Spybot - unexpected error in fixing problems
M
MaryL
I'm not sure if this is the correct newsgroup for my question because I
don't know if this is a Vista problem or something else. I am using Vista
Home Premium (full version, not OEM), running on a Dell 530 desktop that is
only 3 months old. I have Windows firewall and AVG free running. I
connected via cable and am using a Linksys wireless-G router. I run Adaware
almost daily and Spybot Search & Destroy on a weekly basis.
AdAware has never detected any major problems -- there always some files to
delete but never any *critical* problems. Spybot never reported any
problems at all, until today. However, today SpyBot reported ErrorSmart (1
entry) as a problem. When I tried to "fix" the problem," SpyBot responded
with an error message and could not fix the problem.
The error message says:
Unexpected error in fixing problems
(Cannot create file "C:\Windows\wininit.ini". Access is denied)
I rebooted, ran AdAware (no problems detected), then re-ran SpyBot. The same
problem occurred.
When I click on the "+" beside ErrorSmart (within SpyBot) to expand, it
returns this information:
(SBI $C6597282) Web page
C:\Program Files\ErrorSmart\ErrorSmart.url
(Incidentally, I'm not sure if the message is SBI or SB1.)
Can someone on this newsgroup help? I don't have any idea what caused the
problem (or even what this problem means), and I have no idea how to fix it.
Thanks,
MaryL
D
> I don't know if this is a Vista problem or something else. I am
> using Vista Home Premium (full version, not OEM), running on a Dell
> 530 desktop that is only 3 months old. I have Windows firewall and
> AVG free running. I connected via cable and am using a Linksys
> wireless-G router. I run Adaware almost daily and Spybot Search &
> files to delete but never any *critical* problems. Spybot never
> reported any problems at all, until today. However, today SpyBot
> reported ErrorSmart (1 entry) as a problem. When I tried to "fix"
> the problem," SpyBot responded with an error message and could not
> fix the problem.
> The same problem occurred.
> it returns this information:
> caused the problem (or even what this problem means), and I have no
> idea how to fix it.
> Thanks,
> MaryL
It looks like SpyBot treats ErrorSmart as a virus.
http://forums.spybot.info/showthread.php?p=185039
Perhaps you have run ErrorSmart recently?
http://www.errorsmart.com/
M
The only thing I can suggest is running Spybot as "Administrator" and make
sure no web browsers or email programs are open.
Mark
"MaryL" <stancole1@xxxxxx-OUT-THE-LITTER> wrote in message
news:%236JSn2VrIHA.4376@xxxxxx
> is only 3 months old. I have Windows firewall and AVG free running. I
> Adaware almost daily and Spybot Search & Destroy on a weekly basis.
> to delete but never any *critical* problems. Spybot never reported any
> (1 entry) as a problem. When I tried to "fix" the problem," SpyBot
> responded with an error message and could not fix the problem.
> it.
> Thanks,
> MaryL
M
MaryL
"Dave" <1@xxxxxx> wrote in message
news:CNWdnZ9i0PE2QoHVnZ2dnUVZ8qSnnZ2d@xxxxxx
>> fix the problem.
>> idea how to fix it.
>> Thanks,
>> MaryL
Yes, that may be the problem. I downloaded a demo of ErrorSmart recently.
I did not buy the paid version, but the demo is still on my computer. I
will uninstall it and see if that solves the problem (in this case, the
"problem" may simply ben in the error message generated by Spy Bot).
Thanks!
MaryL
D
MaryL wrote:
[snip]
>>> idea how to fix it.
>>> Thanks,
>>> MaryL
> recently. I did not buy the paid version, but the demo is still on my
> computer. I will uninstall it and see if that solves the problem (in
> this case, the "problem" may simply ben in the error message
> Thanks!
> MaryL
Your "problem" is probably too many anti-malware programs. I only run AdAware about once a month
or when I'm bored. Thats the only one I run.
