake
2,254
Location
norfolk
:)SK
unfortunately that's gonna be a case of trial & error, the application has to be quite flexible for compatibility between boards so there's no set layout for fan allocation....
you may be able to find a speedfan tweak guide on google, but as far as im aware its pretty random...
as you can see in my pic the HSF is on the 2nd fan slot, but i have seen other ppl running fans off different slots...
you will just have to play around with the headers on the board & see which value controls which fan...
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
516
Location
North Carolina
:)SK
:)SK
Thanks, I was afriad of that...can't make easy on us nontech folk can they...lol. Oh well back to old faithfull, trial and error.
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
stormy13
633
Check the hardware monitoring in the bios and make note of any fans shown there and what it lists them as, then just match them up in Speedfan.
You can also go here,
SpeedFan Configuration Manager
and register (free) and try any of the user configurations using the same motherboard as yours.
@ skunksmash, nice to see someone using Speedfan that took the time to configure and rename the readings. :D
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
skunksmash
im coming for cake
2,254
Location
norfolk
lol.....;)
i love speedfan...... many deem this app to be inaccurate but it differs from rig to rig, im one of the lucky ones i guess, on my rig speedfan reads the same as all other temp monitoring apps....
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
516
Location
North Carolina
#8
How do I rename my fans and cpu, gpu in speed fan from the default settings. From Fan 1 to fan on psu.... and so on. I still cant fing any thing.
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
stormy13
633
#9
Click on Configure, then on each tab click on the item you want to rename and hit F2. And don't forget to uncheck any that are unused, at least as far as the fans go.
Looks like he finally made it so the temps are only reporting for sensors that are present, instead of the way it used to be and listed temps for everything the monitoring chip was capable of. Used to be lots of fun with someone new to Speedfan and they would see a temp over 100° with its litle flame beside it, and start panicking. :D
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
516
Location
North Carolina
#10
Looks like he finally made it so the temps are only reporting for sensors that are present, instead of the way it used to be and listed temps for everything the monitoring chip was capable of. Used to be lots of fun with someone new to Speedfan and they would see a temp over 100° with its little flame beside it, and start panicking. :D
Thanks, that's what I needed. I couldn't find that info any where. I even registered w/speedfan and still couldn't find nothing. While log on to speedfan I checked to see if my mobo was fan controllable and it looks like a goose egg on mine. Damn OEM systems, well next system will be a build that I can control...
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
stormy13
633
#11
Only one thing to say, F1 ;). Probably why he doesn't have that info on his website, he included a fairly comprehensive help file in Speedfan; it can be a little on the technical side inplaces, but it is all there.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
