SQL 2005 & Vista
D
David Sherman
Has anyone one installed SQL 2005 on Vista?
I have tried twice and I get an Error 1935 with reference 0x80071a30.
Thanks
A
Andre Da Costa [Extended64]
Try disabling UAP and see if it installs then. Start > All Programs >
Accessories > Run > MSCONFIG > Tools (tab) > scroll down > select "Disable
UAP" > Launch, restart system for changes to take effect.
Andre
Extended64 | http://www.extended64.com
Blog | http://www.extended64.com/blogs/andre
http://spaces.msn.com/members/adacosta
"David Sherman" <dshermin@ameritech.net> wrote in message
news:fjt672hphpe7n2ukkeoprfkkm26dlu427r@4ax.com...
> Thanks
D
David Sherman
Failure
I tried 3 times.
On Tue, 23 May 2006 14:15:04 -0700, "Andre Da Costa [Extended64]"
>Andre
>> Thanks
A
Is IIS 7.0 installed? If it is and that does not work, give this work around
suggestion a try:
"I took the cue from the SQL Server 2005 embedded install, which did work.
The trick is to put a new manifest and dll file in each of the Binn
directories. I can't get the SQL Management Studio to install as it has
some error during setup, but the SQL Server Services work.
First, create a new file called Microsoft.VC80.ATL.manifest and paste the
following XML into it:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<!-- Copyright © 1981-2001 Microsoft Corporation -->
<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0">
<noInheritable/>
<assemblyIdentity
type="win32"
name="Microsoft.VC80.ATL"
version="8.0.50608.0"
processorArchitecture="x86"
publicKeyToken="1fc8b3b9a1e18e3b"
<file name="ATL80.dll"/>
</assembly>
Then, locate a copy of the released atl80.dll (look in the
%systemroot%\winsxs directory of a machine with either SQL 2005 or vS 2005
on it.
Now, as the SQL 2005 installer is running, copy those two files into any
directory that has exe/dll files within the Program Files\Microsoft SQL
Server dir -- specifically:
MSSQL.1\MSSQL\Binn
90\Tools\Binn
90\Shared
90\COM
90\Setup Bootstrop (just for good measure)"
Andre
Windows Connected | http://www.windowsconnected.com
news:gla7725ke8ohlhbb7v0p2nif0005qug0jk@4ax.com...
> Failure
> I tried 3 times.
>>Andre
>>> Thanks
D
David Sherman
IIS is not installed. I could not get it installed when I tried to
install Virtual PC server.
Even though IIS isn't installed, I will try your suggestion.
On Tue, 23 May 2006 18:21:57 -0700, "Andre Da Costa [Extended64]"
>suggestion a try:
> <noInheritable/>
> <assemblyIdentity
> type="win32"
></assembly>
>on it.
>MSSQL.1\MSSQL\Binn
>90\Tools\Binn
>90\Shared
>90\COM
>Andre
>> Failure
>> I tried 3 times.
>>>Andre
>>>> Thanks
D
David Sherman
After looking at this message again, I won't be able to do it. I don't
anyone who has SQL 2005 loaded.
>suggestion a try:
> <noInheritable/>
> <assemblyIdentity
> type="win32"
></assembly>
>on it.
>MSSQL.1\MSSQL\Binn
>90\Tools\Binn
>90\Shared
>90\COM
>Andre
>> Failure
>> I tried 3 times.
>>>Andre
>>>> Thanks
A
This issue might be resolved with the first Service Pack for SQL 2005 or a
future build of Vista BETA.
Andre
news:q4p872dqec259m3emfdq2op0vn06pnqms2@4ax.com...
>>around
>>suggestion a try:
>> <noInheritable/>
>> <assemblyIdentity
>> type="win32"
>></assembly>
>>on it.
>>MSSQL.1\MSSQL\Binn
>>90\Tools\Binn
>>90\Shared
>>90\COM
>>Andre
>>> Failure
>>> I tried 3 times.
>>>>"Disable
>>>>Andre
>>>>> Thanks
D
David Sherman
#8
Thanks for the help.
On Wed, 24 May 2006 08:18:47 -0700, "Andre Da Costa [Extended64]"
>Andre
>>>around
>>>suggestion a try:
>>> <noInheritable/>
>>> <assemblyIdentity
>>> type="win32"
>>></assembly>
>>>on it.
>>>MSSQL.1\MSSQL\Binn
>>>90\Tools\Binn
>>>90\Shared
>>>90\COM
>>>Andre
>>>> Failure
>>>> I tried 3 times.
>>>>>"Disable
>>>>>Andre
>>>>>> Thanks
